Bilscho Samba Member
Posted: Wed Apr 20, 2016 10:29 am Post subject: Oil suddenly hot, and pressure low |
have just built a standard 1500 sp which had been running great with good oil pressure and low temp. Got about 120 miles on the clock and, on a short run out today, about 5 miles, all of a sudden the temp started to rise, and the pressure fall. No unusual mechanical noises, just the gauges and the hot oil smell.
Temp got up to about 110c and oil pressure below 14psi at 30mph, not good.
Ideas really appreciated, thanks |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Apr 20, 2016 12:01 pm Post subject: Re: Oil suddenly hot, and pressure low |
Single relief case? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15315 Location: Deep in the 405
Posted: Wed Apr 20, 2016 8:37 pm Post subject: Re: Oil suddenly hot, and pressure low |
Many years ago Gene Berg discovered that on early Bus that how many side windows you have open or closed effects the airflow to the side engine vents and causes the engine temps to change. Do a test with all the windows rolled up then repeat the same test with all the windows rolled down. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
stanovich Samba Member
Joined: March 18, 2013 Posts: 191 Location: central coast calif
Posted: Wed Apr 20, 2016 9:30 pm Post subject: Re: Oil suddenly hot, and pressure low |
check for a stuck relief valve, slightly open will cause the oil to heat and the pressure to drop. check for dirt in the system when you drain the oil and let us know what you find |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51175 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Apr 20, 2016 10:01 pm Post subject: Re: Oil suddenly hot, and pressure low |
Not a bad idea to look in the fan as well for a rag or plastic bag. (engine stopped of course) _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 21, 2016 12:38 am Post subject: Re: Oil suddenly hot, and pressure low |
Thanks for all ideas, it turned out to be rag in the fan, no idea where that came from!! So top marks to busdaddy. |
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Thu Apr 21, 2016 1:07 am Post subject: Re: Oil suddenly hot, and pressure low |
Props to the acid snail! _________________ "...swingaxle...transaxle...same diff." |
Posted: Thu Apr 21, 2016 7:04 am Post subject: Re: Oil suddenly hot, and pressure low |
I'm lazy so I always try the simple stuff first
Good to hear it's solved. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
theDrew Samba Member
Posted: Thu Apr 21, 2016 9:48 am Post subject: Re: Oil suddenly hot, and pressure low |
respect the fan! I've found the strangest things sucked up by that thing _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Fri Apr 22, 2016 6:07 am Post subject: Re: Oil suddenly hot, and pressure low |
fastfil wrote: |
Props to the acid snail! |
That's not an acid snail, that's GARY!
_________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
LocoPedro Samba Member
Posted: Wed May 25, 2016 12:03 pm Post subject: Re: Oil suddenly hot, and pressure low |
FWIW...
I recently had a similar problem with regards to oil temps and pressure.
As I started diagnosing the relief valve (single relief case) I noticed the return spring was getting caught on an edge in right at the piston open position, causing my pressure and oil temp problems.
I noticed that my spring was flat at the top and had sharp edges so I rounded them out a bit and reduced the diameter of last spiral, which made it spring back without a problem.
Seems to be working so far...
Anyway I thought I would share in case anyone else encounters the same issue. _________________ '57 Oval Beetle -- Electric (Lil' Ohms)
'66 13 window Deluxe |
