Opening tunnel for rust treatment and fuel line replacement
Tempie
Tempie is offline
PostPosted: Tue May 24, 2016 5:41 am    Post subject: Opening tunnel for rust treatment and fuel line replacement Reply with quote
Hello,
Did anyone here open his tunnel from oval yet?
I know there is a topic somewhere wich was documented, but I can't find it any more.
Anyone has experience with this?
Kind regards
When a deluxe is not enough.... you go standard Smile
Early 55 standard sunroof Smile
Visit the Standard Split and Oval Beetle group!!
VW Standard Split and Oval Beetle
project_therapy
project_therapy is offline
PostPosted: Tue May 24, 2016 6:14 am    Post subject: Re: Opening tunnel for rust treatment and fuel line replacement Reply with quote
Try looking at the topic right above you in the sticky catagory...good images and references.
Tempie
Tempie is offline
PostPosted: Tue May 24, 2016 6:21 am    Post subject: Re: Opening tunnel for rust treatment and fuel line replacement Reply with quote
It's not the one I meant. Its a topic where the whole closing plate is removed
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Tue May 24, 2016 7:50 am    Post subject: Re: Opening tunnel for rust treatment and fuel line replacement Reply with quote
... man, I do that a lot... I certainly have my critics, but have supporters as well...
... here's on my '54. When installing a new gas line, from the back, I could not feed it beyond this point and opened it to find the obstruction.
... here's the clutch cable access, VW forgot to provide.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
sunroof
sunroof is offline
PostPosted: Tue May 24, 2016 10:21 am    Post subject: Re: Opening tunnel for rust treatment and fuel line replacement Reply with quote
Have a look at this:
http://www.kustomcoachwerks.com/forums/viewtopic.php?f=25&t=8630&p=240635#p240635
Don
Better and better mistakes!
Tempie
Tempie is offline
PostPosted: Tue May 24, 2016 11:01 am    Post subject: Re: Opening tunnel for rust treatment and fuel line replacement Reply with quote
Don
It was not this site, but its the same principle !!
joshbuchan
joshbuchan is offline
PostPosted: Tue May 24, 2016 8:30 pm    Post subject: Re: Opening tunnel for rust treatment and fuel line replacement Reply with quote
Don
I was just about to post a pic then realized you linked him to my thread haha!
What do you need to know? It's a pretty straight forward job....just a bunch of spot welds to drill and slice across to pop the panel off. Have full access to everything and in my opinion less chance of distorting the tunnel welding 2 or 3 8x8 panels back in on top side. Remember to re enforce the clutch cable tube in a couple spots while in there.
THX 1138
THX 1138 is offline
PostPosted: Wed May 25, 2016 12:00 am    Post subject: Re: Opening tunnel for rust treatment and fuel line replacement Reply with quote
Here's a recent thread in the split forum where someone removes the bottom of the tunnel. Maybe thats the post you're remmembering.
http://www.thesamba.com/vw/forum/viewtopic.php?t=653310
