splipete Samba Member
Joined: January 17, 2012 Posts: 12 Location: Somerset UK
Posted: Sat Dec 29, 2012 1:11 pm Post subject: |
Nothing much been said on this subject for a while but as this is where I mentioned my 54 Sc before, I thought I'd post here.(someone tell me if I should start a new thread!)
I'm going to be making a start on the resto soon and I'm stuck which way to go.
As I've said the truck started life as a LHD but somehere way back was converted to RHD.
If I'm going to invest a load of time and money do I change it back to LHD or leave it like it is and accept that is part of the history?
If I leave it RHD is there any point aiming for that 100point stock show winning finish or is the truck always going to be looked on as non-original?
In that case do I slam it and chuck in that big motor I've always wanted and not worry about destroying a rare truck? |
derv Samba Member
Joined: October 12, 2005 Posts: 2600 Location: Oak Park (Chicago), IL
Posted: Sat Dec 29, 2012 3:23 pm Post subject: |
I would start your own thread to not confuse folks with Todd's truck, which just prompted me to go back and see if he sold it to you.
Good luck! _________________ Jack
Quote: |
Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth. |
bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Tue Jan 22, 2013 7:11 am Post subject: |
bigbulli wrote: |
Couple old pics from bigbulli.com
Update 24 NOV 2001
"The single cab has landed. Mark Rafferty and I went to Miami last Friday. What a joke we spent 7 hours in customs, you have to show a passport to prove that you are a US citizen. I don't even have a passport but, we got it back ok. The bus is in better shape than I thought it would be! " |
Just adding a pic as the old one got deleted....
_________________ 1954 Barndoor
1955 Oval |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Thu Sep 12, 2013 6:59 am Post subject: |
_________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
buck Samba Member
Posted: Thu Sep 12, 2013 8:16 am Post subject: |
Nice ! |
Posted: Thu Sep 12, 2013 10:14 am Post subject: |
wanted:
Barndoor Mafia Il Capo
Joined: August 23, 2001 Posts: 6194 Location: EUSKAL HERRIA
Posted: Thu Sep 12, 2013 11:08 am Post subject: |
Damn Todd! Gonna have to start calling you the CHUCK D of Florida |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2179 Location: Graz, Austria, Europe
Posted: Tue Sep 24, 2013 11:15 am Post subject: |
Great work _________________ 1954 Barndoor
1955 Oval |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Fri Sep 27, 2013 8:04 pm Post subject: |
Very nice. Glad to see you making progress _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
rusty69911 Samba Member
Joined: January 18, 2012 Posts: 6 Location: West Australia
Posted: Mon Dec 30, 2013 12:53 am Post subject: |
I actually helped my mate Ken retrieve that SC down in Albany,
it was aussie delivered,
nearly all RHD of any manufacturer came as UK spec
due to the limited market in OZ,
I have always been a vw nut but was not that into Kombi's back then,
I couldnt afford the $8k Aussie that he got for it (exchange rate was pretty good then around 70c to the dollar),
seemed too high for me haha, silly boy I was,
glad to see it getting some love,
looking like getting my first split very soon if a deal pans out well,
cheers Russ... |
RidinRusty Samba Member
Joined: April 02, 2011 Posts: 265 Location: Florida/Montana
Posted: Mon Dec 30, 2013 8:14 pm Post subject: |
Wow Todd great work! _________________ 55 DD panel PBR
96 993 C4 |
Posted: Sun Sep 13, 2015 10:19 am Post subject: |
Any updates? _________________ 1954 Barndoor
1955 Oval |
Posted: Tue Sep 15, 2015 6:07 am Post subject: |
Had to remove the original bushings for the upper shock mounts because the bolts were cross threaded and coarse thread all thread.
Had new bushings made and welded in by a local machine shop friend. Yes, the detail for the original upper shock lock washer in the outer portion was missed. Oh well.
Original / glass bead
Ballotini glass beads in AE grade provide this type surface. No they were not " vapor blasted"
Powder coated in satin black
Yellow zinc / clear zinc / black nickel plating
After boiling in transmission fluid I got the Pistons to come out and the original cylinders had some minor pitting. I honed the pits clean and found some rubber kits on eBay.
Plated in yellow zinc while I was at it.
This is a fun fact. After different cross matching part numbers the front shoes for barndoor brakes are the same as Porsche 944 for the late 70's to early 80's rear. One hole needs to be drilled for a spring but other than that they fit.
wanted:
Posted: Tue Sep 15, 2015 8:17 am Post subject: |
WOW TODD!!!! You are the man!! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69832 Location: Phoenix Metro
scvw Samba Member
Joined: September 02, 2006 Posts: 3544 Location: South Carolina
WOB1 Samba Member
Joined: January 11, 2006 Posts: 176 Location: Austria
Posted: Tue Sep 15, 2015 1:53 pm Post subject: |
Wow nice!
Which brake cylinders did you use? |
Posted: Tue Sep 15, 2015 5:06 pm Post subject: |
scvw wrote: |
Todd I like the way you do parts. |
As always, thank you for your kind remarks , Joey. My anal retentivness is disgusting to myself, first and foremost. _________________ www.blastserv.com
wanted:
Posted: Tue Sep 15, 2015 5:07 pm Post subject: |
WOB1 wrote: |
Wow nice!
These were original wheel cylinders from the bus. ATE brand... _________________ www.blastserv.com
wanted:
