fischer68westy Samba Member
Posted: Thu Aug 20, 2015 6:08 pm Post subject: Drivers Seat - adjustment and removal |
How in the sam hill does one get the drivers seat on to the rails?!
I've tried sliding the seat on from the front, but the adjustment knobs/bolts hit the top of the track and bind the seat to the point where it won't slide back far enough. If I try from the rear, where the adjustment bolts don't hit anything, I cant get the rails to engage.
What the bus? |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1149 Location: Vancouver, WA
velvetgreen Samba Member
Posted: Thu Aug 20, 2015 8:03 pm Post subject: |
x2 works for me. slide the seat all the way fwd so it is basically hitting the steering column before attempting to get it centered on the rails. I also look under the seat to confirm it is corrected seated on both rails. Then I lift and hold up the lever that allows the seat to move backwards and scootch my butt on to the seat. place feet firmly on floor and put my back into the backrest thereby getting the seat to slide backwards- works for me. Agreed that the seat mechanism is not VW's finest hour of engineering |
Pinetops Samba Member
Posted: Thu Aug 20, 2015 8:09 pm Post subject: |
It is a pain in the butt, but it'll go on there. Make sure its ligned up (and pull the lever) and you will save yourself a lot of trouble. _________________ "A rolling bus gathers no rust." |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Thu Aug 20, 2015 9:50 pm Post subject: |
make sure the rails on the seat are not pinched closed on are clean also
I run a thick flat head screwdriver down the rails to open them then put a little bit of lube in them so it slides easier _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
Posted: Fri Aug 21, 2015 6:05 am Post subject: |
Thanks for the replies, so it should be just that simple.
The issue I'm seeing is the adjustment knob on the right side of the seat is binding on the rail. Wondering is something is bent.
Are there any pix someone could share of their seat?
Thanks,
Fish |
EverettB Administrator
Joined: April 11, 2000 Posts: 70754 Location: Phoenix 602
Posted: Fri Aug 21, 2015 8:58 am Post subject: |
The knob doesn't hit the rail but may be you mean the locking tabs that the knob connects to?
Up above you also said bolts - there are no bolts on the seat bottom.
I pasted in some photos below that should help.
To be sure we are working with the same parts, does your seat look like the seat shown below?
Seat knob
Seat rails
Some bottom views of my '63 seat (same as 63-67):
Bottom overall
Bottom overall
Knob in locked position
Knob in unlocked position - pulled up if seat was installed
_________________ How to Post Photos
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri Aug 21, 2015 9:39 am Post subject: |
Can you post a photo of your seat? If it has a reond knob on the front to adjust the backrest it won't fit, it is for a bay. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14783 Location: Casa de Oro, California
Posted: Fri Aug 21, 2015 10:12 am Post subject: |
Maybe the hinge points of your seat lock is binding from dirt or rust and you have the handle all the way rotated where the cogs are blocking the track? |
hitest Samba Member
Joined: September 30, 2008 Posts: 10309 Location: Prime Meridian, ID
Posted: Fri Aug 21, 2015 12:02 pm Post subject: |
Please don't laugh too hard, but try this:
Take out the passenger seat, climb in form the right side and try inserting the driver's seat with your right hand!
I am one of these extremely un-ambidextrous guys. I didn't stand a chance getting the seat lined up with my wimpy left hand. When I squeezed in and tried from the pass. side- piece of cake every time, every VW with seat tracks (and I have a lot). It's so much easier for me to pull up the lever as a righty and still wiggle the thing on the tracks. Naturally this assumes you're right handed... _________________
EverettB wrote: |
FU#5 |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Fri Aug 21, 2015 1:02 pm Post subject: |
hitest wrote: |
I am one of these extremely un-ambidextrous guys. I didn't stand a chance getting the seat lined up with my wimpy left hand. When I squeezed in and tried from the pass. side- piece of cake every time, every VW with seat tracks (and I have a lot). It's so much easier for me to pull up the lever as a righty and still wiggle the thing on the tracks. Naturally this assumes you're right handed... |
Made me laugh, but its true...I have the same problem. It's really hard to do this from the driver's side for me. Also, doing it from the passenger side allows me to hold the lever up while still being able to manipulate the seat, AND watch the latch area line up at the same time. Given how easy the passenger seat comes out, it's well worth the trouble. |
