Judson Magneto / Ignitor
Schnage
Schnage is offline
PostPosted: Mon Mar 21, 2016 12:41 pm    Post subject: Judson Magneto / Ignitor Reply with quote
Hello, i have a 1960 Beetle with a judson charger and magneto, what ignitor is the right for a 1192 cc 30 hp engine? And has someone expierience with that setup? Markus
robotrophic
robotrophic is offline
PostPosted: Mon Mar 21, 2016 3:11 pm    Post subject: Re: Judson Magneto / Ignitor Reply with quote
Is "ignitor" interchangeable with distributor?
If so, the Bosch 010 is a common distributor used with a Judson, as is the 019.
Schnage
Schnage is offline
PostPosted: Tue Mar 22, 2016 11:22 am    Post subject: Re: Judson Magneto / Ignitor Reply with quote
No, ignitor from pertronix, the electronic disconnector...
Schnage
Schnage is offline
PostPosted: Fri Mar 25, 2016 10:04 am    Post subject: Re: Judson Magneto / Ignitor Reply with quote
Mhhh, it looks like no one has an idea? I am thinking abaut to use a ignitor or hot spark system to my judson magneto, but i dont know this works?
txoval
txoval is offline
PostPosted: Fri Mar 25, 2016 11:02 am    Post subject: Re: Judson Magneto / Ignitor Reply with quote
Send a PM to Glenn or TASB
They can probably help you
Schnage
Schnage is offline
PostPosted: Thu Mar 31, 2016 10:46 am    Post subject: Re: Judson Magneto / Ignitor Reply with quote
Does someone know the primery resist of the judson magneto? Im mean the resist bewenn + and - ? I dont have my car here to look at the coil....
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Mar 31, 2016 10:56 am    Post subject: Re: Judson Magneto / Ignitor Reply with quote
If you have a 010 or 019 then the Pertronix 1844 (12v) and 1844N6 (6v) drops in.
Glenn
Member #1009
#BlueSquare
Schnage
Schnage is offline
PostPosted: Thu Mar 31, 2016 11:45 am    Post subject: Re: Judson Magneto / Ignitor Reply with quote
I have a 6 volt, but the question ist, does the pertronix work with my judson magneto?
Jacks
Jacks is offline
PostPosted: Thu Mar 31, 2016 12:02 pm    Post subject: Re: Judson Magneto / Ignitor Reply with quote
Read this
http://www.thesamba.com/vw/forum/viewtopic.php?t=423444&highlight=magneto
Jack Staggs
Actual name
