Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1777 Location: Finland, Jakobstad
Posted: Mon Jun 01, 2009 2:45 pm Post subject: The 1966 Geländewagen type-51 |
The wife bought this the past weekend. Maybe she got tired over my never ending projects...
The car is kind of a "barnfind" as it have been sitting the past 27 years unregistered in a heated garage. The seller decided to register it this spring without any problem. All he did was replace the front brakehoses, buy new 6V battery and new tires.
_________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD |
Derek Cobb Annoying
Posted: Mon Jun 01, 2009 3:19 pm Post subject: |
Beautiful! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77119 Location: Sneaking up behind you
Posted: Mon Jun 01, 2009 3:21 pm Post subject: |
Very clean.
Will you marry me? (only if you buy me a nice car like that ). _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
54ovsemi Samba Member
Posted: Mon Jun 01, 2009 3:24 pm Post subject: |
I Likes it... And your Avatar too.. |
FRK Samba Member
Joined: December 09, 2002 Posts: 2654 Location: Orange county, CA
Island_Girl Samba Member
Joined: February 10, 2009 Posts: 137 Location: Vancouver, BC
Posted: Mon Jun 01, 2009 5:53 pm Post subject: |
She's a beaut! Where can I find a heated barn? _________________ '68 White Bug
Finally back down to one manageable car :S |
iaccy Samba Member
Posted: Fri Oct 30, 2009 4:20 pm Post subject: |
This winter I will have to pull the engine and do an overhaul as it started to smoke blue smoke. I hope it is just the sealrings on the pistons as the engine had been sitting in the warm garage for so long.. Also the heads will be redone at the same time.
I will also replace the rest of the brakelines that the previous owner didn't replace.
And the body will most likely be repainted in Seesand L568... _________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
Posted: Mon Feb 15, 2010 12:51 pm Post subject: |
Pulled the engine in January as it needed an overhaul. Turned out to need a major one... Pulled the pulley and it had 1,6mm of endplay...
Decided to use my spare 1680cc type-3 engine for it instead.
Here all finished and waiting for some kind of carburation, yet not decided...
The leftside frontfender had bumped into something during the cars life and had a major bend on the top from the turnsignal and down to the wheel arch. Needed to be hammered out.
This weekend I decided to test out the new colour. Seesand on the front fender.
The brakehoses did fail (42 years old hoses...) last summer I had to crawl under this car for the first time and was able to check the pan closer the past weekend..
Not much done here and even less do do there...
Just replaced the brakehoses and pipes. Still need to replace the fuel hoses too.
The Hebster52
The 912ST
The KidVRod project
AJ Quick Samba Member
Joined: July 20, 2006 Posts: 539 Location: Minnetonka, MN
Posted: Sun Mar 07, 2010 3:06 pm Post subject: |
AJ Quick wrote: |
Awesome car! One of the nicest condition cars I have seen... not bad for sitting around for 27 years.
I would have kept it all original paint, but its your car.. so go nuts! |
Thanks! So would I but the PO had repainted it because "the paint looked so scratched..."
He did re repaint himself and didn't spray enough on it so when we bought it last year I spent 3 days on sanding the paint and rubbing it up to some kind of gloss... _________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
LosCreepers Samba Member
Joined: November 05, 2009 Posts: 83 Location: The Netherlands
Posted: Sun Mar 07, 2010 4:27 pm Post subject: |
Nice car!
I always wonder where you guys find cars like these, sitting in barns/garages for most of their lifes.
Did you pull out those hideous seatcovers (post #1, last pic) or what? _________________ www . b u g p e o p l e . nl |
Posted: Wed Mar 10, 2010 9:00 am Post subject: |
This one happened to pop up in the for sale ads in the local newpaper. I just was fast enough to react on it this time..
Yes, those seatcovers were the first thing to come out. Unfortunately the passangerside seat had a minor blemish in the cloth..
Also had to replace one hingepin on the driverside. Just needed to make a tool for that. Thanks to photos found here in the gallery it was easy to make.
Here's an other photo of the engine with the aircleaners mocked up on the carbs.
The Hebster52
The 912ST
The KidVRod project
66busman Samba Motorcyclist
Joined: September 14, 2006 Posts: 1166 Location: Madison, Wisconsin
Posted: Wed Mar 10, 2010 9:17 am Post subject: |
I'm curious to see what type of linkage setup you use with those carbs. I have a nearly identical setup to put in my bus (sp rather than dp), so I'm watching. Hurray for 1966's! _________________ '66 SO-42
'73 Bay
'75 Type 181 |
^RAGE^ Samba Member
Joined: November 16, 2009 Posts: 16 Location: kent/uk
Posted: Wed Mar 10, 2010 2:32 pm Post subject: |
very nice very nice indeed . good work
RAGE _________________ Click to view image |
estofer Samba Member
Joined: November 25, 2004 Posts: 867 Location: Lawrence, Kansas
Posted: Wed Mar 10, 2010 4:06 pm Post subject: |
Nice bug!! _________________ 1964 Type 1 Vert "Ruby"
2019 Tiguan
2020 Tiguan |
