two bleeder calipers
missourimark
missourimark is offline
PostPosted: Fri Apr 24, 2015 9:25 pm    Post subject: two bleeder calipers Reply with quote
On calipers with two bleeder valves what one should you bleed first top or bottom?
johnnypan
johnnypan is offline
PostPosted: Fri Apr 24, 2015 9:49 pm    Post subject: Reply with quote
you only have to bleed the top.
Tim Donahoe
Tim Donahoe is offline
PostPosted: Fri Apr 24, 2015 10:48 pm    Post subject: Reply with quote
They only put two bleeders on so you could put the caliper on either side of the car. Air (bubbles, pockets, whatever) floats to the top; so do as JP said and just worry about bleeding the top bleeder.
Tim
Let's do the Time Warp again!
Richard O'Brien
rockerarm
rockerarm is offline
PostPosted: Sun Apr 26, 2015 11:44 am    Post subject: Reply with quote
While I totally agree with johnny and tim's replies here, I recently read an interesting comment in my brown colored type 3 Bentley manual. In the brake section #2, page 13, "The main function of the additional bleeder valve at the bottom of this new-type caliper is to permit old brake fluid to drain completely when the brake fluid is changed. The older-type calipers must be disassembled to drain the fluid from the lower brake fluid passage."
I will admit, I have not performed this method to flush out brake fluid. My norm has been to slowly pump the brake pedal approx. 30x for the rear cylinders and 20x for the fronts. Some may say this many times could possibly damage the master cyl internals, but I try and not bottom out the master cyl.
Hope this helps, Bill.
Tim Donahoe
PostPosted: Sun Apr 26, 2015 3:29 pm    Post subject: Reply with quote
rocker, that makes sense--as far as bleeding.
When I completely bleed the brake system, I just gravity bleed until I see nice, new brake fluid. Then have my daughter do a little pumping and holding while I open and close the bleeder screws for the final bleeds.
I haven't changed out the brake fluid since installing a new front disc conversion, but I will bleed from the bottom screw.
Tim
Richard O'Brien
kamesama980
kamesama980 is offline
PostPosted: Mon Apr 27, 2015 6:16 am    Post subject: Reply with quote
So, basically, the lower bleeder is not necessary for only bleeding air out of the brakes. It is used for flushing the brakes. Presumably the hose enters near the top of midpoint of the piston, so any fluid not between the hose inlet and bleeder wouldn't get changed in a brake flush.
I can actually say I've seen the downsides of this on my Father-in-law's cheap chinese knockoff of a honda rebel, front and rear calipers are all dual-piston with the inlet and bleeder right next to eachother. after a while, the brakes were crap and wouldn't get any better after bleeding so he took them apart. Found swamp goo filling the caliper behind the piston. old nasty fluid had never been moved with all his brake bleeding.
-Russell
"You don't get to blame me for how I fix what you break"
1970 VW Beetle
1994 Pontiac Firebird
2001 BMW R1200C
2003 Subaru Baja
theKbStockpiler
theKbStockpiler is offline
PostPosted: Mon Apr 27, 2015 11:31 am    Post subject: Reply with quote
Is this a fixed caliper or a floater?
Does it have one or two cylinders?
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
Tim Donahoe
PostPosted: Mon Apr 27, 2015 3:10 pm    Post subject: Reply with quote
Well, I'm not a fan of Empi stuff; but their front disc conversion I installed was very well made. It may have been "cheap", but sometimes that's a good thing. cheap and well-made. Now I like that.
Tim
Richard O'Brien
