Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 495 Location: France
Posted: Sun Apr 07, 2024 3:16 am Post subject: External Oil Cooler 2.0L Air Cooled |
Looking for info on external oil coolers for a very heavy 2.0l vanagon. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17164 Location: Retired South Florida
Posted: Sun Apr 07, 2024 5:22 am Post subject: Re: External Oil Cooler 2.0L Air Cooled |
On the water cooled engines there is enough room to add a sandwich adapter with oil line ports between the oil filter and engine. The air cooled engine is a lot tighter in that area. You might look at installing a remote oil filter and cooler. You can find spin on adapters that replace the filter. It looks like you are not in the US. I use a company called Summit Racing and Pegasus Auto Racing. They will have what you need. You would be fabricating the mounting and lines.
Here is the down side. You are adding multiple points of failure that will result in a seized engine. I saw your other thread regarding oil temp. My suggestion would be to run a thinner synthetic oil. Not Mobile 1 unless you run Mobile 1 racing. Higher viscosity oil creates friction and that is more heat. I ran Mobile 1 20-50 in my VW race car. I was seeing 260F. Switching to Redline 30wt dropped temps 40 degrees F. No other changes. _________________ ☮️ |
Posted: Sun Apr 07, 2024 7:51 am Post subject: Re: External Oil Cooler 2.0L Air Cooled |
MarkWard wrote: |
Here is the down side. You are adding multiple points of failure that will result in a seized engine. I saw your other thread regarding oil temp. My suggestion would be to run a thinner synthetic oil. Not Mobile 1 unless you run Mobile 1 racing. Higher viscosity oil creates friction and that is more heat. I ran Mobile 1 20-50 in my VW race car. I was seeing 260F. Switching to Redline 30wt dropped temps 40 degrees F. No other changes. |
Yes I totally agree with you on the external oil cooler. I looked at it last summer and that is what put me off . Going to order a new pressure relief spring and go from there VW 021115421B |
CarstenR Samba Member
Posted: Thu Apr 11, 2024 12:06 pm Post subject: Re: External Oil Cooler 2.0L Air Cooled |
Hey everyone, I've been following several posts across various sources on temperature control on air-cooled engines. At the risk of oversimplification (a place my simple mind likes to go) and a minor hijack of the thread, for us air-cooled Vanagon owners, is the solution to keeping your type IV motor from overheating possible via:
1) Making sure the factory air cooling components are working as intended
2) Using the right viscosity oil (I'm seeing 5W-30 synthetic in these posts)
3) Installing temp monitoring to keep an eye on things
Or are there additional steps that one should (not just 'could', but really 'should') take to ensure the longevity of the motor when heat is concerned?
- Aircooled Anxious in Allen Park _________________ Carsten Ramcke
Allen Park, MI
1981 Aircooled Westfalia: the 'Opa Bus' |
