Murt Samba Member
Joined: October 01, 2017 Posts: 311 Location: Kent, England
Posted: Fri Apr 19, 2024 1:36 am Post subject: Perspex cc measuring rings |
Hi Chaps
Can anyone help me with a quick question ?
I was going to buy a cc measuring kit, the 3 circles and the syringe. and I don't intend to pay £65 ($81)!!!!! for it, and would rather buy some ready cut Perspex circles over here in the UK.
Can anyone here who has a set, (Guessing 80.5/90.5/94 ??) tell me the exact diameters of the discs please
TIA
Dave _________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
modok Samba Member
Joined: October 30, 2009 Posts: 26823 Location: Colorado Springs
Posted: Fri Apr 19, 2024 4:40 am Post subject: Re: Perspex cc measuring rings |
it needs to be larger than the piston but smaller than the counterbore so it fits in the head.
slightly smaller than the top of the cylinder would be a good bet.
exact size?, not sure what an exact size is...., (I guess it's an imaginary concept.,.....?)
Didn't know who makes kits of these
But I have heard of perspex, we call it plexi-glass, but it's more generally known as clear acrylic plastic sheet
but anyway
here are some popular sizes of cylinder bore and OD of cylinder, nominal sizes
77-89.8
83-93.8
85.5-93.8
88-95.4
90.5-97 (early thinwall)
90.5-98 (most 90.5)
92-98
92-101 (AA thickwall 92)
94-101
I prefer having the hole near the edge, but if you go with a hole in the center then it's easy to mount on your lathe and trim round |
richparker Samba Member
Joined: November 24, 2011 Posts: 6998 Location: Durango, CO
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77060 Location: Sneaking up behind you
Millionmph Samba Member
Posted: Fri Apr 19, 2024 8:04 am Post subject: Re: Perspex cc measuring rings |
You can get the syringes for like $5 on amazon and for the disc I used a plastic lid and cut to size, cost $0 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26352 Location: Douglas, WY
Posted: Fri Apr 19, 2024 8:21 am Post subject: Re: Perspex cc measuring rings |
You want cheap?
I used to make my own CC Kit by salvaging computer related stuff. Repurposing the clear plastic spacer disks that were included in sleeves of blank CD-R and DVD-Rs, cutting them down to fit. And repurposing the syringes that came in InkJet Printer Cartridge Refill Kits. Stuff I had just lying around, zero cost except time. http://members.trainorders.com/android/VW12up/PoorMansCCKit-CDInsertDisksPlusInketSyringes.jpg _________________ Andy T.
garym999 Samba Member
Joined: November 26, 2022 Posts: 106 Location: Oxfordshire, UK
Posted: Fri Apr 19, 2024 11:01 am Post subject: Re: Perspex cc measuring rings |
If you know someone with a 3D printer should be easy to make, just a thought _________________ 1975 South African Fleetline |
lner JP Samba Member
Posted: Fri Apr 19, 2024 11:45 am Post subject: Re: Perspex cc measuring rings |
If you look on coolairvw website you can hire the discs for £5.50, that's what I planned to do when I get round to my build.
JP |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3476 Location: Paradise, Ca
Posted: Fri Apr 19, 2024 12:05 pm Post subject: Re: Perspex cc measuring rings |
Because our poster is in England, that CC kit that is $37 turns into $80 real fast once all the shipping/fees are paid. Its really not hard to make something that gets the job done perfectly. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Zed999 Samba Member
Posted: Fri Apr 19, 2024 1:45 pm Post subject: Re: Perspex cc measuring rings |
Being also in the UK I found I could peel the colour layer off an old licence plate leaving clear perspex.
99p for a syringe from the local chemist was every bit as accurate as the fancy burette I bought to check the syringe. lol |
Murt Samba Member
Posted: Sat Apr 20, 2024 3:13 am Post subject: Re: Perspex cc measuring rings |
Thanks Chaps for the responses
I'm not a cheapskate by any means but as said earlier if I order one here it's $80 bucks, or as also said, I can hire it for ~$7 but the site below, will make them for peanuts, and as @modok said, I can even have the hole made where I want.
I have just ordered a set of the AA 88's machine in, and wanted to be able do deck height and to CC my heads as well for when I put it all together. The heads will need to be opened up to take 90.5, but I wanted to know the size of the discs that come in the kit if that makes sense ? anyway at the price of the discs, I may make up a couple of sets syringes on Amazon are dirt cheap as well
https://www.perspexsheet.uk/perspex-disc/ _________________ 1966 VW Beetle ‘Jules’
Zed999 Samba Member
Posted: Sat Apr 20, 2024 4:31 am Post subject: Re: Perspex cc measuring rings |
Bargain!
I think your best bet is to get the heads in your hands and measure yourself. |
