Seat Rails Finally
Yustrn
JHC Controla
Yustrn is offline
PostPosted: Wed Nov 23, 2005 3:00 pm    Post subject: Seat Rails Finally Reply with quote
Finally these are available from Wolfsburg West and at 45 that ain't bad
I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Airsick
Samba Lowering Squad
Airsick is offline
PostPosted: Wed Nov 23, 2005 3:08 pm    Post subject: Reply with quote
They seem so basic. I wonder why it took so long?
Hebster52
Hebster52 is offline
PostPosted: Wed Nov 23, 2005 3:29 pm    Post subject: Reply with quote
I paid 8 euros for mine... Complete new made set by local metalshaper. Is also the outer driverseat rail that is higher available?
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Sun Nov 27, 2005 12:16 am    Post subject: Reply with quote
No, save your original.
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
Hebster52
PostPosted: Sun Nov 27, 2005 1:24 am    Post subject: Reply with quote
It's quite intresting that the left rail on the drivers seat was raised from Ch.nr. 1-0 128 116 in late 49'.. Anyone have got any explanation for this?
~Kris~
The 912ST
The KidVRod project
johnshenry
johnshenry is offline
PostPosted: Sun Nov 27, 2005 9:21 am    Post subject: Reply with quote
I don't know why that changed, but have wondered if there is a difference also in the frames of deluxe vs. std seats? (aside from the bottom not having the rail-slot). If you merely used a deluxe seat on a std floorpan, without the sliding rails, it would seem that it would be around 1.5" lower than a deluxe seat height.
I can't imagine that VW made two kinds of seat frames, but maybe.
I think at least one of the seats from my '51 is a std seat, I'll have to measure the frame height and compare it with my deluxe.
Anyone have any info on this???
John Henry
'57 Deluxe
'56 Single Cab
Hebster52
PostPosted: Thu Jun 11, 2009 9:19 am    Post subject: Reply with quote
Hmm.. I'll pull this old thread up again..
I seem to have missplaced the measurements I took off the rails before I removed the original rusted out pan. Now I dont know where to weld the seatrails.
Anyone able to measure the positions for me and others who would need to know?
~Kris~
The 912ST
The KidVRod project
virtanen
virtanen is offline
PostPosted: Thu Jun 11, 2009 11:22 pm    Post subject: Reply with quote
I can make it for you. Any preferable reference points?
Splitdog
Splitdog is offline
PostPosted: Fri Jun 12, 2009 12:27 am    Post subject: Reply with quote
Recommendation: Weld them about 2 inches further back. You'll be waaaay more comfortable AND NO ONE WILL KNOW. Wink (when was the last time you had them adjusted all the way forward?......................that's what I thought.)
CH³NO²
Z = z² + C
#notacallooker
Hebster52
PostPosted: Fri Jun 12, 2009 4:38 am    Post subject: Reply with quote
I guess the measurements from the napoleonshat and the measurements from the centertunnel would be the ones that I need.
I have some kind of memory that the rails aren't perfectly parallell to the frametunnel?
I have short legs so I guess I dont gain anything by moving them ... Laughing
~Kris~
The 912ST
The KidVRod project
virtanen
virtanen is offline
PostPosted: Fri Jun 12, 2009 10:16 am    Post subject: Reply with quote
Can you get it here?
Hebster52
PostPosted: Fri Jun 12, 2009 12:37 pm    Post subject: Reply with quote
Perfect!
Seems like I remember the 67cm correct then but the other measurements was lost in my head... Laughing
~Kris~
The 912ST
The KidVRod project
bally
bally is offline
PostPosted: Sat Sep 20, 2014 6:15 am    Post subject: Reply with quote
This thread is a few years old but I hope someone will be able to answer my query below please?
Which part of the rail are these measurements to please? Is it to the flange that welds to the floor or the rail itself: the top inner or outer of the lip or the bottom inner or outer of the big lip?
Cheers,
Dave
bally
bally is offline
PostPosted: Tue Apr 14, 2015 1:52 pm    Post subject: Reply with quote
Cheers,
Dave
Can anyone answer my question above please?
Doas anyone make a replacement rear strengthening bar for split bug seat backs please? One of mine is missing and the other is a little crusty:
How about the clips that hold the springs to the flat bar around the edges - sorry about the out of focus pictures but the clip in question is in the centre of the picture:
These are quite simple to make but even easier if someone already makes them Smile
Cheers,
Dave
Martin Southwell
Martin Southwell is offline
PostPosted: Tue Apr 14, 2015 3:32 pm    Post subject: Reply with quote
Hello Dave - I don't know what standard you are doing these seats to, but bear in mind that if you are recovering the seats nicely afterwards, the last thing you want is for these simple metal strips you talk about, to open up, and require you to uncover the seats again to affect a repair.
I had this challenge last year with the '47 seats I was refurbishing. The spring tops were originally held to the metal wire that runs around the preimeter of the seat, with the sort of simple metal tabs you mention. A low tech, imperfect solution, fraught with failure possibilites.
I couldn't bear the thought of undoing the fabric again, and so instead of using these metal strips again, I used some elongated, wire wound metal springs, which I pulled out of an NOS Swedish 1960's bed (Built like a Rolls Royce) which served the same purpose there. Having fitted these to the seats, they wont come undone again, ever!
I've asked Mika to post a couple of pictures of what I'm talking about, which will make things clearer. I hope this helps.
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Tue Apr 14, 2015 6:50 pm    Post subject: Reply with quote
Dave, I bet you could harvest those pieces from any low back seat. Might be worth checking with one of your mates that has a later low back seat you could disassemble.
Just a thought...
Cheers!
virtanen
virtanen is offline
PostPosted: Tue Apr 14, 2015 8:46 pm    Post subject: Reply with quote
Here the picture Martin asked to post.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
virtanen
virtanen is offline
PostPosted: Tue Apr 14, 2015 8:48 pm    Post subject: Reply with quote
Dave,
I have forgot the front seat bar, I will check how to make some.
Mika
New projects
bally
bally is offline
PostPosted: Tue Apr 14, 2015 11:39 pm    Post subject: Reply with quote
Thank you all for you replies and pictures. Martin, do you have any more of your nos Swedish bed springs? I am only missing a couple of those clips so I am guessing they are quite good at staying in place?
Mika, do you have a front seat bar to work from or should I remove mine and send it to you?
Does anyone have any further clarification in the location for the seat runners?
virtanen
virtanen is offline
PostPosted: Wed Apr 15, 2015 2:00 am    Post subject: Reply with quote
I have an old seat where I can check the dimensions, and need to take as sheet metal laser cuts.
I also have those tiny clips you asked. They can be found on later seats too.
For the rails location, I'll try to take pics.
Mika
New projects
