AndyBees Samba Member
Joined: January 31, 2008 Posts: 2338 Location: Southeast Kentucky
Posted: Sat Mar 09, 2024 10:18 am Post subject: Re: Official lazy person's stupid question thread |
E1 wrote: |
Where’d you get that steel t-connector for the fuel lines, Andy?
Mine’s plastic and freakin’ me out, Man. |
Well, I purchased this Van in January, 2016 from the 2nd owner in Knoxville, TN. It had been sitting for a long time.
Anyway, what you see is what was on it when I got it. Someone had replaced all the fuel hoses.
The ECU was missing. I bought one and installed it... new plugs and plug wires. It starts and runs great. It had 142k miles on and now has 162k.
Really, all it needs is the AC system update which I'd like to do this spring among all my other projects. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6626 Location: Westfalia, Earth
Posted: Sat Mar 09, 2024 10:26 am Post subject: Re: Official lazy person's stupid question thread |
Cool, Thanks! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9954 Location: Orbiting San Diego
Posted: Sat Mar 09, 2024 10:28 am Post subject: Re: Official lazy person's stupid question thread |
All the wbx Vanagons came with the steel fuel tee plus test port.
The tiny screw/plug for the test port can be an issue for ham-handed types.
That may explain why a plastic tee got installed, maybe after someone broke or lost the tiny screw/plug.
Mark
AndyBees wrote: |
E1 wrote: |
E1 Samba Member
Posted: Sat Mar 09, 2024 10:33 am Post subject: Re: Official lazy person's stupid question thread |
That’s great info Mark, Thanks… makes perfect sense.
Time Bomb I never want to see expire, I often ask suppliers about this part but have never found one.
crazyvwvanman wrote: |
Mark
AndyBees wrote: |
E1 wrote: |
— Colin Chapman |
Posted: Sat Mar 09, 2024 10:48 am Post subject: Re: Official lazy person's stupid question thread |
Yeah, I am pretty sure the 1.9 WBXer engine that was in my 84 has the metal tee and test port.
I do know for sure that the 2.0 Air-cool engine in my 83 has the metal tee and test port. It was never a problem during the 225k miles I drove it (85 thur 2005). When I purchased it the spring of 1985, I also bought a Bentley and a VDO pressure gauge with 1 psi increments to 100 PSI to do diagnostics. I took that gauge with me on all the trips to Alaska from 1986 thru 2003 in that ol' 83..... and never did need it. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Sat Mar 09, 2024 11:20 am Post subject: Re: Official lazy person's stupid question thread |
kamzcab86 wrote: |
Abscate wrote: |
That’s not a fuel line and it’s burning from a wiring fault inside, not from external heat. Time to get that puppy open and inspected. |
Perhaps if you owned a WBX you wouldn't be providing an incorrect response. That is indeed a fuel line, which is wearing the factory-original protective sheathing. |
I am wondering if the factory sheathing couldn't hold up to gasoline and as the original hose broke down with time gas collected in a low spot in the sheathing and gradually damaged it? |
E1 Samba Member
Posted: Sat Mar 09, 2024 12:18 pm Post subject: Re: Official lazy person's stupid question thread |
djkeev wrote: |
E1 wrote: |
The 2.1 engine had the steel bleeder/pressure test port.
If yours is truly plastic let me know, I think I've got an extra you can have.
Dave |
Hey, Thanks!
I need to crack the engine bay and double-check that I’m not confused and the plastic one was in our old van!
This sometimes happens. Okay, am confused *a lot*. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
69tr6r Samba Member
Joined: October 10, 2017 Posts: 130 Location: Shelton, CT
Posted: Fri Mar 22, 2024 1:08 pm Post subject: Re: Official lazy person's stupid question thread |
Brake question on my 84 stock van. When I press the brake pedal the emergency brake dash light comes on, even though my fluid is full. Brakes seem to work fine.
I replaced the master cylinder a while back, and this problem did not happen at that time.
I also smell brake pads after driving, seems like it's coming from the pass rear. I jacked up the van and both rear wheels spin free.
Thanks for the help! |
Posted: Fri Mar 22, 2024 1:20 pm Post subject: Re: Official lazy person's stupid question thread |
69tr6r wrote: |
Maybe check a Bentley Manual in reference to the connectors on the two switches on the Master Cylinder.
Also, is it possible something come unplugged and you plugged it in the wrong place? _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Fri Mar 22, 2024 1:33 pm Post subject: Re: Official lazy person's stupid question thread |
69tr6r wrote: |
The brake switches have a long history of failing. Buy the best you can find. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Fri Mar 22, 2024 2:08 pm Post subject: Re: Official lazy person's stupid question thread |
One of your brake light switches has failed. The '84's had SPDT switches, just so that the dash brake warning would come on if one had failed. Why they got rid of this later I don't know - perhaps the later SPST switches were cheaper. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Fri Apr 05, 2024 8:28 pm Post subject: Re: Official lazy person's stupid question thread |
Does anyone have part numbers for the two bottom radiator hoses for a 1984 Vanagon with the 1.9 engine? _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32659 Location: Reading Pennsylvania
Posted: Sat Apr 06, 2024 6:35 am Post subject: Re: Official lazy person's stupid question thread |
Thanks....... much appreciated. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 324 Location: Chicago, IL
Posted: Sat Apr 06, 2024 10:47 am Post subject: Re: Official lazy person's stupid question thread |
69tr6r wrote: |
Prob brake switch like others have mentioned. Two easy things to check before ripping out the switches on the brake master cylinder. 1. Check the float on the brake fluid reservoir. My sensor was broken and that was causing that light to flicker. Check the wires going to it and then take the cap off and look at the float on the underside of the cap. Make sure it is all functioning. 2. (Probably less likely but also caused my brake light to come on) check the button under the e brake handle. Brake pushes this button down and turns the light off. The spring broke on this button for me which also made that light go on. Replacing that button is very easy fix. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Sun Apr 14, 2024 1:36 pm Post subject: Re: Official lazy person's stupid question thread |
1990 Westfalia
Are the bolts holding the H-bar to the pop-top the same bolts than for the latch housing? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
BirdBus85 Samba Member
Joined: December 06, 2022 Posts: 32 Location: North Carolina
Posted: Fri Apr 19, 2024 5:53 am Post subject: Re: Official lazy person's stupid question thread |
1985 1.9L manual trans Westy, getting ready to do a cooling system overhaul. I have and will be reading as much of the threads as I can but I need to order stuff soon as I have a trip planned in a few weeks. Is there a specific brand of hose, radiator & water pump I should be buying? |
4Gears4Tires Samba Member
Posted: Thu Apr 25, 2024 6:09 pm Post subject: Re: Official lazy person's stupid question thread |
Nah, just go to van cafe or gowesty and prepare to hurt your wallet. _________________ '87 Syncro
