Emittim3 Samba Member
Posted: Wed May 18, 2022 7:43 pm Post subject: '02 Weekender -- best tires? |
In your opinion, what are the best tires for a 2002 Weekender?
Is there a specific speed rating on them that is recommended and/or sidewall stiffness? |
Tvättbjörn Samba Member
Posted: Wed May 18, 2022 10:08 pm Post subject: Re: '02 best tires? |
Go by the label on the car. Make sure to buy the high load rating tires according to the label on the van. Passenger tires are too weak and NOT safe to use on those heavy vans |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22687 Location: NYC/Upstate/ROW
Posted: Thu May 19, 2022 3:40 am Post subject: Re: '02 best tires? |
About half of the T4 in our local group of 30 use passenger tires. Despite the shrill chest beaters here, no issues.
It’s all about intended use. Easy driving around town , they are fine
85 on western freeways at rated load, no. _________________ .ssS! |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2800 Location: North Carolina
Posted: Thu May 19, 2022 4:01 am Post subject: Re: '02 best tires? |
I’m going to respectfully disagree Abs. Why not just get what is recommended with the proper rating?
Limited choices for me with the 15” wheels, but I went with General Grabber HDs and have been really happy with them. Quiet but beefy. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
gesoffen Samba Member
Joined: August 22, 2009 Posts: 139 Location: NoVA, USA
Posted: Thu May 19, 2022 9:16 am Post subject: Re: '02 best tires? |
Kumho Crugen HT51 are available with a 104 load rating (above the required load rating) in a 235/60R16 size. Slightly wider and taller than stock but within a few percent on both dimensions. They are also reasonably priced and generally available.
I have them on my '03 W/E with no issues.
https://www.tirerack.com/tires/tires.jsp?tireMake=...;tab=Sizes |
matics Samba Member
Joined: January 19, 2022 Posts: 25 Location: SF Bay Area
Posted: Thu May 19, 2022 11:55 am Post subject: Re: '02 best tires? |
gesoffen wrote: |
I have these on my new-to-me '03 Weekender. I'll likely need to replace 2 of them due to wear soon and will get the same. |
50Splitman Samba Member
Posted: Sat May 21, 2022 8:50 am Post subject: Re: '02 Weekender -- best tires? |
Been running the Vredsteins from Tirerack on my 02 Weekender for years with no issues. Quiet, handle nicely, and so far after 20K+ miles, they wear very well. PO had 98 load rated tires installed and the ride was soft and sloppy. Much improved with the proper load rated tires. Since I load up the van significantly, it was dangerous anyway to run 98 load rating tires (they were Firestone, FWIW). |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2544 Location: Ocean Beach in Beautiful BLUE California
Posted: Sat May 21, 2022 10:44 am Post subject: Re: '02 best tires? |
matics wrote: |
gesoffen wrote: |
Same here, very happy with the HT51s. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
smores Samba Member
Posted: Fri Jun 03, 2022 12:16 pm Post subject: Re: '02 best tires? |
Abscate wrote: |
85 on western freeways at rated load, no. |
I agree. On a weekender, which is much lighter than an EVC, passenger car tires of 92 load or so will be just fine. |
Posted: Fri Jun 03, 2022 6:24 pm Post subject: Re: '02 Weekender -- best tires? |
I’ll try to do a better job in 2025 remembering the T4 forum serves T4a, T4b, and EVC. _________________ .ssS! |
AlexandMary Samba Member
Posted: Thu Jun 09, 2022 6:31 am Post subject: Re: '02 Weekender -- best tires? |
Abscate wrote: |
I’ll try to do a better job in 2025 remembering the T4 forum serves T4a, T4b, and EVC. |
Steve. You are very where! |
murraybot Samba Member
Posted: Mon Apr 15, 2024 10:41 am Post subject: Re: '02 Weekender -- best tires? |
Can 235/60/16 be run on the stock 16” rims on later eurovans, or is the 235 too wide for the stock rim? |
paddygarcia Samba Member
Posted: Mon Apr 15, 2024 5:32 pm Post subject: Re: '02 Weekender -- best tires? |
I've been running Yokohama Geolanders in 235/60-15 quite successfully for 10k miles now. |
Posted: Tue Apr 16, 2024 4:01 am Post subject: Re: '02 Weekender -- best tires? |
Zero issues with running Kumho Crugen HT51 in a 235/60R16 size. |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 383 Location: Asheville, North Carolina
Posted: Tue Apr 16, 2024 4:12 am Post subject: Re: '02 Weekender -- best tires? |
Well...
Depends on what you're doing with the vehicle. I always recommend LT tires for Eurovans. Thicker sidewalls, better puncture resistance.
Here's the rundown on the differences.
https://www.discounttire.com/learn/passenger-vs-light-truck _________________ If it ain't broke, don't fix it! |
bigfoot_ev Samba Member
Joined: March 13, 2018 Posts: 160 Location: Anacortes, WA
Posted: Mon Apr 22, 2024 9:46 am Post subject: Re: '02 Weekender -- best tires? |
I used to run Yokohama Geolandar A/T-S, 235/60 16 with a 100 load rating on my Weekender. I really like this tire and it did well for winter driving and the occasional forest service road. No issues with it fitting. But when I needed new tires I had problems finding it with the proper load rating. I switched to Nokian Rotiiva AT 215/65. I felt having a little more weight on a slightly smaller contact patch was actually a good thing for my driving needs. The Nokian is another good option. |
Posted: Tue Apr 23, 2024 10:49 am Post subject: Re: '02 Weekender -- best tires? |
Thanks for the replies!
Ended up using a 215/65/16 Falken AT Trail - they look pretty nice. There are lots of good choices for high load tires in the that size. |
