Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Wed Mar 06, 2024 2:11 pm Post subject: Headlight buzzer |
As we swing around into autumn in this part of the world the evenings are starting to get a little darker and I put the headlights on yesterday evening for the first time in a while. Of course I promptly forgot and they were left on for a couple of hours while parked (but thankfully the car started right up for me).
Since clearly I can't rely on my brain, maybe it's time to install a buzzer connected to the cabin light switch or similar as a 'you left the headlights on again you dope' alert. I'm sure this has been done a million times but if anyone can direct me to a post describing how it's been done (or maybe there's even a plug & play product out there by now) that would be super
I did search but nothing obvious popped up. 6V electricals if that's relevant.
Thanks peeps! _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Wed Mar 06, 2024 3:03 pm Post subject: Re: Headlight buzzer |
Taking a cue from VW's solution with a buzzer if you leave your key in the ignition:
Splice in a wire to your driver door switch for the interior light (the terminal that grounds when the door is open. Run that wire to a buzzer; the other buzzer terminal goes to the headlight switch such that it gets power when the lights are switched on.
Mount the buzzer on the underside of the dash. Use grommets for any metal penetrations, and add an inline fuse to the headlight side.
So the buzzer sounds when you leave the lights on and open the door to get out.
https://www.amazon.com/Buzzer-Buzzer3-24V-Electronic-Continuous-Length/dp/B0CL465GBK
Lots of threads with ideas and suggestions:
https://www.google.com/search?q=thesamba.com+headl...p;ie=UTF-8 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26328 Location: Douglas, WY
Posted: Wed Mar 06, 2024 4:11 pm Post subject: Re: Headlight buzzer |
Lite-Minder!
I've done this on my older cars for years. They used to sell a Lite Minder kit that IMO is better than that piezo buzzer piece of crap shown above. I know it's crap because I installed one such in my 83 Camry only to have it die and had to replace it. But I have Minders in my bugs, and the last time I checked, they still work fine. (That was a 12V kit though, so a multi-voltage piezo might be the only way to go on 6V)
_________________ Andy T.
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1266 Location: GILROY, CA
finster Samba Member
Joined: May 26, 2012 Posts: 7966 Location: north o' the border
Posted: Thu Mar 07, 2024 3:28 am Post subject: Re: Headlight buzzer |
simply develop the habit of always looking back at your car after parking up (pipe smoking old duffer emoji) _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Thu Mar 07, 2024 5:20 am Post subject: Re: Headlight buzzer |
Use a relay and any buzzer (or a light). Use the Oil Pressure Switch wire and the headlight wire that becomes hot when the lights are on. Wire it up per below.
As a bonus, the buzzer will also sound if your oil pressure dies when the lights are on with the car running. When the car is not running, of course you have no oil pressure, and the buzzer will sound when the headlights are left on.
86 – Trigger -> Headlight switch that is hot when lights are on
30 – Power -> Headlight switch that is hot when lights are on
85 – Ground –> Oil Pressure Switch
87 - Normally Open –> Not connected
87a - Normally Closed -> Buzzer (+)
Chassis Ground -> Buzzer (-) |
Costa66 Samba Member
Posted: Thu Mar 07, 2024 7:24 am Post subject: Re: Headlight buzzer |
Did this with a tiny little peizo buzzer like several have mentioned back in high school. What a life saver!
Josh |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31396 Location: Hot Arizona
Posted: Thu Mar 07, 2024 7:56 am Post subject: Re: Headlight buzzer |
glutamodo wrote: |
Lite-Minder! |
Yeah, I installed Lite Minder, but believe these are no longer sold as such.
I did buy a buzzer from Radio Shack and installed that similarly in one of my vehicles, this should work for 6V too
https://www.amazon.com/uxcell-HYD-2312-Passive-Ele...amp;sr=8-1
The first night I took one gal to a movie, it was twilight when we got there and when we returned 2.5 hours later, my 1970 VW's headlights were still blazing; I told her to get in, it would start right up, and it did. So she didn't have to help push, and 1.5 years later I married her. And I still have that 1970, 53.5 years with it now (I'm the second owner). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
KTPhil Samba Member
Posted: Thu Mar 07, 2024 11:07 am Post subject: Re: Headlight buzzer |
Cusser wrote: |
53.5 years with it now (I'm the second owner). |
The car or the girl?
zerotofifty Samba Member
Posted: Thu Mar 07, 2024 6:37 pm Post subject: Re: Headlight buzzer |
Some folks actually remove such buzzers do to the annoyance. _________________ Give peace a chance. No American war with Russia! |
KTPhil Samba Member
Posted: Fri Mar 08, 2024 12:21 pm Post subject: Re: Headlight buzzer |
zerotofifty wrote: |
Some folks actually remove such buzzers do to the annoyance. |
Yes, I removed the ignition key buzzer from my dad's '71 Fastback due to the annoyance, and repurposed the fusebox/relay box position for a fog lamp relay. |
Cusser Samba Member
Posted: Fri Mar 08, 2024 12:33 pm Post subject: Re: Headlight buzzer |
KTPhil wrote: |
Cusser wrote: |
39 years with the gal !!! Brought our oldest home from the hospital in that 1970 VW. And our youngest is getting married next week. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
