chthemonkey Samba Member
Joined: July 30, 2008 Posts: 105 Location: united kingdom
Posted: Fri May 06, 2016 7:10 am Post subject: Headlight info |
Hi does anyone have any info on this headlights weather it off a vw or something else as the retaining tab has a return but then as you see they have vw glass and the earlier lamp hold down catch I have 2 the same
belairman Samba Member
Posted: Fri May 06, 2016 7:59 am Post subject: Re: Headlight info |
chthemonkey wrote: |
It is for pre 53 vw. |
Posted: Fri May 06, 2016 8:07 am Post subject: Re: Headlight info |
It is for pre 53 vw.[/quote]
That's what I thought but I think there original replacements as one has 1q as manufacture code but the tab is what I'm not sure about |
Posted: Fri May 06, 2016 11:24 am Post subject: Re: Headlight info |
That's what I thought but I think there original replacements as one has 1q as manufacture code but the tab is what I'm not sure about[/quote]
I dont know about being replacements but I have seen tab on 50-52 headlights. My friend has an orig 51 beetle and has that type of assembly. |
Porsche904 Samba Member
Posted: Fri May 06, 2016 1:35 pm Post subject: Re: Headlight info |
I have a pair of these on my 51', they should be ok for pre -52 cars |
bwaz Samba Member
Posted: Fri May 06, 2016 3:05 pm Post subject: Re: Headlight info |
I've seen them on Zwitters as well. |
janerick3 Samba Member
Posted: Fri May 06, 2016 7:17 pm Post subject: Re: Headlight info |
If the date codes on the backside of the reflectors are unreadable, the lenses are (usually) date-stamped at the 12 o'clock position on the lip, with a roman numeral and a letter. _________________ Thanks,
Jan K. |
James Davies Samba Member
Joined: September 24, 2013 Posts: 141 Location: Baltimore, USA
Posted: Mon May 16, 2016 8:57 am Post subject: Re: Headlight info |
My guess would be that the chrome rings are from 1951 or earlier. By 1952, the Bosch chrome rings has round fastening tabs at the bottom. |
Posted: Mon May 16, 2016 7:12 pm Post subject: Re: Headlight info |
If the "1Q" date code on the other reflector is really "1G," then the headlight dates to January 1951. For the reflector shown, there appears to be the date code "2G" barely readable between the two rows of numbers. _________________ Thanks,
Jan K. |
gorlininc1 Samba Member
Joined: July 25, 2011 Posts: 38 Location: MERRITT ISLAND, FL
Posted: Mon May 16, 2016 7:17 pm Post subject: Re: Headlight info |
The 5 drain hole Bosch buckets are for the zwitter. From all my reading pre-zwitter Bosch have no drain holes. The bent screw tab is also zwitter. I believe that the splits have a flat tab and a single rivot. This is my understanding from over the years. If I'm wrong, then I stand correct. But I'm pretty sure I'm correct. _________________ 1952 zwitter
1971 Toyota FJ40
1997 Jaguar XK8 vert
2006 Lexus SC430
RVA MEMBER |
