Gman73 Samba Member
Joined: April 25, 2018 Posts: 79 Location: Spotsylvania, VA
Posted: Sun Apr 28, 2024 12:22 pm Post subject: Re: What did you do to your Bug Today? |
OTTO 1303 wrote: |
Gman73 wrote: |
oh yeah... also fitted a bus shifter in the SB. its ridiculous
I’d like to do same
How do you like it? |
I'm okay with it. I takes a little getting used to it, the wife said she could get used to it. also has the short shifter spacer in it. |
BCE56 Samba Member
Posted: Sun May 05, 2024 6:19 pm Post subject: Re: What did you do to your Bug Today? |
It was clear and breezy this morning after last night's showers.
Checked Frankenbug's plug wires. Filed the points and scraped rotor & cap terminals.
Put 20 bucks' worth of premium in the tank and drove to the Esplanade.
Drivability noticeably improved. Off-idle flat spot is nearly gone.
One of these days I will do a real tune-up... _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
swede-german2 Samba Member
Posted: Sun May 05, 2024 9:08 pm Post subject: Re: What did you do to your Bug Today? |
Almost got through replacing the padded dash today; the rain kept me from totally finishing the job. All that's left is getting the glove box area done. It was pretty straightforward, just tedious. _________________ '69 Bug (stock daily driver)
'66 Bug (a field rescue nightmare)
'65 Bug (in a state of disarray!)
'64 Bug (in progress)
'74 MILF (upgraded to MIF in '02) |
PiperFixer Samba Member
Posted: Mon May 06, 2024 5:52 am Post subject: Re: What did you do to your Bug Today? |
New coil and plug wires.
New SVDA from Sparxwerks. Timed correctly this car runs well and has pickup now! I still have a little off idle hesitation which is probably from the POS no name carb that the PO installed. I tried to tune it but it really doesn't want to behave. I'm guessing this air cleaner setup isn't helping either.
Tried to do a valve adjustment and most of the screws are absolutely frozen. Luckily all but two intakes were pretty close to being at .006. New set of adjustment screws ordered... onward. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31472 Location: Hot Arizona
Posted: Mon May 06, 2024 6:34 am Post subject: Re: What did you do to your Bug Today? |
Connect breather hose near oil fill cap to underside of your air cleaner.
Keep spark plug wires away from the manifold, use the little clips to hold up on the fan shroud. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon May 06, 2024 7:25 am Post subject: Re: What did you do to your Bug Today? |
Cusser wrote: |
Keep spark plug wires away from the manifold, use the little clips to hold up on the fan shroud. |
New breather hose is on the list. The clips are broken on the shroud unfortunately. I took the pic before I zip tied things a little more securely. |
Cusser Samba Member
Posted: Mon May 06, 2024 1:21 pm Post subject: Re: What did you do to your Bug Today? |
Sweet, thanks! |
SemperVivus Samba Member
Posted: Mon May 06, 2024 9:43 pm Post subject: Re: What did you do to your Bug Today? |
1.) Adjusted the valves to .006
2.) Flushed and changed the oil with Rotella T6 15-W40
3.) Cleaned and changed oil on the oil bath air filter
4.) Adjusted the throttle cable (was only getting 75% open at WOT!)
5.) Removed the loose/bad crimp on spades on the coil, distributor ground and carb choke and added brass, open barrel crimp spades
Tomorrow is gear oil. |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 472 Location: Canadian Rockies
Posted: Thu May 09, 2024 7:40 am Post subject: Re: What did you do to your Bug Today? |
Over the last few weeks I got some much needed work done on the Bug before bringing it out of hibernation. I removed the fuel tank and used the POR 15 gas tank repair kit as per the directions. I actually let the tank liner dry for 7 days while I did other work. It looks pretty good, but I'll pull the tank in the fall and see how it is holding up. I also put a new gasket between the tank and the body, but used some window seal material from the hardware store. Now my fuel gauge is not working, so I suspect I just need to ground the fuel tank.
I had way too much oil leaking from my rebuilt motor, so started chasing that. I suspected that the flywheel seal was leaking, so I replaced that.
When I was installing the engine, I noticed that the front driver side generator stand stud had almost backed out completely. The 13mm carb wrench came in handy here!
I've been struggling with leaking valve covers for quite a while. This time I used Gasgacinch to seal the 4mm cork gaskets to spotless original flat valve covers. I made sure the head surface was completely dry/clean and installed the covers with dry cork, no grease or oil.
I replaced my NGK B6HS plugs with a fresh set, adjusted valves(so much better with the engine out), set points with dwell meter, and set the timing.
Currently, the Bug is running better than it has in my 6 years of ownership! At the moment it is not leaking any oil. Did I just jinx myself? I need to take it out for a long highway rip just to make sure, but it sure is nice have it back out on the road again! _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
benntn Samba Member
Posted: Fri May 10, 2024 9:55 pm Post subject: Re: What did you do to your Bug Today? |
Took out the engine and removed the tar board. Cars been sitting since 2006.
I'm ready to start getting her ready for the road again. Going to clean it up, fix some wiring, change some gaskets, replace or add some missing tins, put a new manifold and carb. I removed the dual carbs and I'm going back to stock. I hated them, they were a PITA.
Rome Samba Member
Joined: June 02, 2004 Posts: 9712 Location: Pearl River, NY
Posted: Fri May 10, 2024 10:37 pm Post subject: Re: What did you do to your Bug Today? |
Quote: |
I removed the dual carbs and I'm going back to stock. I hated them, they were a PITA. |
What type of dual carbs did you use? |
benntn Samba Member
Posted: Sat May 11, 2024 6:34 am Post subject: Re: What did you do to your Bug Today? |
Rome wrote: |
Solex H40/44eis Brosol
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 956 Location: Sacramento, CA
Posted: Sat May 11, 2024 3:02 pm Post subject: Re: What did you do to your Bug Today? |
Got my bug ready for a road trip to Santa Cruz next Sunday. Adjusted valves,(they weren't bad at all) brakes and clutch. Replaced my 009 distributor with the correct dual diaphragm distributor. Set timing at 5* atdc (with vacuum disconnected and plugged). Checked at 3500 RPMs and it is at 29* atdc. Took for drive to warm it up and adjusted carb. Took for a test drive and it runs nice and smooth with no flat spot. An easy 75 mph on the highway.
Looking forward to our vacation to the coast. |
Phydous Samba Member
Posted: Sat May 11, 2024 5:35 pm Post subject: Re: What did you do to your Bug Today? |
Weather is finally warm here in Northern Utah...
I checked the oil level, then went for about an hour drive around Layton/Kaysville area.
Super nice day! |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 651 Location: Louisiana
Posted: Sat May 11, 2024 8:00 pm Post subject: Re: What did you do to your Bug Today? |
Completed stripping of framehead and underside of spare tire well with oven cleaner and pressure washer.
All rust buffed away and/or treated with OSPHO.
Primed all bare metal. Undercoated bottom of spare tire well and painted framehead.
_________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Posted: Tue May 14, 2024 7:32 am Post subject: Re: What did you do to your Bug Today? |
Attempted first valve adjustment. Screws were frozen so I pulled the rockers and cleaned it all up. New adjusters and spring washers. Here's 1-2. 3-4 will be next.
Cusser Samba Member
Posted: Tue May 14, 2024 4:33 pm Post subject: Re: What did you do to your Bug Today? |
I silicone-glued a loose piece of piping into place, and also glued some carpet that had come loose by the rear window. I also added a home-made "fix" to the driver door striker, and filled up the VW with gas on my trip into town to run errands.
There's a brand-new store that opened today, called Falling Prices. Tuesdays EVERYTHING is $6, Wed. all $4, Thursdays all $2, Fridays all $1, and Saturdays all 25 cents. I imagine the place will be mobbed Friday and Saturday.
Apparently every Monday they re-stock with new closeout items. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
stagewex Samba Member
Joined: November 17, 2021 Posts: 168 Location: New Rochelle, New York
Posted: Fri May 17, 2024 5:28 am Post subject: Re: What did you do to your Bug Today? |
I don't mind the freckles (rust) here-and-there on the bright work but these reproduction "chrome" peashooters really deteriorated pretty quickly.
Less than 2 years old, really terrible quality.
I don't know why I just didn't buy the stainless-steel one's in the first place? They sound better too.
MountainBeetle Samba Member
Joined: October 23, 2022 Posts: 36 Location: Edinburgh
Posted: Fri May 17, 2024 7:29 am Post subject: Re: What did you do to your Bug Today? |
With a 3ft long inspection camera, I found the missing aerial housing/surround in the hardest-to-reach area of the Beetle, in the diminishing channel between the cabin and the wheel arch.
