AlteWagen Troll
Posted: Sat May 14, 2011 2:22 pm Post subject: Official 1960-1961 registry and restoration guide thread. |
Please post your BC info here and any specific build questions/comments.
Thanks TheSamba for making it easier for us to build correct cars and keeping them alive! |
AlteWagen Troll
Posted: Sat May 14, 2011 4:35 pm Post subject: |
Purchased in 1991 for $125, has over 300,000 miles with over 6 engines, and 3 transmissions since purchased.
Vin: 29090XX
Feb 1960
European delivery
L 436 Indigo Blue
Special features:
60-61 only 3 finger apron
came with 58-59 plastic visor which looked original to the car even though PR states it should be a padded one. Maybe different for euro spec. was different. Also had a 58-59 style wiring harness that also looked original to the car.
Entered U.S. as gray market so bumper over riders were installed and semaphores were leaded closed.
Sunroof was grafted in due to extensive roof damage (kids used it as a trampoline I guess) and what looks like a ton of hail damage which was repaired by PO with over an inch of bondo.
Still sporting its original black plates issued in 63.
AlteWagen Troll
AlteWagen Troll
potentvw Samba Member
Joined: April 13, 2004 Posts: 65 Location: Rusty east coast
Posted: Sat May 14, 2011 8:12 pm Post subject: |
Lots of great info here. I have not looked through everything yet, but in case its not known, early 60's had a 4 rib front apron, same as a 59. |
AlteWagen Troll
Posted: Sat May 14, 2011 10:44 pm Post subject: |
potentvw wrote: |
Correct. We are trying to find out the actual vin cut off for this, do you have a early 60 with a four finger apron? |
Zekes'Low60 Samba Member
Joined: October 22, 2004 Posts: 259 Location: Jackson Creek,NC
Posted: Sun May 15, 2011 9:26 am Post subject: |
My 60 has the 4 finger apron. Built Dec10, 59
Hard to see.....but it has 4.
Found an old pic when she was fresh out of the barn that show the 4 fingers.
_________________ 10 December 1959.... L41 VW De Luxe Sedan..."Christine"
62 'Vert basketcase....."Tetnus"
62 Dragcar/ProStreet project....."Muffdiver" |
AlteWagen Troll
Posted: Sun May 15, 2011 11:04 am Post subject: |
Thanks.
Wow your gas heater is mounted on the passenger side to boot! Any other accessories? What kind of visors do you have? |
Posted: Sun May 15, 2011 11:43 am Post subject: |
Padded visors. Has the round VDO gas gauge but missing the sender. Tank got changed out and I guess the sender went with the old one.
I had taken the heater out but it leaves an ugly hole so I put it back in. _________________ 10 December 1959.... L41 VW De Luxe Sedan..."Christine"
AlteWagen Troll
Posted: Sun May 15, 2011 12:03 pm Post subject: |
Would you mind posting pics of your gauge, there seem to be different dash grills that were used. One with the slots surrounding the gauge and the other one with straight cut off slots. Do you know if it was a dealer install or factory? BC? |
Posted: Sun May 15, 2011 12:28 pm Post subject: |
Not sure about the gauge but Im thinking dealer install maybe?????
Steering wheel isnt correct....horn ring hoop isnt broke off....never was one and wheel doesnt have cut out for it.
BC
AlteWagen Troll
Posted: Sun May 15, 2011 12:39 pm Post subject: |
Zekes'Low60 wrote: |
Not sure about the gauge but Im thinking dealer install maybe????? |
The only way to tell dealer vs. factory is with a BC. Here is my gauge that I pulled off an early 61
My car is a 60 I just couldnt get all the steering wheel parts together so I slapped on a 59 wheel and column I had.
Thanks for the info! |
Joined: April 27, 2002 Posts: 6375 Location: Pentwater, Michigan
Posted: Sun May 15, 2011 12:52 pm Post subject: |
I've owned this beetle for 22 years now. Purchased in Lake Arrowhead for $680. Built 13 January 1961. Delivered to the USA.
It has a three finger front apron
screw terminal wiring
no foot rest
had a plastic plug in the dash for a choke cable now running a 36 hp.
red handled oil dip stick
H rear apron
vertical door handle keyway
1960 type turn signal switch
I believe it is an original sunroof although the birth cert does not indicate this. I base this on my last headlner install. The OG color was Pearl white it was green when I got it. _________________ Roads Scholar &
stale air Samba Member
Joined: August 23, 2007 Posts: 5163 Location: Senoia Ga, formally NorCal
Posted: Sun May 15, 2011 1:01 pm Post subject: |
derluftwagen wrote: |
Fyi, according to the plate number is was originally registered out of Hathorne Ca. _________________ WANTED: Henry Veale Santa Rosa plate frames
AlteWagen Troll
Posted: Sun May 15, 2011 1:34 pm Post subject: |
This is exactly what I am talking about, many "60 only" features on a mid year 61.
Could you please post you vin so I can add it to the registry and we can narrow down the actual cut off for the various listings?
Thanks |
Posted: Sun May 15, 2011 2:56 pm Post subject: |
vin # 3 591 436
honestly some things like door handles, turn signals and dip stick are very easy to change. Others like the lack of a foot well and aprons and wiring would be dificult to change. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
AlteWagen Troll
Posted: Sun May 15, 2011 3:06 pm Post subject: |
tasb wrote: |
Others like the lack of a foot well and aprons and wiring would be dificult to change. |
Do you mean the foot rest? I had to put one in on mine due to the 61 up rubber mat I got at a swap. What I found strange is my 60 already had the slot for the foot rest tab in the firewall stamping.
BTW thanks for the vin |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sun May 15, 2011 3:21 pm Post subject: |
My 60 has a passenger foot rest. built Jan 60 _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Posted: Sun May 15, 2011 3:38 pm Post subject: |
Not sure if mine came with a footrest but it has the slot. _________________ 10 December 1959.... L41 VW De Luxe Sedan..."Christine"
janerick3 Samba Member
Posted: Sun May 15, 2011 8:47 pm Post subject: |
tasb wrote: |
vin # 3 591 436
honestly some things like door handles, turn signals and dip stick are very easy to change. Others like the lack of a foot well and aprons and wiring would be dificult to change. |
We owned #3509444 from '66 to '71 and it had all of the '61 features, but still had the 4-tab hood. I'm guessing your car was rolled early in its life and the og '61 hardtop body was swapped out for a '60 ragtop body. _________________ Thanks,
Jan K. |
