WaterBuggy_24 Samba Member
Posted: Wed Mar 27, 2024 6:58 pm Post subject: Custom Windshield? |
Looking for resources for custom cut glass for my rail buggy. Trying make legal for road use, but I need the d.o.t. approved safety glass. Any help would be greatly appreciated. Ty _________________ They will not float indefinitely! |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5439 Location: Holland, MI
Posted: Thu Mar 28, 2024 5:15 am Post subject: Re: Custom Windshield? |
Your local auto glass shop will do it. Cost me less than $200 to have them cut a sheet of safety glass out and install it.
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
racecougar Samba Member
Joined: July 31, 2023 Posts: 109 Location: Imperial, MO
Posted: Thu Mar 28, 2024 5:57 am Post subject: Re: Custom Windshield? |
If you're going for MO plates (going off your KCMO location), you don't have to have a windshield in place for the inspection. If you do install a windshield, you'll have to have a functional windshield wiper. |
PhillipM Samba Member
Posted: Thu Mar 28, 2024 6:53 am Post subject: Re: Custom Windshield? |
Almost anywhere that cuts or sells windows should be able to cut and mark you a piece of laminated glass, I think mine cost me £50 |
Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 195 Location: Clare MI
Posted: Thu Mar 28, 2024 11:02 am Post subject: Re: Custom Windshield? |
Vanapplebomb wrote: |
I'm at this stage also.
My original roll hoop had aluminum angle pop-riveted into the inside "round" of the tubes. They used what I would call a tractor weatherstrip with a thin groove outward for the aluminum thin angle and the inner had a groove for the 1/4" thick glass.
I plan on making a small'ish frame for my windshield, probably 1/2" steel angle and curve up around the two upper corners and weld it all up as a one-piece frame. I "was" going to use adhesive to glue the glass into the frame, but last night thought as long as I'm going to have this minimal framework to the outside of my windshield hoop, that I could use a rubber weatherstrip and inset the glass to it and still have a FULL view as the weatherstrip is likely less than 1.5" wide, the width of the hoop tubing.
Where did you get the weatherstrip for the install? I figured with a small external frame, that 3 to 4 tabs along top and bottom with a couple on the uprights, that I can just bolt it to the windshield hoop. The slight lip of the angle will protect the edge of the glass, ever IF it were glued into the frame.
I think Beanie Buggy did something similar to what I'm thinking of doing, of course after I saw his install...
Suggestions?
Thanks, Dan |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1063 Location: St. Louis
Posted: Thu Mar 28, 2024 11:49 am Post subject: Re: Custom Windshield? |
I made a 3/4" DOM tubing frame with a 3/4" wide metal strip welded to adhere the glass to. I had a glass shop cut the glass and urethane it to the frame with the usual automotive windshield glue. I have had the car 3 feet in the air multiple times and jumped off a loading dock a few times, as well as doing Hell's and Fins in Moab with the glass in. No problemo! I sorta figured frame flex would break it.
_________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
BFB Samba Member
Posted: Thu Mar 28, 2024 4:19 pm Post subject: Re: Custom Windshield? |
racecougar wrote: |
Yep! I can 2nd that _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
Posted: Thu Mar 28, 2024 7:51 pm Post subject: Re: Custom Windshield? |
I appreciate all the feedback everyone. I went to one autoglass business and they did cut glass. I'm thinking they just install OEM windshields. There's plenty around I'll keep searching. In the meantime I've got a piece of half inch lexan or polycarbonate. It's shatterproof. It scratches easier though. _________________ They will not float indefinitely! |
Posted: Fri Mar 29, 2024 2:54 am Post subject: Re: Custom Windshield? |
Go to a commercial window place, somewhere that does flat plate windows, not an autoglass fitter. |
Posted: Fri Mar 29, 2024 2:14 pm Post subject: Re: Custom Windshield? |
Talked to my glass guy this afternoon. He's a local gut to where I used to live in Midland MI. He does all sorts of auto glass and classics with lots of flat glass.
I got my 1/2"x1/2"x1/8" angle iron this afternoon and will make up my perimeter frame and get the window bead locking gasket/weatherstripping to go with it. This way if I break one, it's a matter of just peeling back the locking strip and put in a new glass.
I told him that I may have an issue finding a good place to mount my wiper motor and he said that I can just do a halfmoon along the bottom edge of the frame wherever it needs to be and he will lay in the weatherstripping and he will cut the glass to fit.
I will put it all together and cut out a piece of Masonite as a fake windshield and he then will just make the new glass the same as my Masonite pattern... Easy peazy he said...
I'll have just under 7 square feet of glass at $21/s/f and he'll charge me $50 labor to cut and install it in my painted windshield frame.
This won't be for a few more weeks, but I will post when it's done.
I know I hijacked this thread and I'm sorry for that, but I do greatly appreciate all the direction and ideas!
Dan |
