wrxnofx Samba Member
Joined: July 06, 2022 Posts: 243 Location: Richfield, MN
Posted: Sat Apr 27, 2024 5:36 pm Post subject: Original Shift Rod Bushing Looks Great - Replace It? |
The existing (original?) rear shift rod bushing in my bus looks great. No wear that I can see. Do I replace it since I’m in here or is the old stuff better? The new one seems garbage - the circular tab thingy is too large for the shaft hole so would need to be modified to get it to fit.
The front one absolutely has wear so I will be replacing that one… _________________ 1977 VW Type 2 Bay Window Westy FI |
RWK Samba Member
Posted: Sun Apr 28, 2024 6:15 am Post subject: Re: Original Shift Rod Bushing Looks Great - Replace It? |
I had a fit problem with replacement ones, seemed to small to go around shift rod. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17018 Location: San Diego, California
Posted: Sun Apr 28, 2024 8:02 am Post subject: Re: Original Shift Rod Bushing Looks Great - Replace It? |
The birdies have plastic tits on the inside. These tits fit into drilled holes in the rod. I’ve had to modify the tits at times for better fit and then use channel locks to squeeze them in. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun Apr 28, 2024 10:30 am Post subject: Re: Original Shift Rod Bushing Looks Great - Replace It? |
I, too, discovered the fitment of the tits. Like you, I squeezed them down into the hole.
I guess what I’m asking is, is the quality of the original, unworn birdie better than a new one? _________________ 1977 VW Type 2 Bay Window Westy FI |
Posted: Sun Apr 28, 2024 11:26 am Post subject: Re: Original Shift Rod Bushing Looks Great - Replace It? |
On rigs with just the two birdies, I would added the third, but otherwise would live with the originals if they looked good. All the birdies do is keep the rod somewhat centered to keep it for vibrating against the steel tube. |
Posted: Mon Apr 29, 2024 10:42 am Post subject: Re: Original Shift Rod Bushing Looks Great - Replace It? |
Thanks for this guys! _________________ 1977 VW Type 2 Bay Window Westy FI |
