Noisy alternator?
bhartwell59
bhartwell59 is offline
PostPosted: Tue May 10, 2016 6:34 am    Post subject: Noisy alternator? Reply with quote
What do you all make of this noise? The video records the noise that seems to be coming from the alternator.
I replaced the fan belt last weekend, drove it around for the first time since Christmas and then noticed this whistling.
Probably doesn't matter but it's a '74 Ghia auto stick, vert... new carb, new fuel pump installed last Christmas.
Thanks!
'74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k
sjbartnik
sjbartnik is offline
PostPosted: Tue May 10, 2016 7:52 am    Post subject: Re: Noisy alternator? Reply with quote
Sounds like a really nasty ready-to-die alternator bearing.
Remove belt and spin alternator by hand. Does it feel smooth and quiet or gritty and noisy?
I wouldn't continue to run it like that, if the bearing seizes while running you're gonna have some problems.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
bhartwell59
PostPosted: Tue May 10, 2016 10:31 am    Post subject: Re: Noisy alternator? Reply with quote
Hmmm, the bearing... that sounds right.
Is that something I can replace or is it better to replace the whole alt?
sjbartnik
PostPosted: Tue May 10, 2016 10:36 am    Post subject: Re: Noisy alternator? Reply with quote
If the alternator is electrically OK, a competent auto electrical rebuilder should be able to replace the bearings no problem (there are most likely two bearings, one at the pulley end and one at the fan end).
Just make sure high quality sealed bearings are used, like FAG or SKF.
This may be beyond the reach of a home mechanic unless you have a press to press the bearings on and off the shaft.
But check it first, pull the belt and see how it spins by hand. If the bearings are bad you will feel it and hear it.
Here's my generator with a bad rear bearing (the one closest to the pulley). It was making some noise when running on the car:
In addition to being noisy when spun by hand it felt gritty and notchy. It should be silent and smooth when spun by hand.
2000 Kawasaki W650
bhartwell59
PostPosted: Tue May 10, 2016 12:26 pm    Post subject: Re: Noisy alternator? Reply with quote
Cool... that helps a lot!
22manybugs
22manybugs is offline
PostPosted: Tue May 10, 2016 9:48 pm    Post subject: Re: Noisy alternator? Reply with quote
One other thing to check: make sure the back of the pulley isn't rubbing against the alternator body. Sometimes aftermarket pulleys do not stand up well to over-torqueing, then the rear half of the pulley starts to break away from the hub and rubs against the alternator body.
Lon
1969 Karmann Ghia convertible
1971 Westfalia camper
sjbartnik
PostPosted: Wed May 11, 2016 6:32 am    Post subject: Re: Noisy alternator? Reply with quote
Good idea! Easier/cheaper than replacing alternator bearings. Very Happy
2000 Kawasaki W650
runamoc Premium Member
runamoc is offline
PostPosted: Wed May 25, 2016 3:08 pm    Post subject: Re: Noisy alternator? Reply with quote
NSK 6202VVC3 17mm, 40mm x 12mm
NSK 6203VVC3 15mm, 35mm x 11mm
Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
bhartwell59
PostPosted: Wed May 25, 2016 3:58 pm    Post subject: Re: Noisy alternator? Reply with quote
Thanks... where should I buy the bearings from? The alt is a Bosch AL78 (external regulator).
runamoc is offline
PostPosted: Wed May 25, 2016 5:05 pm    Post subject: Re: Noisy alternator? Reply with quote
I got mine from work. Wink EBay and Amazon have them for around $15 each. Found some with that # for $6 FS but they were DDU. Whatever that means but the picture was identical.
74 Thing
74 Thing is offline
PostPosted: Thu May 26, 2016 2:20 pm    Post subject: Re: Noisy alternator? Reply with quote
Ebay the 6202 and 6203 bearings.
