askSTEEVESdtcom Samba Member
Posted: Tue Dec 26, 2006 12:28 pm Post subject: adjustible beam and drop spindles |
do i have to put an adjustible beam on my 71 ghia if i am going to put drop spindles on it? Will the tires rub the car if i dont use at least a 2 inch narrowed beam or can i use the stock beam? i am only doing a 2 inch drop with the spindles.
thanks |
hpw Samba Member
KPottorff Samba Member
Posted: Tue Dec 26, 2006 3:07 pm Post subject: |
I would bet that a narrower axle would be necessary. The fit of the stock tire is kind of tight to begin with and going lower would probably cause rubbing on the top of the sidewalls. I would also bet even money that wider wheel / tire combos would only make things worse.
I think the real question is how to determine how much narrower the axle needs to be. I've seen articles in the VW mags on how to put in the axles but they rarely mention how to determine the axle dimensions. |
karmann57 Samba Member
Joined: October 22, 2004 Posts: 705 Location: Airdrie, Alberta
Posted: Wed Dec 27, 2006 9:05 am Post subject: |
If you want to run a stock size or wider tire, or wheels that are wider than stock or with a different offset then I would suggest looking into a narrowed beam. If you want to run a smaller tire (ie 135/15) then you should be able to get away with a stock width beam.
Don't use adjusters in addition to the drop spindles unless you want to go really low. If you do go with a narrowed beam most will come with adjusters already, set it as high as it will go and you can always lower it if you feel it necessary.
Shane |
Posted: Wed Dec 27, 2006 9:59 am Post subject: |
thanks for the responses everyone i think i will be getting the narrowed beam then just to be sure of no issues. |
