the trouble with lloyd (a 74 rebuild)
troubledmind76
troubledmind76 is offline
PostPosted: Tue Sep 15, 2015 4:03 pm    Post subject: Reply with quote
Started to weld in the passenger rear wheel well. Not thrilled with the thin replacement panels, but anything is better than rust and putty.
troubledmind76
PostPosted: Sun Mar 27, 2016 7:14 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
spring and time to get back to work again. lost winter storage for my bikes so had to get the pans out of the shed, so I had some friends help put the body back on.
troubledmind76
troubledmind76
PostPosted: Sun Mar 27, 2016 7:15 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
troubledmind76
PostPosted: Sun Mar 27, 2016 7:20 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
still have a lot of body work to do but, I should be able to finish the rest with the body on without too much problem ( we do what we have to do).
I had some issues with the pan bolt holes not all lining up with the captive nuts on the new heater channels and napoleons hat, but it was the cheap stamping and not as much my measurements. honestly considering how much I replaced it went back together and fit better than I had expected. overall I'm pleased with it. hopefully I will be able to finish the body work this summer and move on to the electrical. just have to wait and see how it goes.
troubledmind76
PostPosted: Sun Mar 27, 2016 7:27 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
it looks better than the pictures show. the pans were a bit dirty from sitting out exposed for a year and then the kids walking on them in the shed but i'll clean them up when I finish the body work and give another top coat before I install sound deadening
BeetL62
BeetL62 is offline
PostPosted: Sun Mar 27, 2016 7:36 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Looking good! Keep up the good work.
vwman1960
vwman1960 is offline
PostPosted: Sat May 14, 2016 5:17 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Nice work! Little guy is looking good! Glad you didnt give in to all the ney sayers who told you to scrap him
VERTED71
VERTED71 is offline
PostPosted: Sat May 14, 2016 9:04 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
....wow....looking at how much you have done makes me super lazy as all I need to get my vert back on the road is rust bullet the pans and re-install the battery. Hats off to you my friend. Keep us posted as to your progress.
Aloha'z and have a great day!
71 Super Beetle Vert
15x4.5 Front
15x6.5 Rear
155/60R15 74T tires FRONT
205/65/15 tires REAR
1600 Dual Port
Progessive Carb
Electronic Ignition
Tri Mil "hotdog" exhaust
kitmar
kitmar is offline
PostPosted: Sat May 28, 2016 11:12 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Meet Winnie !!
These type 1 Sunbugs are quite rare now and I think are very special.
I admire the work you are putting in to put Lloyd back on the road and I am sure it will be a very satisfying experience when you get to drive the car.
Very Best
Chris JM
troubledmind76
PostPosted: Mon Jul 02, 2018 6:34 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Been away for a long time but was finally able to get back to work on lloyd. The front clip was hit at some point in the 80s and was never repaired. Just lots of putty and all the captive nuts were rusted out along with the entire drivers side. Nothing really to save. As always I was worried about the thinner aftermarket parts but with no good donor parts local to me and not willing to take a chance on having someone else's unk own putty filled panel shipped I went with one from cip.
troubledmind76
PostPosted: Mon Jul 02, 2018 6:51 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
[/img]
troubledmind76
PostPosted: Mon Jul 02, 2018 6:52 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Rough fitting the replacement
troubledmind76
PostPosted: Mon Jul 02, 2018 6:53 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Welded in now. Have a lot of cleaning to do but everything fit pretty well
troubledmind76
PostPosted: Mon Jul 02, 2018 6:55 am    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Fenders line up well and the lid closes as it should with a decent gapping
Rome
Rome is offline
PostPosted: Mon Jul 02, 2018 2:50 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Glad to see an update that you're still interested in Lloyd.
What do you plan for the hood seal retaining lip? Remove the part still on the car and use a Mexican under-the-hood seal- http://vwparts.aircooled.net/Front-Hood-Seal-Beetle-and-Superbeetle-Mexibug-p/mexihoodseal.htm
or weld in a replacement lip? http://vwparts.aircooled.net/Hood-or-Decklid-Seal-Channel-Front-or-Rear-Bug-p/111-813-311.htm
troubledmind76
PostPosted: Mon Jul 02, 2018 10:22 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Plans are to weld in a new channel
troubledmind76
PostPosted: Sat Mar 21, 2020 12:18 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Been too long since I had a chance to do any work. I was in a bad motorcycle accident at the end of 2017 and i was laided up for a few months then had to move. Recently started back on lloyd. It's slow getting back Into it but determined to finish someday.
troubledmind76
PostPosted: Sat Mar 21, 2020 12:35 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Started by finishing of patching the rear tray and then laying some sound deadener
troubledmind76
PostPosted: Sat Mar 21, 2020 12:37 pm    Post subject: Re: the trouble with lloyd (a 74 rebuild) Reply with quote
Decided to rework the dash some too. ( should have do e that before the sound deadener . Well we all make mistakes and get in a hurry sometime.
Page 3 of 6
