69Weekender Samba Member
Posted: Sun Jan 24, 2016 8:08 pm Post subject: 1969 California Camper |
So this past Saturday (1/23/16) I took out the $3,000 I'd been saving up to go and buy a bus I had only seen pictures of. It was 35 minutes from my house and it was exactly what I have been endlessly searching for for months.
I have wanted a bus probably my entire life and now i have one!
Here's the story:
My dad and I get to the sellers house and he was a great guy. He told me all about his 19 years with the bus and how he was extremely sad to part with it.
I told him I would take extrordindary care of "Linda."
This was the first car I bought with my own, hard earned cash so I have extreme pride in every rust hole, squeak, noise and quirk in my bus.
I plan to restore this bus as originally as I can. It has A LOT of rust but the frame is the best I've seen on a bus, it cruises 50-55 all day long, stops as good as its three drum brakes (one brake line is crimped) will let it and the interior is about 90% complete.
Anyways, here she is! I hope everyone here enjoys looking at her as much as I do!
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1771 Location: Newmarket, ON
Posted: Sun Jan 24, 2016 9:45 pm Post subject: Re: 1969 California Camper |
How old are those tires? Likely not something you really should be trusting your life to. |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12845 Location: San Jose, California, USA
Posted: Sun Jan 24, 2016 9:47 pm Post subject: Re: 1969 California Camper |
Welcome to TheSamba!
1969 wiring changes
Posted: Mon Jan 25, 2016 5:11 am Post subject: Re: 1969 California Camper |
TCASH - Thanks brother!
71Survivor - I am so stoked about this bus!
Wildthings - To tell you the truth, I have no idea. I couldn't find a date code anywhere. There is no dry rot and the tread is next to perfect so I hope I don't have to replace them right away. The PO gave me a spare tire too and I think that tire is about as old as the bus!
As the week progresses, I am going to find time in between school and practice to go through the electrics, tires, fluid levels and hopefully make her to school on Friday! |
Posted: Mon Jan 25, 2016 5:28 am Post subject: Re: 1969 California Camper |
So I got up early yesterday before work and started to do some minor deconstruction and some cleaning.
I started using BlueMagic leather and vinyl cleaner and followed it with their conditioner. The seat behind the driver's seat (if someone could give me the proper name for it that would be great!) was extremely dirty so i also hit it with some Purple Power and a light brush.
Then I was testing out the maneuverability of the z-bed. It was super hard to get it to recline even a little bit so I decided to unscrew the hinges from the bottom part of the seat and pulled out the top and hinges for a cleaning, sanding, painting and regreasing.
As I was taking off the hinges I noticed three different screws being used.
I am assuming the long bronze-ish on is the right one.Also, how many screws are supposed to be attached on each side and where can i buy new ones?
Yes I know it is stripped. |
72camper Samba Member
Posted: Mon Jan 25, 2016 7:28 am Post subject: Re: 1969 California Camper |
69Weekender wrote: |
The seat behind the driver's seat (if someone could give me the proper name for it that would be great!).... |
I can only help here and that seat would be known as the jump seat. |
Posted: Mon Jan 25, 2016 8:05 am Post subject: Re: 1969 California Camper |
72camper wrote: |
Ah gotcha, awesome! Thank you! _________________ Mitchell
ISO any California Road Runner Camper parts or info
1969 California Road Runner Camper: http://www.thesamba.com/vw/forum/viewtopic.php?t=646780
1989 Dodge D250 2WD 5SPD
Past:
2015 Tacoma, 01 Honda Insight, 06 Beetle TDI, 77 Toyota, 96 Geo Metro, 06 Tacoma, 13 Jetta Wagon, 05 Jetta, 96 Corrado VR6 |
Posted: Mon Jan 25, 2016 8:35 am Post subject: Re: 1969 California Camper |
Your shorter flat head screw is probably the original, but maybe not a single one is. I really don't know. Most hardware stores have quite the selection of wood and sheet metal screws these days, you just have to be willing to pull out a lot of drawers to see what is hidden on the shelves. It is quite possible that some of you holes have been stripped so you will end up with more than one diameter screw which since the larger screws will also have larger screwheads can possibly cause problems.
It looks to me like your tires are probably P185/75r14 tires (or something close to that size) which are way underrated for a bus and especially if they are very old could fail all to readily. |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Jan 25, 2016 8:44 am Post subject: Re: 1969 California Camper |
Welcome to the air cooled life!
Change those fuel lines and work on your rock-paper-scissors skillz. _________________ 1976 Westy
1966 Beetle |
Posted: Mon Jan 25, 2016 9:12 am Post subject: Re: 1969 California Camper |
Wildthings - That's what i was going to do if I could not find originals. I'll measure the thread pitch when i get home. Also, the tires are 195/75/14. What do you mean by underrated?
Bala - Why the rock, paper, scissor skills lol?
In other news: I am going to Harbor Freight today to 1) Apply for a second job 2) Buy a flux welder, welding googles, POR15, cheap paintbrushes, angle grinder (maybe), and some clear silicone as a temporary fix until i can get ahold of some new seals.
I am also going to try and finish cleaning the two z-bed cushions. Once those are clean, I will degrease, sand, paint and regrease the hinges. Hopefully I can have it installed buy the weekend! _________________ Mitchell
Past:
Bala Samba Member
Posted: Mon Jan 25, 2016 10:01 am Post subject: Re: 1969 California Camper |
Bala - Why the rock, paper, scissor skills lol? |
Just messin' with ya.
Try to keep your bus "on the road" while you're working on it. It will help keep your motivation level up!
Before you spend too much time on that Z-bed, have you thought about trying to find an original westy interior? If that's the direction you want to go... _________________ 1976 Westy
1966 Beetle |
Posted: Mon Jan 25, 2016 10:06 am Post subject: Re: 1969 California Camper |
I got my child's cot from BD. $80 gets it. |
Posted: Mon Jan 25, 2016 10:25 am Post subject: Re: 1969 California Camper |
Bala - Wow lol, that went right over my head. Great joke! I've been driving it around my neighborhood without a plate just becuase it is so fun.
I would like to keep the bus in the most original state that I can. That being siad, I do not really want to completely swap the interior. Plus, it is in such great condition, there is no sense in changing it!
72camper - Thanks for the input! _________________ Mitchell
Past:
Abscate Samba Member
Joined: October 05, 2014 Posts: 22722 Location: NYC/Upstate/ROW
Posted: Mon Jan 25, 2016 10:48 am Post subject: Re: 1969 California Camper |
Its rock paper scissors lizard Spock, anyhow.
Some people here just can't keep up.
Congratulations on your new van....I mean Bus, OP
(Cue cartoon link someone - I can't find it) _________________ .ssS! |
Posted: Mon Jan 25, 2016 11:07 am Post subject: Re: 1969 California Camper |
Wildthings - That's what i was going to do if I could not find originals. I'll measure the thread pitch when i get home. Also, the tires are 195/75/14. What do you mean by underrated? |
Tires are only designed to carry so much weight. You wouldn't expect to see the tire designed for a Smart Car installed on a semi. Your present tires have a load index of 92 which means they are only designed to handle 1389# in passenger car use or 1264# when derated for MPV/light truck use, while your weight rating is going to require a stronger tire. A P205/70R14XL (load index 98 ) or P215/70R14 (load index 96) will meet the load requirements of your vehicle, but many people think you need to go even stronger and use a 185R14C truck tire or even something heavier. There are also 195/75R14LT (LR 96) tires that will meet your needs, these tires are available in a more aggressive tread.
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Jan 25, 2016 11:32 am Post subject: Re: 1969 California Camper |
Abscate wrote: |
(Cue cartoon link someone - I can't find it) |
http://www.samkass.com/theories/RPSSL.html
Couldn't find the cartoon link either and waiting for help.
Aloha
tp |
Posted: Mon Jan 25, 2016 11:59 am Post subject: Re: 1969 California Camper |
... I am going to Harbor Freight today to ... Buy ... and some clear silicone as a temporary fix until i can get ahold of some new seals. ... |
There are better sealants than silicone and silicone can cause future paint problems. Do a search for sealants for windshield gaskets and you'll find better products and helpful recommendations. If I recall Ray Greenwood has some excellent comments.
Aloha
tp |
Tcash Samba Member
Pinetops Samba Member
Posted: Mon Jan 25, 2016 1:51 pm Post subject: Re: 1969 California Camper |
I love your bus and your enthusiasm. I wouldn't change the interior either, just restore it and get everything looking and working like it should. You are going to have a blast with this bus. Just please do everything with safety in mind.
Keep us posted on your progress! _________________ "A rolling bus gathers no rust." |
