Fishynos72 Samba Member
Posted: Fri Aug 10, 2012 11:31 pm Post subject: Matra Tools w/photos |
The time has come for a Matra thread. There's quite a few treads that deal with individual tools, so for the sake of organization and ease, lets put it all in one spot.
For those who haven't seen it yet here's a list of the tools.
Lets make it our goal to have at least one photo of every tool to go with every description, not just the sounderwerkzeuge folder page
http://www.thesamba.com/vw/archives/info/tools1.php
I'll start things off
Stuff I use at work
313 support clamp
307 fixture (mounts to back of motor)
307a flywheel lock
207 piston pin pilot drift
165 socket for cylinder head nuts
161a Circlip pliers
159 Oil Pressure Switch Wrench
And here's my Matra tool box. It once belonged to my grandfather when he worked for Volkswagen in the 50's
I'll add more when i get the change, till then show us your collections _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2005 Caddy panel van
2006 Golf R32 |
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Mon Aug 13, 2012 1:40 pm Post subject: |
I like your 161a the best. Been looking for one for a couple years now. Very nice engine stand too. I'm waiting for my old german friend to 'kick the bucket' as he says. it's the only way I'll get his old stand and trolley with the seat that he sat his but on for 40 years _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
Posted: Mon Aug 13, 2012 3:15 pm Post subject: |
Thanks. Does anyone where the replaceable tips for those could be bought? _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10199 Location: Petaluma, CA
Posted: Tue Aug 14, 2012 8:20 am Post subject: |
Fishynos72 wrote: |
Thanks. Does anyone where the replaceable tips for those could be bought? |
I could use a set of those too, mine are worn beyond use. |
shady1955 Samba Member
Joined: April 03, 2011 Posts: 6 Location: Cornwall, UK
Posted: Fri Aug 17, 2012 7:10 am Post subject: |
campingbox wrote: |
Fishynos72 wrote: |
I could use a spare set myself
Here is some of my Matra collection
VW313 Fixture & VW307 engine Yoke (clearanced for 200m)
VW311h Valve extractor
VW310 Crankshaft fixture for early VW and porsche 356
VW202c Extractor ring
VW161a
VW131a (top) & VW133b
VW190 Type4 Fan side crankshaft seal
VW191 Type4 Flywheel side crankshaft seal
_________________ Stump Puller Project
Posted: Fri Aug 17, 2012 2:53 pm Post subject: |
A few more -
VW201 Oil pump extractor
VW203b Fan pulley extractor
VW202d Extractor hooks
VW202u Extractor hooks
VW202s Extractor hooks
VW202p Extractor plates
VW202f VW202i VW202k VW202 thrust pads
VW311s Valve spring compressing tool
VW311p (Additions to valve grinding hit VW311k)
Got some other Matra tools hidden away somewhere, will update as I find them. _________________ Stump Puller Project |
Posted: Fri Aug 17, 2012 4:19 pm Post subject: |
Wow, what a fantastic collection. Thanks for the photos _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
Posted: Fri Aug 17, 2012 5:49 pm Post subject: |
Here's a photo from Thursday's club meeting. I will post the numbers and uses for the tool when I have my computer _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Wed Aug 29, 2012 11:15 am Post subject: |
From a recent acquisition:
Guide Plate for 112a
VW Tool 758/1
Adapter for Steering Worm, Types 1, 2, 3
For making adjustments to the steering gear, in conjunction with a torque gauge
VW Tool 242
Ball Bearing Extractor
For removing reduction gear shaft inner ball bearing in reduction gear case of VW Transporters
VW Tool 223/1
Knuckle Pin Extractor
For removing the upper knuckle pin of VW Transporters
VW Tool 244
Driving Sleeve
For installing
- spacer for inner front wheel bearing,
- inner ball race of outer wheel bearing
VW Tool 223a
For removing the upper knuckle pin of VW Transporters, if VW 400 and corresponding tool set are not available
VW Tool 273b
Torsion Arm Bush Drift
For installing the torsion arm bushes in the front axle beams in VW Transporters
VW Tool 273a
For installing the torsion arm bushes and needle bearings in front axle beams in VW Passenger Cars
VW Tool 202nT
Extractor Plate
In conjunction with VW 202, VW 202d, and VW 202h, for removing the inner half of reduction gear case of VW Transporters
VW Tool 350
Retaining Plate with Measuring Equipment (automatic transmission)
For holding the final drive for assembly and for adjusting the ring gear
VW Tool 3090
Water boxer rod support tool for re-installing piston wrist pins.
VW Tool 249
Clamping Piece (automatic transmissions)
For checking the friction torque of the double tapered roller bearings of the drive pinion and the differential when used in conjunction with a torque gauge
VW Tool 182
Special Wrench (automatic transmission)
For adjusting
- ring gear
- preload of the pinion bearing
VW Tool 661/1
VW Tool 159
For removing and installing oil pressure switch
VW Tool 542
Guide for Bonded Rubber Mounting
For installation of the bonded rubber mountings in the front wishbones and the rear trailing arms (Dasher)
VW Tool 215c
Flywheel Retainer
For holding the flywheel with 130 teeth (outer dia. 276 mm) when loosening and tightening the gland nut, clutch bolts, and crankshaft pulley
VW Tool 276a
Lower Torsion Arm Extractor
For removing the lower torsion arm from the front axle beam in VW Type 3s
VW Tool 340
Tensioning device for coil springs - aka Strut spring compressor. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Thu Aug 30, 2012 12:59 am Post subject: |
ooh there's some sweet stuff there. i was looking through your adds the day before you posted. amazing collection of tools.
thanks for sharing _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
DanM Samba Member
Joined: June 07, 2002 Posts: 1330 Location: Falls Church, VA
Posted: Sat Sep 08, 2012 9:28 am Post subject: |
Had this box for a while, just sold it.
The box has the following stenciled on it:
VERS. NR. 5180-12-141-1427
WERKZEUGSATZ, VERBRENNUNGSMOTOR-
INSTANDSETZUNG ERH.-STUFE 3
MIT KASTEN
VW- INDUSTRIEMOTOR TYPE 122
The following tools are inside and still covered in cosmoline. All are MATRA unless otherwise noted as Peiseler.
vw1266 - 13mm fuel pump wrench
vw126a - 14mm fuel pump wrench
unmarked mystery tool (see below)
vw171 - cam follower holders (unopened)
vw204b - crankshaft oil seal installing tool
vw109 - oil cooler wrench
vw 328b (peiseler) - 36hp fuel pump preload tool
vw219 clutch centering tool / drift
vw201 - oil pump puller
vw215b - flywheel lock
vw 328d (peiseler) - 40hp fuel pump preload tool
vw112/3 - breaker bar
vw112/2 - flywheel socket guide plate
vw112/1a - 36mm flywheel socket
here's a close-up of the "mystery tool". Anybody know what it is?
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Sat Sep 08, 2012 5:41 pm Post subject: |
Dan, that box was marked for industrial motor and the fixture might had been for a PTO in some way...cool kit nonetheless. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4576 Location: St Charles, MO
Posted: Thu Sep 13, 2012 9:52 am Post subject: |
A big "thank you" to DanM for the above NATO crate of Matra tools, I am the delighted new owner. They arrived this morning and I've already drooled all over the tools and the case! I actually already owned 9 of the 14 tools in this case, but these NOS tools in the original NATO crate were too nice to pass up. Dan did an awesome job of padding and packing everything up for a safe trip to my door. Thanks again Dan! Can't wait for the day that my 1956 Ziegler Fire Brigade water pump powered by a 1956 VW Industrial engine needs some work, and I get to scuff up the cosmoline on those tools!
Again, does anyone have any idea what that odd "mystery" tool is for?
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Thu Sep 13, 2012 10:02 am Post subject: |
Oh! I have a Matra #135 tool, looks like a pliers that would spread something apart. Does anyone have an old catalog that might explain the applications of a Matra #135 ??? Thanks! I'll try later to load up a photo to show the tool...
Ah! Here is a thread with photos of it I started a while back...
http://www.thesamba.com/vw/forum/viewtopic.php?t=487618&highlight=special+service+tool
Bill _________________ I'm looking for these license plate frames for my fleet:
Posted: Sat Sep 15, 2012 12:30 pm Post subject: |
I would like to know what this is for. It's some kind of jig. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Sat Sep 15, 2012 5:57 pm Post subject: |
Seeing as the number for the jig is so high, it's more likely for a water cooled car. Or its some strange tool used for factory reconditioning or something like that. If its recent enough you can contact Matra and they can tell you what its for. _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
Posted: Sun Sep 16, 2012 6:26 am Post subject: |
Fishynos72 wrote: |
Seeing as the number for the jig is so high, it's more likely for a water cooled car. Or its some strange tool used for factory reconditioning or something like that. If its recent enough you can contact Matra and they can tell you what its for. |
It most likely is a jig for water cooled vehicles. I've searched for Matra's contact information but haven't found anything. I would appreciate any information anyone can provide. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Sun Sep 16, 2012 3:13 pm Post subject: |
Publisher MATRA-Werke GmbH
Management:
Ingo Rädisch,
Dieselstraße 6
Klaus Baumgärtel
63512 Hainburg
Registered office:
Hainburg
Fon: +49 (0) 6182 - 7833 - 5500
Register court:
Offenbach HRB 43982
Fax: +49 (0) 6182 - 7833 - 5501
From their website _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
lasslo Samba Member
Joined: September 01, 2004 Posts: 206 Location: sweden
Posted: Mon Sep 17, 2012 5:17 pm Post subject: MATRA |
Some of my MATRA tools
_________________ 65 DD klenbus
57 Karmann Ghia |
Posted: Tue Sep 18, 2012 1:11 am Post subject: |
Just picked this up on the weekend.
Not quite like the brochure but getting close _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
