dr8track Samba Member
Joined: July 18, 2005 Posts: 504 Location: Seattle area
Posted: Fri Apr 05, 2024 4:09 pm Post subject: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
I recently had my bus painted and ordered the one piece gasket for the rear engine compartment from Wolfsburg West. It fits in the body beautifully, but the problem is the rear door will no longer close. I have the latch catch on the engine compartment moved all the way forward, but no amount of pushing will get the door latch to connect and close. I'm stumped on what to do to remedy this problem.
The gasket is a pretty firm rubber vs the gasket around the rear hatch to the interior. That particular gasket is pretty soft and. pliable.
If anyone has any thoughts about how to remedy my problem please let me know. I'm not sure is there is a different gasket that is not as thick and "stiff" that is available? _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51284 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Apr 05, 2024 4:29 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
dr8track wrote: |
......I have the latch catch on the engine compartment moved all the way forward,........ |
Try moving it all the way to the back and report back with the results. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Apr 05, 2024 6:20 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
No, still impossible to close. Here are a couple pics
Starbucket Samba Member
Posted: Sat Apr 06, 2024 2:55 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
Are there any vent holes to let the air out of the center when compressing? If not drill a few where the hatch wont cover them |
Posted: Thu Apr 11, 2024 12:42 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
I tried both of these suggestions and neither worked. I can't believe I;m the only person to have this problem. I'm stumped on what to do to fix it. I'm still wondering if another company makes a seal that might either be thinner or made of a softer material? As i mentioned, the old seal on the rear door to the interior is a softer rubber.
Not sure what to do at this point. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12774 Location: on a bike ride somewhere
Posted: Thu Apr 11, 2024 12:44 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
You’re not the only one.
The rest of us are just busy driving our late buses with shredded and leaky hatch seals.
For anything meaningful to change, we could try holding our parts shops accountable, but that would require them to listen and respond to our concerns without getting defensive and denying responsibility.
www.airschooled.com |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1977 Location: Manitowoc, WI
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1275 Location: Bethlehem, PA
Posted: Thu Apr 11, 2024 1:19 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
Adjust the striker plate? |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4954 Location: Southern AB
Posted: Thu Apr 11, 2024 3:50 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
weird the 68-71 seal I just got from wolfsburg west is really soft
the one that came with the bus from CIP that was 20 years old was hard as month old Twizzlers _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4536 Location: Oklahoma City, OK
Posted: Fri Apr 12, 2024 2:57 am Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
Try loosening the hinge scews, there is usually a little wiggle room, pull back and tighten them. With max latch/catch clearance try closing the lid slowly, if you still need more the catch (part mounted to body) can be massaged back with a hammer, that is gently with the blows. |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1772 Location: Newmarket, ON
Posted: Fri Apr 12, 2024 12:14 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
W1K1 wrote: |
the one that came with the bus from CIP that was 20 years old was hard as month old Twizzlers |
I've been working on some current projects on my bus for over two years and it turns out I don't remember where I ordered it from. I called both Wolfsburg and Bus Depot and neither have record of me ordering it. So it's a mystery where I got it.
I went ahead and called Wolfsburg back and they confirmed that there's is a softer "foam feeling" rubber. So I just ordered a new one and I'll give up on the one I have. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2773 Location: Hamble, Hampshire, UK
Posted: Sat Apr 13, 2024 11:44 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
Out in the market place there are hard black seals and soft greyer seals.
With a hard seal it will never give enough to close easily.
Complain to WW as they are selling crap.
Over here in the UK the usual way to tell is the same place will sell two choices, one less expensive than the other.
The more expensive one is usually the softer/good greyish rubber one.,
But for e.g front door seals you also get the choice of the Brazilian one that does not fit the same (needs lots of contact glue), but is extremely cheap (and soft and greyish) costing £25 compared with £100 for the correct fit soft rubber part. From that vendor the hard black one was about £50 AFAIR.. _________________ Ancient vehicles and vessels
Posted: Tue Apr 16, 2024 7:35 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
The Wolfsburg West version arrived. And a reminder, I was mistaken about buying the other one from WW. I had them and Bus Depot check to see if I ordered it from them and I didn't. So at this time I don't know where I got it.
The first one is superior in many ways to the WW version. It's a one piece design with 90 degree corners and it fits in the channel perfectly. You wouldn't even need to use adhesive on it if you didn't want to. The problem is it's just too darn big. Nothing I did helped.
The WW version is simply a long strip of weatherstripping with no corners. Just one long piece. It's the grayish softer rubber. It also fits in the channel well and barely is higher than the actual channel. When test fitting it you discover a couple challenges. What exactly do you do at the corners? And, when you fit it in the channel it's about 1 foot short. So it's clear that it needs to be stretched as its being installed.
I considered cutting a V in the corners to see if it would make the turn better, but in the end I just opted to stretch it around the corner.
I got some weatherstrip adhesive and began the installation. One of the challenges is that it's hard to know just how much you should be stretching it to successfully have the two ends meet. I didn't stretch enough and it left about a 4 inch gap at the top. I may or may not add some rubberish weatherstrip I have to fill the gap.
So the WW version does work, but it's not nearly as professional looking as the black one piece that is too thick. The WW version is almost too thin. Had to move the striker plate all the way back. It barely compresses the wstrip when closed.
But at least it works. Glad to move on to the next task. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
W1K1 Samba Member
Posted: Tue Apr 23, 2024 12:34 pm Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
Ok this is interesting. As W1K1 mentioned, WW does indeed carry a one piece seal with the corners. In the picture it looks identical to the one that I originally ordered (that I can't remember where I ordered it) that absolutely will not allow the door to close.
I called them and apparently, the seal they sold me this last time is actually a seal for the top engine access cover. It's the one long spongy rubber seal.
The guy I talked to this time says they absolutely do not sell a spongy rubber seal for the rear engine hatch. The guy I spoke with last time must have been confused about which seal I was looking for.
So now I'm wondering if their one piece seal with the corners (that looks exactly like the one I have) might actually work.
Or maybe I just cut my losses and stick with the spongy seal for the rear engine hatch. It's glued in their now. It works. Not as nice looking as the one piece with the corners, but I can't be sure I will ever find one that will allow my rear engine cover to close. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Posted: Wed Apr 24, 2024 7:04 am Post subject: Re: Rear Hatch - Engine - 74 Bus One Piece Weatherstripping |
Put it in your dishwasher (top rack) and run it through a cycle, the hot water will soften the rubber (no soap needed). |
richparker Samba Member
Joined: November 24, 2011 Posts: 7000 Location: Durango, CO
