Autry21 Samba Member
Posted: Tue Jul 19, 2016 9:50 am Post subject: Re: How to lower a Bus and all lowering questions |
brese73 wrote: |
67 lowered with flipped spindles, 68 bug trans & modified spring plates. Im having an issue with tire wear. Bus rolls down the road straight as an arrow, but there seems to be a positive camber issue. Outter edges of my front tires are wearing. I installed the proper amount of spindle shims correctly. Anyone experience the same? Solution? |
Is it wear or is it rubbing the upper-fender dogleg? _________________ 1967 SO42 (A42)
1965 SingleCab |
brese73 Samba Member
Posted: Tue Jul 19, 2016 11:04 am Post subject: Re: How to lower a Bus and all lowering questions |
tire wear. no rubbing of the dogleg. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Wed Jul 20, 2016 9:32 pm Post subject: Re: How to lower a Bus and all lowering questions |
brese73 wrote: |
67 lowered with flipped spindles, 68 bug trans & modified spring plates. I'm having an issue with tire wear. Bus rolls down the road straight as an arrow, but there seems to be a positive camber issue. Outer edges of my front tires are wearing. I installed the proper amount of spindle shims correctly. Anyone experience the same? Solution? |
Double check your toe in and camber. Did you measure the trailing arm offset to determine the shim count? Do you know if your trailing arms and beam are straight/not bent? _________________ nothing |
Posted: Thu Jul 21, 2016 6:24 am Post subject: Re: How to lower a Bus and all lowering questions |
Quote: |
Double check your toe in and camber. Did you measure the trailing arm offset to determine the shim count? Do you know if your trailing arms and beam are straight/not bent? |
toe in is correct. im definitely getting a positive camber. trailing arms/beam are not bent. I measured the trailing arm offset and have the correct shim count. The outside wear of the tires is the same for both tires. is there an adjustment that can be made for camber? |
Posted: Thu Jul 21, 2016 7:20 pm Post subject: Re: How to lower a Bus and all lowering questions |
brese73 wrote: |
The trailing arm measurement to determine shim count is done specifically to make the correct camber. Those shims are the camber adjustment. Might be time to double check the measurement and shim count with the chart. _________________ nothing |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
Posted: Thu Jul 21, 2016 7:24 pm Post subject: Re: How to lower a Bus and all lowering questions |
Double check your shims, but I'd bet cdennisg's left nut that you have way too much toe-in. _________________ Aaron D. Badertscher
Click here for ALL my links. |
Posted: Thu Jul 21, 2016 7:47 pm Post subject: Re: How to lower a Bus and all lowering questions |
WideFive wrote: |
Double check your shims, but I'd bet cdennisg's left nut that you have way too much toe-in. |
I should get upset about that, but honestly, I really don't need them anymore. _________________ nothing |
Posted: Thu Jul 21, 2016 7:49 pm Post subject: Re: How to lower a Bus and all lowering questions |
cdennisg wrote: |
WideFive wrote: |
I should get upset about that, but honestly, I really don't need them anymore. |
I figured you'd just be happy that I acknowledged that you even had a set, ha, ha. _________________ Aaron D. Badertscher
Posted: Thu Jul 21, 2016 7:56 pm Post subject: Re: How to lower a Bus and all lowering questions |
WideFive wrote: |
cdennisg wrote: |
WideFive wrote: |
I figured you'd just be happy that I acknowledged that you even had a set, ha, ha. |
My wife keep's 'em in her purse. _________________ nothing |
Posted: Fri Jul 22, 2016 7:52 am Post subject: Re: How to lower a Bus and all lowering questions |
confirmed...way too much toe-in |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Fri Jul 22, 2016 8:08 am Post subject: Re: How to lower a Bus and all lowering questions |
brese73 wrote: |
Simple fix, nice. _________________ 1957 Beetle
1966 Bus |
Posted: Fri Jul 22, 2016 7:17 pm Post subject: Re: How to lower a Bus and all lowering questions |
Glad you got it figured. Tires are expensive. _________________ nothing |
megamau Samba Member
Posted: Tue Jul 26, 2016 5:04 pm Post subject: Re: How to lower a Bus and all lowering questions |
Hello,
I want to lower my bus just a little bit, and I would like to use tires 185 65R15 with porsche 356 replica rims. I read a lot over the internet and this particular thread, and I know there are some that just use flipped spindles and everything else stock however there's not that much information on cases like these. This is exactly what I want for now (front suspension wise).
So my question is: are these going to fit without rubbing? Where do tires use to rub? At the top, or side of the fender? |
tarzan271 Samba Member
Joined: October 20, 2003 Posts: 336 Location: Santa Rosa, CA
Posted: Fri Sep 09, 2016 2:44 pm Post subject: Re: How to lower a Bus and all lowering questions |
megamau wrote: |
Hello,
Should fit. Tires rub on the top if they are tall and the bus is really low (flipped spindles with adj. beam). They rub on the outside (dogleg) if you use non-stock rims with wide offsets. This is why people narrow the beams. I am not sure what the offset of the 356 rims are compared to the stock bus rims, but I assume they are similar. _________________ ~Tarzan
1964 Deluxe Bus - Sold |
Posted: Fri Sep 09, 2016 4:34 pm Post subject: Re: How to lower a Bus and all lowering questions |
tarzan271 wrote: |
megamau wrote: |
Hello,
Should fit. Tires rub on the top if they are tall and the bus is really low (flipped spindles with adj. beam). They rub on the outside (dogleg) if you use non-stock rims with wide offsets. This is why people narrow the beams. I am not sure what the offset of the 356 rims are compared to the stock bus rims, but I assume they are similar. |
There are 2 types of offsets for these rims, 4.5x15 ET25 (like stock) and 5.5x15 ET15. So probably the ones with stock offset should fit. |
brokenbus951 Samba Member
Joined: August 15, 2008 Posts: 32 Location: Winchester, Ca
Posted: Fri Sep 30, 2016 10:30 am Post subject: Re: How to lower a Bus and all lowering questions |
I did a search and couldn't find the answer i was looking for. I have a lowered Splitty (4") with a 2" narrowed beam. Im running stock 15" wheels. I dont really care for the big & little look so, i want to run the same diameter all the way around.
Size suggestions? |
Posted: Fri Sep 30, 2016 10:34 am Post subject: Re: How to lower a Bus and all lowering questions |
195/60r15 _________________ Aaron D. Badertscher
kingodirtp3 Samba Member
Joined: December 07, 2007 Posts: 1062 Location: Monterey CA
Posted: Thu Nov 17, 2016 10:12 am Post subject: Re: How to lower a Bus and all lowering questions |
I found out that bug sway bars fit bus beams.
I got a 2 in narrowed beam, didn't like the body roll without the swaybar so I got a few different bars and found that a 2 inch narrowed bug swaybar fits a 2inch narrowed bus beam. I used the stainless clamps and urethane bushings too, goes around corners much better now!
the bug bar is 3/4 instead of 7/8 but it works great since its a narrowed beam. |
jacopotex Samba Member
Joined: June 05, 2015 Posts: 76 Location: gorizia italy
Posted: Sun Dec 04, 2016 8:01 am Post subject: Re: How to lower a Bus and all lowering questions |
cdennisg wrote: |
mastorna wrote: |
Well, I was able to fab a bolt to match the former PO's solution.
If anyone has a better idea for a proper solution or if ya'll think this works just fine, let me know. |
That axle tube is clocked 45 degrees out of alignment. Your end casting should have the bolt holes at the four corners, not top/bottom/left/right.
I am having trouble wrapping my head around how that happened. I am guessing that the axle tubes were installed on the wrong sides.
Here is a beetle rear suspension setup. Yours should look nearly identical to this when properly assembled.
hi have the same problem i think, but i removed the swing axle from a bug, so i think that the end casting are in the right position.
than a friend give me the harry harpics kit, for adapt the bus spring plates to the bug plate, it the same that you can see on the book "how to modify volkswagen bus"
and this is the cut zone
what can i do for resolve this problem?
didn't foud many information about harry harpics kit |
Posted: Sun Dec 04, 2016 11:38 am Post subject: Re: How to lower a Bus and all lowering questions |
I have never heard of that kit. but it does appear to cause clearance issues with the upper shock cover. You may need to relocate the upper shock mount and/or remove that upper cover. _________________ nothing |
