Melville Engineering steel and pipe 54' rhd single
Page: Previous  1, 2, 3 ... 6, 7, 8 ... 14, 15, 16  Next
splipete
splipete is offline
PostPosted: Sat Dec 29, 2012 1:11 pm    Post subject: Reply with quote
Nothing much been said on this subject for a while but as this is where I mentioned my 54 Sc before, I thought I'd post here.(someone tell me if I should start a new thread!)
I'm going to be making a start on the resto soon and I'm stuck which way to go.
As I've said the truck started life as a LHD but somehere way back was converted to RHD.
If I'm going to invest a load of time and money do I change it back to LHD or leave it like it is and accept that is part of the history?
If I leave it RHD is there any point aiming for that 100point stock show winning finish or is the truck always going to be looked on as non-original?
In that case do I slam it and chuck in that big motor I've always wanted and not worry about destroying a rare truck?
derv
derv is offline
PostPosted: Sat Dec 29, 2012 3:23 pm    Post subject: Reply with quote
I would start your own thread to not confuse folks with Todd's truck, which just prompted me to go back and see if he sold it to you.
Good luck!
Jack
Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth.
bigbulli
bigbulli is offline
PostPosted: Tue Jan 22, 2013 7:11 am    Post subject: Reply with quote
bigbulli wrote:
Couple old pics from bigbulli.com
Update 24 NOV 2001
"The single cab has landed. Mark Rafferty and I went to Miami last Friday. What a joke we spent 7 hours in customs, you have to show a passport to prove that you are a US citizen. I don't even have a passport but, we got it back ok. The bus is in better shape than I thought it would be! "
Just adding a pic as the old one got deleted....
1954 Barndoor
1955 Oval
gatorwyatt
gatorwyatt is offline
PostPosted: Thu Sep 12, 2013 6:59 am    Post subject: Reply with quote
www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine
buck
buck is offline
PostPosted: Thu Sep 12, 2013 8:16 am    Post subject: Reply with quote
Nice !
gatorwyatt
PostPosted: Thu Sep 12, 2013 10:14 am    Post subject: Reply with quote
www.blastserv.com
wanted:
Barndoor Mafia
Il Capo
Barndoor Mafia is offline
PostPosted: Thu Sep 12, 2013 11:08 am    Post subject: Reply with quote
Damn Todd! Gonna have to start calling you the CHUCK D of Florida Wink
djfordmanjack
djfordmanjack is offline
PostPosted: Thu Sep 12, 2013 1:25 pm    Post subject: Reply with quote
great corner welding, thats the way to do it !
62 Dickholmer, custom color Seeblau L360
bigbulli
bigbulli is offline
PostPosted: Tue Sep 24, 2013 11:15 am    Post subject: Reply with quote
Great work Cool
1954 Barndoor
1955 Oval
zuggbug
zuggbug is offline
PostPosted: Fri Sep 27, 2013 8:04 pm    Post subject: Reply with quote
Very nice. Glad to see you making progress
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
rusty69911
rusty69911 is offline
PostPosted: Mon Dec 30, 2013 12:53 am    Post subject: Reply with quote
I actually helped my mate Ken retrieve that SC down in Albany,
it was aussie delivered,
nearly all RHD of any manufacturer came as UK spec
due to the limited market in OZ,
I have always been a vw nut but was not that into Kombi's back then,
I couldnt afford the $8k Aussie that he got for it (exchange rate was pretty good then around 70c to the dollar),
seemed too high for me haha, silly boy I was,
glad to see it getting some love,
looking like getting my first split very soon if a deal pans out well,
cheers Russ...
RidinRusty
RidinRusty is offline
PostPosted: Mon Dec 30, 2013 8:14 pm    Post subject: Reply with quote
Wow Todd great work!
55 DD panel PBR
96 993 C4
bigbulli
bigbulli is offline
PostPosted: Sun Sep 13, 2015 10:19 am    Post subject: Reply with quote
Any updates?
1954 Barndoor
1955 Oval
gatorwyatt
PostPosted: Tue Sep 15, 2015 6:07 am    Post subject: Reply with quote
Had to remove the original bushings for the upper shock mounts because the bolts were cross threaded and coarse thread all thread.
Had new bushings made and welded in by a local machine shop friend. Yes, the detail for the original upper shock lock washer in the outer portion was missed. Oh well.
Original / glass bead
Ballotini glass beads in AE grade provide this type surface. No they were not " vapor blasted"
Powder coated in satin black
Yellow zinc / clear zinc / black nickel plating
After boiling in transmission fluid I got the Pistons to come out and the original cylinders had some minor pitting. I honed the pits clean and found some rubber kits on eBay.
Plated in yellow zinc while I was at it.
This is a fun fact. After different cross matching part numbers the front shoes for barndoor brakes are the same as Porsche 944 for the late 70's to early 80's rear. One hole needs to be drilled for a spring but other than that they fit.
www.blastserv.com
wanted:
Barndoor Mafia
Il Capo
PostPosted: Tue Sep 15, 2015 8:17 am    Post subject: Reply with quote
WOW TODD!!!! You are the man!! Wink
PostPosted: Tue Sep 15, 2015 9:12 am    Post subject: Reply with quote
Super nice!
scvw
scvw is offline
PostPosted: Tue Sep 15, 2015 9:21 am    Post subject: Reply with quote
Todd I like the way you do parts.
58 Coral Red ragtop(Diana's car)
57 PG/SG standard
63 Ruby Red SC
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775
WOB1
WOB1 is offline
PostPosted: Tue Sep 15, 2015 1:53 pm    Post subject: Reply with quote
Wow nice!
Which brake cylinders did you use?
gatorwyatt
PostPosted: Tue Sep 15, 2015 5:06 pm    Post subject: Reply with quote
As always, thank you for your kind remarks , Joey. My anal retentivness is disgusting to myself, first and foremost.
www.blastserv.com
wanted:
gatorwyatt
PostPosted: Tue Sep 15, 2015 5:07 pm    Post subject: Reply with quote
WOB1 wrote:
Wow nice!
These were original wheel cylinders from the bus. ATE brand...
www.blastserv.com
wanted:
Page 7 of 16
