Jrmobb55 Samba Member
Joined: July 10, 2003 Posts: 126 Location: southern california
Posted: Wed Sep 17, 2003 10:56 pm Post subject: ball joint conversion |
How Hard is it to convert to link pin from ball joint? _________________ 1974 white bug, 1741 engine |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Thu Sep 18, 2003 6:57 am Post subject: |
I am about to do this very thing...
You have to get a Link pin front end obviously, with the frame head...
then you basically cut the frame head off the car and weld the Link pin frame head on...
Make sure everything is lined up perfectly because if it's off by an inch at the weld, it'll be off by a mile at the wheels...
Good Luck! |
zach_camaro Samba Member
Posted: Sat Sep 27, 2003 8:41 am Post subject: |
what exactly is the difference in how a link pin and balljoint front end mount? I haven't ever seen a link pin front end up close but I have a balljoint. Are the 2 beams farther apart or closer together? |
BigElipso Samba Member
Joined: May 19, 2003 Posts: 289 Location: West Michigan
Posted: Sat Sep 27, 2003 3:50 pm Post subject: |
Ball joint beams are farther apart. |
Daily Driver Bajabug Guy Samba Member
Joined: July 17, 2003 Posts: 37 Location: Southern California, Inland Empire.
Posted: Sat Sep 27, 2003 9:00 pm Post subject: ball joint conversion |
I just wrote a little article on how I went about the conversion
You can read it here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=52321
...just scroll down to my post _________________ 1963 Body on 1973 Pan - 1600 DP - Linkpin/IRS with no bump stops |
Posted: Sun Sep 28, 2003 6:05 pm Post subject: |
what's the difference between how ball joint and link pin trailing arms bolt to the leafs? When using through rods can you mount link pin trailing arms in a ball joint beam? |
