usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Wed Oct 28, 2015 4:50 am Post subject: |
OK, so not for a car for sure with 90 Watt?
Is there a way to check if it works? _________________ Master of my domain! |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1463 Location: Finland
mikeandkirsti Samba Member
Posted: Wed Oct 28, 2015 10:38 pm Post subject: |
The date code is on the other side above the Bosch logo, usually very hard to read. As I recall early Kübelwagens had a 90W generator but utilized a different style relay. From 1943 it looked liked this but generator was 130W, also for Schwimmwagen and KdF Type 92/82E. It may be that the KdF-Wagen Type 60 utilized the 90W generator and this relay? Check the date code on it.
usariemen wrote: |
I just found this strange D shaped regulator with a flat top.
It has an unusual writing that ends with 1Z
Is that the date code? So january 1944?
But what is between the scew holes? That looks like an N?
Inside there is an extra condensator?
From below a spiral (resistor?) that is also new to me.
Is that a typical KdF aera part? |
Posted: Thu Oct 29, 2015 8:11 am Post subject: |
mikeandkirsti wrote: |
You are right mate!
Some brushing and there it was. 1Y
That´s january 1943?
Would be good to know if that type was on a car. _________________ Master of my domain! |
Posted: Thu Oct 29, 2015 11:59 am Post subject: |
Yes, it is January 1943.
Without checking I cannot say for sure but I am pretty certain the KdF-Wagen Type 60 uses the 90W generator and this is a regulator for it, correct for the KdF Type 60 1943-1944.
Worth it´s weight in gold maybe?
The 90W generator was used again in 1946-47 in the Type 11 Beetle and this regulator would work for on one too but the cover would have been with the cross pressing already. |
Posted: Thu Oct 29, 2015 1:24 pm Post subject: |
Now we are talking.
Sounds promising. _________________ Master of my domain! |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Wed Oct 25, 2017 6:49 pm Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
Ok, so here is a question regarding SWF date codes. Among many ribbed SWF sems I have, I have an "IB" and an "MB". Despite the first page of this thread stating that "I" was not used (for year anyway), "I" is the month on my "IB" and it is Sept 1950. What is "MB", or what letter between I and M is skipped because if none were skipped then "M" is the 13th month of the year.
Sorry if this was covered previously in this thread, I didn't read all the posts.
I propose that "M" is December and "L" was skipped because it looks too much like an "I". Just a theory..... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Oct 26, 2017 6:48 pm Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
Ok, scratch that theory, I am going through all of my sem pics and have found an "LD" that I restored years ago. So what is the missing letter??? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Fri Oct 27, 2017 6:17 am Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
J ?? |
Posted: Fri Oct 27, 2017 8:20 am Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
Yes, would have to be J or K. Still going through my hundreds of pics of sems... Any one have ribbed SWF sem with a J or K letter for the month? _________________ John Henry
'57 Deluxe
'56 Single Cab |
GHIA Samba Member
Posted: Sun Jan 07, 2018 1:09 pm Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
Someone would have it Garbe Lahmeyer date code ? |
Peter_KG Samba Member
Joined: January 08, 2013 Posts: 148 Location: Belgium
Posted: Fri Mar 30, 2018 10:55 am Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
Hi y’all,
I have this NOS Bosch round voltage regulator, the only code I can find on it is; RS/TB/130-150/6/1. Any info (date) for this one, is much appreciated! _________________ VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69834 Location: Phoenix Metro
Posted: Fri Mar 30, 2018 10:42 pm Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
I'm used to this code:
The date code is on the other foot:
1K in this case
I see a pic with similar codes on the box in the Gallery but I don't have any close-up photos of the feet
Does your regulator have the rounded-off mounting feet?
If it's doesn't, it's not for a VW _________________ How to Post Photos
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Apr 01, 2018 2:50 am Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
GHIA wrote: |
Early distributors not really a code 3/55 for March 1955 for example. Later distributors do not have any date codes on them. Not sure on other components. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Apr 01, 2018 5:00 am Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
Thanks!! I found the ebay add, in my google searches, too... However, couldn’t find any 356 with a round Bosch voltage regulator though...
Couldn’t find any Bosch code, that would tell me the date, neither!
So still searching to find out what car it belongs to.
Posted: Fri Nov 30, 2018 6:26 pm Post subject: |
xavi_242 wrote: |
just got a BR8 centrifugal distributor... can't date it.
It only wears a little 10 stamped at the body... and a big 1 on one other side...
any thoughts? Oh, badge is french... |
I realize that this post is over 8 years old but it would be cool to see a picture of this distributors badge if it is indeed French and Bosch?
There wasn't anyone in quality control inspecting the date code stamps so sometimes they are missing the month or year stamp or are indistinct. The big "1" is the terminal designation for the through bolt.
The VJU 4 BR 8 was used on the Beetle from August 1954 until July 1960. The Ghia only used this distributor for a shorter period compared to the Beetle of August 1955 until July 1959.The Ghia received the new vacuum only distributors on a trial basis. _________________ Roads Scholar &
James Davies Samba Member
Joined: September 24, 2013 Posts: 141 Location: Baltimore, USA
Posted: Thu Feb 06, 2020 9:21 pm Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes |
The round Bosch RS/TB 130..150/6/1 voltage regulator above is for a 1951 Mercedes 220. It matches to the LJ/GJH 130/6/2200 R 1 generator. It is listed in the 1952 Bosch parts book.
It also is for the 1952 Ford Taunus 12M, matched to the LJ/GE 130/6/2600 R 3 generator. |
