arrowz Samba Member
Posted: Wed Dec 27, 2006 1:03 pm Post subject: Particular question about setting Valves. Please Help! |
*note: I have been strickened with this annoying habit of being a perfectionist, so here goes:
While adjusting valves, when tighting the screw onto the valve, Do you want the feeler gauge to be tight in the correct position, or do you want to just barely feel the screw scrape against the feeler gauge? I have spent too much time trying to figure this out!! Ha. Thanks |
Randy in Maine Samba Member
Posted: Wed Dec 27, 2006 1:14 pm Post subject: Re: Particular question about setting Valves. Please Help! |
arrowz wrote: |
you want to just barely feel the screw scrape against the feeler gauge. |
The answer was in your post! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77036 Location: Sneaking up behind you
Posted: Wed Dec 27, 2006 1:14 pm Post subject: |
You should get a "go / nogo" feller gauge. They have a step so the tip is .006" and the rest is .008". You want it to move on the .006" but not be able to get the .008" in there.
Don't get too nuts, just check them every 3000 miles or twice a year. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
A.J.Sims Banned
Joined: December 11, 2003 Posts: 1016 Location: LowBugget.com 982 N Batavia A4 Orange Ca 92867
Posted: Wed Dec 27, 2006 1:31 pm Post subject: |
get a air gauge. then set at 0.0" lash!
set your valve lash at 0.0" lash at the coldest time and check in 3,000 miles. you will not need to adjust in 3,000miles. _________________ Have tech questions? Need real help? Give us a call.
www.Lowbugget.com
982 North Batavia A4, Orange Ca 92867.
68 drag bug 1915cc 10.50's @130mph
66 fastback 2387cc turbo street car
67 baja 2054cc turbo. |
bugsterkafer Samba Member
Joined: October 04, 2004 Posts: 131 Location: Geneva, Switzerland
Posted: Wed Dec 27, 2006 1:36 pm Post subject: |
You mean 0 lash for stock pushrods?
I thought it was only for chromoly pushrods..?
Leo |
A.J.Sims Banned
Posted: Wed Dec 27, 2006 2:02 pm Post subject: |
Yes stock. Just set at the coldest time of the day when the motor is cold.
if you drive your car at 4am then set the valve lash at that time so the motor will never see a colder time. if it gets colder say normal of 60* and now its 30* than re set. _________________ Have tech questions? Need real help? Give us a call.
www.Lowbugget.com
Posted: Wed Dec 27, 2006 3:07 pm Post subject: |
Okay thanks for the tip
Leo |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Dec 28, 2006 12:25 am Post subject: |
Hey A.J., want to fly out to Iowa and adjust my valves for me on OUR coldest day (record is -27F)? _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
