mnakandala Samba Member
Joined: September 28, 2009 Posts: 245 Location: Sri Lanka
Posted: Mon Aug 11, 2014 2:00 am Post subject: What is stock flywheel made of? |
Hi guys a little dilemma, the subject tells it all, what is the stock VW bug 200mm 12V flywheel made of? is it cast iron or other material
_________________ 1964 bug
1983 mitsubishi Delica |
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Mon Aug 11, 2014 2:07 am Post subject: |
The stock German flywheels are Chromium vanadium steel very high quality by OEM standards (most OEM stuff is cast), yes there are cheapo cast iron wheels out off brazil etc both OEM and aftermarket. |
Posted: Mon Aug 11, 2014 2:15 am Post subject: |
Joe Bence wrote: |
Thank you Joe Bence and is there a way to identify these from one another? _________________ 1964 bug
Posted: Mon Aug 11, 2014 2:18 am Post subject: |
I can tell just from looking at it. Also if some one is selling a flywheel or lightened flywheel too cheap it is most likely cast.
Cast wheels have a dull machine finish and pressed on ring gear, German wheels have a shiny machine finish. |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Mon Aug 11, 2014 3:00 am Post subject: |
The machine finish is from the machining after it is cast. Cast iron provides a very effective frictional surface in such an application. There would be no logical reason to forge such a part (except the "forgery" of marketing.) _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Mon Aug 11, 2014 4:25 am Post subject: |
Quokka42 wrote: |
The machine finish is from the machining after it is cast. Cast iron provides a very effective frictional surface in such an application. There would be no logical reason to forge such a part (except the "forgery" of marketing.) |
What is your point? The VW stock flywheel is Chrome Vanadium steel. It is a good choice of material. The cast aftermarket ones are very weak as discovered by some who had them fall off leaving the center on the crank. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
Posted: Mon Aug 11, 2014 4:45 am Post subject: |
Not sure of the metallurgy, I'd have though Chrome Vanadium too expensive and unnecessary for this application, but it is definitely cast steel - you can often see the mould impression. Very hard metals such as Cr-V tend too provide poorer friction and less heat tolerance, as does forged metal. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3485 Location: Paradise, Ca
Posted: Mon Aug 11, 2014 12:09 pm Post subject: Flywheel |
If your application is high performance, I would not settle for anything but a NEW forged chromoly flywheel. Vw's have enough issues with the dowl pin area already. Dont settle for anything but a REAL Chromoly flywheel such as this:
http://www.thesamba.com/vw/classifieds/detail.php?id=1382480
I spun the Center out of a "German" flywheel after a hard launch on the street. Never again will I mess with a stock VW flywheel of any sort in high performance application.
Jeff _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Mon Aug 11, 2014 12:36 pm Post subject: Re: Flywheel |
jpaull wrote: |
Jeff |
I almost called BS on that remark. I honestly dont think its possible to to do. Maybe the "German" flywheel was made by a guy called Chang...
You cannot get a better flywheel than stock. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Aug 11, 2014 1:05 pm Post subject: |
This is true. I saw the light a few years ago myself and almost always try to run a german flywheel when .possible on builds now. A loose or improperly torqued gland nut can accomplish the same results. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Mon Aug 11, 2014 1:15 pm Post subject: |
Where are you finding German flywheels? Buying a used one and 8 doweling? Refacing ect? _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Aug 11, 2014 1:32 pm Post subject: |
I used to shoot at an old VW flywheel at a gravel pit when I was a teenager. 6.5x55 Swedish Mauser with fmj ammunition wouldn't even leave a dent in an oem german flywheel. Just a shiny spot and it rang like a bell.. That was not cast iron. _________________ 1958 Karmann Ghia owner |
Posted: Mon Aug 11, 2014 1:43 pm Post subject: |
andy198712 wrote: |
Where are you finding German flywheels? Buying a used one and 8 doweling? Refacing ect? |
DPR Jose will take a good German core and re-manufacture it to your liking. |
Posted: Mon Aug 11, 2014 2:18 pm Post subject: |
I'll have a look at his site, being in the uk mean postage is a killer on something like that _________________
Alstrup wrote: |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1168 Location: Las Vegas, Nevada
Posted: Mon Aug 11, 2014 3:35 pm Post subject: |
From first hand experience, I have lighten stock flywheels and they are anything but cast iron ,cast iron is very flake when machined like drilling a cast rotor and Cr-v does not chip very well it wants to come off the tool in strings. Also the stones to resurface most import fly wheels are speced for Cr-v. I highly recommend buying only OG VW flywheels especially for daily drivers. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Aug 11, 2014 4:16 pm Post subject: Re: Flywheel |
Boolean wrote: |
I almost called BS on that remark. I honestly don't think its possible to to do. Maybe the "German" flywheel was made by a guy called Chang... You cannot get a better flywheel than stock. |
German was in quotations, probably meaning he got burned by a cast flywheel masquerading as a true OG steel one. I've seen pics of an exploded cast flywheel, and it wasn't even on a strung out motor. Get a real German one, or a a confirmed steel one to avoid issues. The Ford and Chevy guys can get away with it, we can't. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1854 Location: Grass Pants, Orygun
Posted: Mon Aug 11, 2014 6:18 pm Post subject: |
Boolean wrote: |
Quokka42 wrote: |
What is your point? The VW stock flywheel is Chrome Vanadium steel. It is a good choice of material. The cast aftermarket ones are very weak as discovered by some who had them fall off leaving the center on the crank. |
Later OEM VWs had cast cranks and flywheels. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
Posted: Tue Aug 12, 2014 4:31 am Post subject: |
I think the Germans were a little too clever to forge a flywheel ever. It doesn't mean they were cast iron, a lot of metal can be cast (and what we traditionally know as "cast iron" would be unsuitable for this application due to it's high carbon content.) Ironically, (pun intended,) several "stainless steel" alloys work well for flywheels and brake disks and drums, but they are almost invariably cast. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Mon Apr 03, 2017 1:52 pm Post subject: Re: What is stock flywheel made of? |
Old thread, but I am curious about the use of cast flywheels. Seems like they have been around for ACVW's for a number of years now. Has there been any improvement in metallurgy to where they are now ok to use?
p.s. remember old quokka42? _________________ DDC racing |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21650 Location: Oklahoma City
Posted: Mon Apr 03, 2017 3:41 pm Post subject: Re: What is stock flywheel made of? |
Lot of crap in this thread. The stock flywheels are indeed steel...cast and hardened steel...not cast iron...and not forged. They are tougher than hell.
For instance among type 4 engines (I realize we are speaking of type 1 here)..the only models that came with a forged flywheel were the early 411 with 200mm (Europe only) and the Porsche 914 2.0 liter.
Cast steel is totally different than cast iron...alot stronger tensile wise but with some of the same issues.
All aircooled VW types 1 through 4 cranks that came out of Germany were forged. Whether they started making some cast cranks in Brazil in the last years.....mainly 1980s....I do not know.
Aftermarket cast flywheels...I have no idea what they are made of whether its iron or steel. Ray |
