Site Search change?
Forum Index -> Site Share: Facebook Twitter
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Wed Nov 29, 2023 2:30 pm    Post subject: Site Search change? Reply with quote
It seems like something has changed on the search forum feature. More often than not I use the main forum search
https://www.thesamba.com/vw/forum/search.php
select the forum I want to search, leave the defaults, and I'm getting "No topics or posts met your search criteria"
If I navigate to the forum I selected in that search
https://www.thesamba.com/vw/forum/viewforum.php?f=4
and within that forum enter the same search term, I get at least one result. For example, I entered the two words "popout boss" (no quotes).
I get nothing from the general forum search but get one result using the same two words in the split bus forum search.
This is just one example but it seems like this happens a lot lately.
No biggie, but I'm curious if something did change a while back.
PostPosted: Wed Nov 29, 2023 4:16 pm    Post subject: Re: Site Search change? Reply with quote
There hasn't been any recent changes but the difference between the overall Forum search and the specific Forum search, Split Bus in this case, is that the overall Forum search defaults to a title only search and the specific area search does not.
This is the difference in the Zero (overall search) vs. 1 (Split Bus area search) results you are getting.
If you select "Search topic title and message text" from the overall Forum search screen at
you will get the same # of results.
Reply to topic    Forum Index -> Site All times are Mountain Standard Time/Pacific Daylight Savings Time
