OldSchoolVW's Samba Member
Posted: Tue Mar 26, 2024 9:01 pm Post subject: LED Tail/Brake Light Help Needed - '63 Bug 6v |
I’m switching to LEDs for my turn signals and tail/brake lights. The turn signals and dash indicator work fine, but I’m not having luck with the tail/brake lights. The incandescent bulbs work correctly … dim when light switch is ON and bright when brakes are applied. When I install LED bulbs that are equivalent to the dual filament incandescent bulbs, the only time the LED bulb comes on is when the brakes are applied. I have contacted the supplier to see what would be needed to get the LEDs to behave as the incandescents do. They have suggested that I “may” need 6 ohm 25 watt LED load equalizers on the brake light wires and “maybe” on the tail light wires as well. “May” and “maybe” ideas sound like they really don’t know and just want me to throw parts at it … at my expense of course.
With the ignition switch in the ON position, these are the readings I get on my meter:
Brakes OFF & Light switch OFF:
Left contact = 0v Right contact = 2.5v
Brakes OFF & Light switch ON:
Left contact = 5.8v Right contact = 2.5v
*The LED bulbs should be on low light in this situation. They are not on at all.
Brakes ON & Light switch OFF:
Left contact = 0v Right contact = 5.6v
*The LED bulbs are on and bright.
Brakes ON & Light switch ON:
Left contact = 5.8v Right contact = 5.6v
*Again, the LED bulbs are on and bright.
I may very well need load equalizers, I’m just hoping those of you who have done this or have a greater understanding of the electrical issues in this situation can give more definitive guidance on how to make these LEDs behave like the incandescents do. Thank you!
_________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
EVfun Samba Member
Posted: Tue Mar 26, 2024 9:36 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
Your tail lights, brake lights, and parking lights should not require anything special to be swapped out for LED bulbs. The turn signals may not work if you swap in LED bulbs without adding load resistors.
I think the stray 2.5 volts on the brake light terminals when the brakes lights are off may be the problem. It is hard to know what the manufacturer put inside your LED bulbs. If you can find and get rid of that voltage the bulbs may work correctly. It should be about 6 volts with the brake lights on, but 0 volts when the brake lights are off (like the tail lights). _________________
Wildthings wrote: |
Posted: Wed Mar 27, 2024 10:17 am Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
Thanks EV. The right contact (where the stray 2.5v is) is connected to the black wire which leads back to the brake switch (J3 on the wiring diagram) and then to the fused side of #8. So, maybe a faulty brake switch that is letting voltage leak through? '63 models don't have a brake warning light like my '69, so nothing on the dash to tip me off.
BTW ... When I installed LEDs for the turn signals, I also used the recommended flasher, which is compatible with the LED bulbs. They work perfectly. I had to replace the original bulb holder for the dash turn signal indicator with the later style plastic one with 2 terminals so I could connect the + and ground wires with the correct polarity for the LED dash bulb. After that, the dash bulb worked fine and came on at the same time as the turn signal bulbs.
I'll see if I can isolate the source of the 2.5v on the brake light wire and share what I find. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
zerotofifty Samba Member
Posted: Wed Mar 27, 2024 2:00 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
Take the volt readings without the led bulbs installed, rather regular bulbs.
Note that low volts on the brake filaments maybe result of poor contacts in the turn switch assembly, even when no turn is requested at the switch. The brake lamp power passes thru the turn signal switch.
Good luck _________________ Give peace a chance. No American war with Russia! |
Posted: Wed Mar 27, 2024 3:36 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
zerotofifty wrote: |
Good luck |
The voltage readings were taken directly off of the spring tabs in the bottom socket where the dual filament brake/tail light bulb would go with no bulb inserted. This is what the circuits are delivering under each of the scenarios I described. You are suggesting that I remove the rear light assembly, install the incandescent bulb, ground the assembly with a jumper and take readings for the same scenarios as before, correct? I imagine you would also suggest doing this with the LED bulb installed as well, correct?
According to the wiring diagram for a '63 Bug, the power for the brake light circuit originates at the fused side of fuse #8 then passes through the brake switch on the master cylinder and continues on to the tail light assembly. The turn signal switch in the steering column is not part of that circuit.
The tail lights receive power from the fused side of fuses 2 & 3 (fuses 2 & 3 are bridged in the fuse box and the power is supplied to 3 from the light switch on the dash). The turn signal switch in the steering column is not part of this circuit. The only current passing through the turn signal switch is power from the load terminal on the flasher.
Both the flasher for the turn signals and the brake light circuit are connected to the fused side of #8 ... but other than that, do not share any connections.
Perhaps the confusion is in terminology:
Rear turn signal bulb = the top bulb in the rear light assembly.
Tail light bulb and brake light bulb are the same bulb containing 2 filaments = the bottom bulb in the rear light assembly.
The turn signal bulbs (all LEDs) are working correctly and are not part of either the tail light or brake light circuits. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
EVfun Samba Member
Posted: Wed Mar 27, 2024 3:38 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
My working theory is that your LED bulbs are “smart.” They see the small voltage on the brake light pin as a request to shine on brake light mode, however, 2.5 volts is not enough for them to light. When the tail light power is on they see it as a request for full tail light plus brake light brightness. Since power is available (from the tail light side) it can light up to maximum brightness.
Your turn signal switch should have nothing to do with your tail lights, unless your tail light housing isn’t making a good ground connection. _________________
Wildthings wrote: |
Posted: Wed Mar 27, 2024 3:51 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
OldSchoolVW's wrote: |
Good luck |
The turn signal bulbs (all LEDs) are working correctly and are not part of either the tail light or brake light circuits. |
ok, 1963 has a separate filament for brake and turn. 1961 uses same filament for both and thus brake signal goes through the turn switch. My bad. but yes check the voltage with a load on them. the regular bulbs are a higher load than an led, and thus will cause that 2.5 volt to likely drop a lot, but an led wont drop it much.
there should not be that 2.5 volt on there when no triggered by the switch. _________________ Give peace a chance. No American war with Russia! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Wed Mar 27, 2024 3:52 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
Double-check the grounding of the lamp assembly. Sounds like it's finding ground through the "filament" of another bulb or filament, and the partial voltage is what you are seeing (2.5V).
Those look really cleaned so it's doubtful, but I always check the free/easy faults first (or again). _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
Posted: Wed Mar 27, 2024 4:14 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
EVfun wrote: |
My working theory is that your LED bulbs are “smart.” They see the small voltage on the brake light pin as a request to shine on brake light mode, however, 2.5 volts is not enough for them to light. When the tail light power is on they see it as a request for full tail light plus brake light brightness. Since power is available (from the tail light side) it can light up to maximum brightness. |
Okay, I think this would be consistent with info from the supplier. They said the LEDs would begin to illuminate at 3.6v and fully illuminate at 4.25v. So maybe this is where the recommended 6 Ohm 25 Watt LED Load Equalizer comes into play? _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Wed Mar 27, 2024 4:16 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
there should not be that 2.5 volt on there when no triggered by the switch. |
Will do! _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Wed Mar 27, 2024 4:22 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
KTPhil wrote: |
Those look really cleaned so it's doubtful, but I always check the free/easy faults first (or again). |
Yes, scraped the daylights out of all the + and ground connections. Even thought about how to add a supplemental ground wire to the housing assembly for good measure, but haven't figured the best way to do that. Seems you can't have too may grounds when dealing with a 6v system. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
EVfun Samba Member
Posted: Thu Mar 28, 2024 12:34 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
EVfun wrote: |
Okay, I think this would be consistent with info from the supplier. They said the LEDs would begin to illuminate at 3.6v and fully illuminate at 4.25v. So maybe this is where the recommended 6 Ohm 25 Watt LED Load Equalizer comes into play? |
I would pull out fuse 8 and check your tail light terminals again. This should remove the stray 2.5 volts from the right contact. If it does then try putting the LED bulb in and see if its tail light function works correctly. Naturally the turn signals and brake lights won't work (no power).
If the above gets the tail lights working then I think you need a pull down resistor between the brake light switch output and ground. (Hopefully a 210 ohm 1/4 watt resistor would be enough.) You should be able to do that at any point between output side of the master cylinder to the inside a tail light housing. This should pull the right contact down to 0 volts when fuse 8 is put back in place. I suspect the stray power getting through to the right contact is an electrically leaky brake light switch. There is little else on that circuit branch. The real solution is to replace the brake light switch and bleed the brakes, but current replacements seem to have quality issues of their own. _________________
Wildthings wrote: |
Posted: Fri Mar 29, 2024 7:24 am Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
EVfun wrote: |
If the above gets the tail lights working then I think you need a pull down resistor between the brake light switch output and ground. (Hopefully a 210 ohm 1/4 watt resistor would be enough.) You should be able to do that at any point between output side of the master cylinder to the inside a tail light housing. This should pull the right contact down to 0 volts when fuse 8 is put back in place. I suspect the stray power getting through to the right contact is an electrically leaky brake light switch. There is little else on that circuit branch. The real solution is to replace the brake light switch and bleed the brakes, but current replacements seem to have quality issues of their own. |
I remembered reading about this pedal activated brake light switch in another discussion:
https://www.aircooledevolution.com/product-page/pedal-activated-brake-light-switch
Maybe this would be a better work-around. Just take the brake switch on the MC out of the equation. Thoughts? _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
EVfun Samba Member
Posted: Fri Mar 29, 2024 9:53 am Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
EVfun wrote: |
Maybe this would be a better work-around. Just take the brake switch on the MC out of the equation. Thoughts? |
I would do the diagnostic work first before applying possible solutions. I suspect your brake light switch has a resistive off state, but in a 60 year old car with untold previous owners there is no telling what was messed up before you.
If it's the brake light switch then a pedal mounted one is a good solution, IMHO. I installed a pedal mounted brake light switch on my beach buggy. They typically light up faster than pressure switches, turning on before the pedal moves enough to cover the bleeder ports in the master cylinder. _________________
Wildthings wrote: |
Posted: Fri Mar 29, 2024 10:34 am Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
EVfun wrote: |
If it's the brake light switch then a pedal mounted one is a good solution, IMHO. I installed a pedal mounted brake light switch on my beach buggy. They typically light up faster than pressure switches, turning on before the pedal moves enough to cover the bleeder ports in the master cylinder. |
Yes, planned to do diagnostics before purchasing/applying any solution(s). The pedal mounted switch just came to mind (in the middle of the night) and I thought it was worth considering as an option if the MC brake switch ends up being the culprit.
The car is very stock. Wiring is as shown in the Bentley wiring diagram with no modifications (with the exception of a HSR I added). I'm the 3rd owner and it appears the POs just let it age unmolested. Fortunate for me since that keeps the Bentley manual relevant. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Sat Mar 30, 2024 8:22 pm Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
Update ...
So I put the LED tail/brake light bulbs back in to test them, turned the ignition to "ON" and turned on the light switch. To my surprise the tail lights came on at the lower intensity as they should. Then I pushed on the brake pedal and they got bright. This is the first time they have behaved as they are supposed to. The last time I tested them, I got no low intensity tail light ... just the bright intensity when the brakes were applied. I did nothing to the wiring, so I'm guessing it was the brake switch on the master cylinder that was sticking and letting the 2.5v get through which was messing with the LEDs as EV suggested. The brakes are working well, so I'm just going to let the MC be. Since the reliability of the MC brake light switch is questionable, I am inclined to go ahead and install the pedal activated brake switch mentioned earlier and take the MC switch out of the picture.
Thanks to you all for the advice and tips! _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Tue Apr 09, 2024 3:23 am Post subject: Re: LED Tail/Brake Light Help Needed - '63 Bug 6v |
I had a similar problem with 6v led bulb.
The issue:when lights are on and stop pedal is not pressed, the LED put out some current ALSO from the wiring for the stop function. In fact while the filament bulb has 2 separate filaments, the LED has only 1 emitter, driven to make high or low light.
But the wiring in the car connects the 2 stoplight in parallel.
My solution was to insert a couple of diodes (one foreach side) in series with the stop contact.
The arrangement: buy 2 diodes and sold a male and a female spade connector at diode terminal, then put this circuit between the wiring from the car and the terminal on the rear light... all OK! |
