earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Oct 23, 2010 10:35 am Post subject: 36hp barrel spacers, any body need them? |
Does any body need barrel spacers for there 36hp motors? I run a water jet machine where I work and pretty much have a free time to use it for myself. I have allready made some barrel spacers for 94mm jugs and can make them any diameter that you would need, the only problem is I work with std. gauge sheet metal so if you want a set of .060" spacers they will probably wind up being .058", I can usually get close + or- .002".
Here a pic of one I made for 94mm, The one on the right is a Bugpac for comparison, but I made them a little wider then normal, I could make them any width you need.
I'm also working on a Porsche style look a like round oil sump.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Sat Oct 23, 2010 10:54 am Post subject: |
Here a picture of what I have so far for the sump...
I just need to find some 10" aluminum tubing or I might have to roll my own, It will have the grooves cut on the sides, The bottom might wind up being flat I don't know yet, but it will bolt on.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
