Original style tar boards?
ahcheemjoe
ahcheemjoe is offline
PostPosted: Wed Mar 27, 2024 8:01 pm    Post subject: Original style tar boards? Reply with quote
Several years ago, I repainted the engine area in my '63 convertible. At the time, I removed the original worn tar board and replaced with waffle pattern replacements. I've never been happy with them. They car is very original, and to my eye they don't look right.
Does anyone make a set that approximate the look of the original?
rcooled
rcooled is offline
PostPosted: Thu Mar 28, 2024 3:30 pm    Post subject: Re: Original style tar boards? Reply with quote
KGP&R (Airhead Parts) has two styles of tar board for Ghias...the least expensive one is the waffle pattern. You'll have to call about the other to see if it's what you're looking for.
https://airheadparts.com/vw-parts/vw-body-parts/en...ear_=1963/
They're having a 20% off sale right now too. Discount code is MOV20.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
obus Premium Member
obus is offline
PostPosted: Thu Mar 28, 2024 8:27 pm    Post subject: Re: Original style tar boards? Reply with quote
*Edited
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273
rcooled
rcooled is offline
PostPosted: Fri Mar 29, 2024 7:49 pm    Post subject: Re: Original style tar boards? Reply with quote
obus wrote:
https://www.thesamba.com/vw/classifieds/detail.php?id=2191544
Not what he wants...
ahcheemjoe wrote:
...waffle pattern replacements. I've never been happy with them...to my eye they don't look right.
ahcheemjoe
PostPosted: Fri Mar 29, 2024 8:04 pm    Post subject: Re: Original style tar boards? Reply with quote
Yes, these waffles are more like what I have.
Any other suppliers in US or international? Thank you.
ahcheemjoe
PostPosted: Wed Apr 03, 2024 7:20 am    Post subject: Re: Original style tar boards? Reply with quote
Is the answer that they do not exist? Maybe my only option is to search for an original set?
Braukuche
Braukuche is offline
PostPosted: Wed Apr 03, 2024 7:32 am    Post subject: Re: Original style tar boards? Reply with quote
https://www2.cip1.com/c24-141-898-805-t/
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
McFunzeepants
McFunzeepants is offline
PostPosted: Wed Apr 03, 2024 11:41 am    Post subject: Re: Original style tar boards? Reply with quote
Has any one used these? How close to stock do they look?
I wonder if they are the same as these:
https://www.seefeldt.de/de/motorraum-isoliersatz-7-tlg-karmann-ghia-141-813-805a.html
Braukuche
PostPosted: Thu Apr 04, 2024 8:06 am    Post subject: Re: Original style tar boards? Reply with quote
I used them, they are not as thick as the orignal stuff but they look more like the original ones since they don’t have the waffle pattern. They are also stiffer and don’t flop around like a piece of rubber like the cheap waffle ones do. I doubt you can find anything nicer at this time.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Rome
Rome is offline
PostPosted: Sat Apr 06, 2024 1:30 pm    Post subject: Re: Original style tar boards? Reply with quote
Many years ago I spoke with Vince (RiP) who was the original owner of a '65 Ghia Cabrio nearby in northern New Jersey. He refurbished it and during that time mentioned that his factory-original firewall insulation had broken up and wanted to replace it. Vince was a resourceful person and came up with the idea that the sound insulation from the back of a washing machine had a very similar texture and appearance to the factory sound panel. He found a large section from a junked machine, cut it to match the factory panel and attached it. Looked very convincing.
Another method would be to find an original tarboard even if it's partially broken or torn. Glue it back together using thin aluminum flashing on the back side to hold the pieces or joints together. Then apply roofing tar paper to the surface that you see in the engine compartment. Glue it on with contact cement and use a small roller to work out any air bubbles. The only issue then is that the thin flashing may prevent the triangular steel spikes on the firewall surface to pierce thru to hold the panel.
Marcdeb
Marcdeb is offline
PostPosted: Sat Apr 06, 2024 2:39 pm    Post subject: Re: Original style tar boards? Reply with quote
I was able to find originals from a Ghia that was being parted out. It's not easy but you can try contacting sellers of scrap Ghia's on this site.
Here's a few and there's more.
https://www.thesamba.com/vw/classifieds/detail.php?id=2630378
This seller is Chris Morrice. He always has several Ghia's he's parting out. If might even have some stashed away.
https://www.thesamba.com/vw/classifieds/detail.php?id=1802715
Here's the link for the search I did.
https://www.thesamba.com/vw/classifieds/search.php...ton=Search
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
ahcheemjoe
PostPosted: Sat Apr 06, 2024 9:06 pm    Post subject: Re: Original style tar boards? Reply with quote
Thank you. This is very helpful. Great site.
Loren
Loren is offline
PostPosted: Fri Apr 12, 2024 1:19 pm    Post subject: Re: Original style tar boards? Reply with quote
I just got the Cip1 tar board set and it's actually very nice. The material is very close to the original tar board found on later Ghias. Unfortunately, it has cut outs for later Ghias, so I can't really use it on my 58 Ghia project. Its a shame they didn't omit the cut outs and provide a template to cut them out if you needed them. As stated above, they are about half as thick as original boards, but they are rigid and look nice. I still haven't found a good replacement for lowlight tar boards. Sad
Marcdeb
Marcdeb is offline
PostPosted: Fri Apr 12, 2024 2:08 pm    Post subject: Re: Original style tar boards? Reply with quote
That's not good. I looked and the description actually says it fits 56 to 74. Not much detail included in the description. Now it also says out of stock.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
