Dash End Screw
henrym
henrym is offline
PostPosted: Fri Jan 05, 2024 3:54 pm    Post subject: Dash End Screw Reply with quote
I'm trying to get my interior correct on my 1970 Ghia and appears the padded dash was replaced sometime back but not properly. I believe there is supposed to be a screw at each end of the dash that pins in tight into the door jam. My dash has neither the screw or the hole in the dash, but the door jam does.
Would anyone have a picture so I could see the proper screw and installation?
Many thanks in advance!
1967 Bug (Second owner)
kent70ghia
kent70ghia is offline
PostPosted: Sat Jan 06, 2024 3:33 pm    Post subject: Re: Dash End Screw Reply with quote
Here is a pic from my 1970 coupe. The dash pad has never been off
c21darrel
c21darrel is offline
PostPosted: Sat Jan 06, 2024 4:26 pm    Post subject: Re: Dash End Screw Reply with quote
here is a 2nd photo, 68 ghia with 67 dash.
GhiaBuild
1967 DC build
Marcdeb
Marcdeb is offline
PostPosted: Sat Jan 06, 2024 6:39 pm    Post subject: Re: Dash End Screw Reply with quote
Here's really close up. It's a 68 vert but I don't think there's any difference in 1970. Original dash pad and screw. It's never been removed. There's a small collar under the screw.
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
kent70ghia
PostPosted: Sat Jan 06, 2024 10:49 pm    Post subject: Re: Dash End Screw Reply with quote
did they use the original pad under the leather, or use something else. I am thinking about doing a leather dash also.
c21darrel
PostPosted: Sun Jan 07, 2024 4:18 pm    Post subject: Re: Dash End Screw Reply with quote
Its a GlassAction dash pad I had covered by my upholstery guy. As I recall he used a thin padding underneath, its vinyl on the dash cap, leather on the grab handle.
GhiaBuild
1967 DC build
kent70ghia
PostPosted: Sun Jan 07, 2024 11:01 pm    Post subject: Re: Dash End Screw Reply with quote
Thanks, I have the Action Glass kick panel speaker enclosures. They make a nice products
