How to lower a Bus and all lowering questions
Page: Previous  1, 2, 3 ... 83, 84, 85 ... 98, 99, 100  Next
Help Help
Help Help is offline
PostPosted: Mon Feb 15, 2016 6:55 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I'm getting ready to correct the height on the rear of my 67 kombi for the second time. After consulting the tables, 6 splines each way should get me there. Where I can use a hand is any tips for getting the spline count right? I'm OK on the outside but I get lost on the inside. What works?
Help Help
cdennisg
cdennisg is offline
PostPosted: Mon Feb 15, 2016 7:06 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Mark a straight vertical line (I use a silver paint pen) on the end of the torsion bar and the spring plate where it meets the edge of the torsion bar before you pull the two apart. Remove the spring plate, and remove the torsion bar slightly so that it comes free from the splines. Using feel, (yes this is done by feel) turn the bar how ever many notches you want by feeling it click in and out of each inner spline. Then install the spring plate by counting the splines between the marks you made before pulling it all apart.
Once you have done all of this, you will probably find that going by the charts and trying to make this a logical math problem will leave you with an uneven bus. For whatever reason, torsion bars seem to never match perfectly side-to-side. That is why I never bother with protractors and charts. I measure the end of the spring plate to the floor right before I pull things apart. Then I set the end of the spring plate at whatever amount of height change I want right before I put it all back together. Sometimes I will end up adjusting one side one more time to get it just right. This is where adjustable spring plates are nice. But I'm cheap/poor so I take the more laborious route.
nothing
Help Help
PostPosted: Wed Feb 17, 2016 5:11 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Thanks for the tips. I'll try the measuring from the floor, that sounds like it might work just fine.
jacopotex
jacopotex is offline
PostPosted: Tue Feb 23, 2016 1:09 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Hi folks!
i'm looking for doing my self the offset spring plates.
So at the moment i cut the orginal bus spring plates, and i screwed on the swing axle tube, the final piece of a beetle springplate.
i measured the distance between the two spring plates, and i see it's 40mm.
is it possible?
if is ok i will solder this week.
mandraks
mandraks is offline
PostPosted: Tue Feb 23, 2016 1:32 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
jacopotex wrote:
Hi folks!
is it possible?
i recommend welding Smile
regards
Uli
jacopotex
PostPosted: Tue Feb 23, 2016 1:49 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
mandraks wrote:
jacopotex wrote:
Hi folks!
is it possible?
yes sure a good solder i don't want to loose a wheel Very Happy
jacopotex
PostPosted: Thu Feb 25, 2016 4:13 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
no one has ever done?
NAES
NAES is offline
PostPosted: Mon Mar 07, 2016 1:12 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
They're just messing with you man. Yes people have joined 2 spring plates together before. In the US we call it welding. Do you call it soldering in Italy? Just for curiosities sake.
NAES
Barndoor Mafia
Box On Wheels
SBS #00
jacopotex
PostPosted: Tue Mar 08, 2016 3:35 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Sorry i made a mistake with the words.
it's correct welding
GLHTurbo
GLHTurbo is offline
PostPosted: Tue Mar 08, 2016 9:45 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Running rear discs on a '68 bug trans/axles, 5x130 rotors. Need to order new rotors. Do people typical run press in studs, or lug bolts to mount wheels with rear discs? Studs are certainly better, but as far as removing the rear wheel from the bus will lug bolts be preferred?
1957 Beetle
1966 Bus
easy e
easy e is offline
PostPosted: Tue Mar 08, 2016 6:29 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
GLHTurbo wrote:
Running rear discs on a '68 bug trans/axles, 5x130 rotors. Do people typical run press in studs, or lug bolts to mount wheels with rear discs? Will lug bolts be preferred?
I use studs. Depends on how low you are too. Right now... do you clear the studs or fight the studs when installing/removing a wheel?
I was tired of it being too low... scraping front tire tub... extra steps in taking shocks off & jacking the axle tube down just to get the back wheel off. Raised it up some to be more manageable. If I remember... I think I pondered the thought of bolts vs. studs... and decided studs + raise.
Does anybody make a female threaded lug hole on 5x130 rotor?
aka: Evan
GLHTurbo
GLHTurbo is offline
PostPosted: Wed Mar 09, 2016 7:45 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Nothing is installed in the bus yet actually, just trying to figure out what parts to order.
These are the rotors I will be buying:
http://www.socalautoparts.com/product_info.php/ind...30-p-13522
"AC Industries Porsche pattern Drums/Rotors come drilled with two sets of holes. One set tapped for 14mm screw-in studs and one set drilled for 14mm press-in studs."
1957 Beetle
1966 Bus
Dubskii
Dubskii is offline
PostPosted: Wed Mar 09, 2016 4:00 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
After reading these forums over and over it seems like the most popular rear tire set up is a 195/55 or 195/60 when lowering a bus. When these tires are paired with a FF transmission with a 3.88 3rd / 0.82 4th how are the RPMs affected?
69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
57 Kombi - Dove Blue http://www.thesamba.com/vw/forum/viewtopic.php?t=648240
WTB Early Dove Blue Bus Driver's Side Door
WTB Joe Heishman VW Arlington, VA License Plate Frame or Other Memorabilia
wrenchnride247
wrenchnride247 is offline
PostPosted: Wed Mar 09, 2016 7:11 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I think you mean 3.88 ring and pinion (not 3rd gear)
With a 3.88 R&P with .82 4th and 195/60/15 you will have to do 79 mph to have 3500 rpm in fourth. (not good)
With 195/55/15 you will need to do 77 mph to get 3500 rpm in fourth. (still not good)
Why 3500 rpm? (glad you asked Laughing )That's the ideal rpm for fan speed to cool motor. If sticking with a basic T1 motor the engine will overheat and be sluggish. You should consider keeping .89 for 4th gear. Your motor will thank you. You need to give more info on motor size and driving habits to help more.
SPL
'62 SC 69x90.5 SP TI
'70 T1 84x105 DP T4
Dubskii
Dubskii is offline
PostPosted: Wed Mar 09, 2016 10:59 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
What defines a FF trans? Is it the 3.88 or 4.12 R&P, the 0.82 or 0.89 4th or a combo of these? I have a 1600DP and want to lower my bus with either 195/55/15 or 185/60/15 rear tires. I would like to cruise on the freeway at no more than 65mph. What is the trans set-up I need? Would it change if I went to a 1776?
What is the equation to calc the RPMs and MPHs? Does the equation work for only 4th gear or all gearing?
My trans gearing is as follows: 1st-3.80, 2nd-2.06, 3rd-1.26, 4th-0.89, R&P-3.88, Small nut RGBs-1.39.
wrenchnride247
PostPosted: Thu Mar 10, 2016 8:36 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Basically, A FF is late model ('73 T1 and later) gearing which is, 3.88 R&P, 3.78 1st, 2.06 2nd, 1.26 3rd, and .89 4th. But, you can also do a 4.12 R&P with same gears, but use .82 4th to give almost the same final drive as 3.88 with .89 4th, but with shift point RPM difference between 3rd and 4th. A 1600ccDP will push it, but not be very exciting to drive. A 1776cc would be better which is what I run, but SP with dual 34 ICT's. I run 65 mph all day and have 350 deg. head temp's. I use this calculator http://johnmaherracing.com/calculators/gear-ratio-calculator/ It's easier/faster than using the formula. If you are lowering your bus, just build the new trans with the gearing that looks (remember the 3500 rpm) the best for your tire diameter. The RGB's you're running now will be fine until you drop it with straight axle rear.
SPL
'70 T1 84x105 DP T4
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Mon Mar 21, 2016 4:26 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I was wondering if anyone has changed the rear hatch hinges to allow the rear hatch to open higher. I am 6'3" tall and with my bus lowered the hatch opens right to about top of my forehead. I am also half blind which really doesn't help the situation.
So is it possible to work the hinge in a way that lets it lift higher? And has anyone done it?
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
flemcadiddlehopper
PostPosted: Mon Mar 21, 2016 7:15 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I took a fairly close look at the hinge and it seems that if i shortened the flat 3/16" steel stop plate it would allow it up a bit. Also if I notched the hinge bracket that attaches to the hatch where it meets the stop, it would give it even more lift.
Thoughts?
Gordo.
cdennisg
cdennisg is offline
PostPosted: Mon Mar 21, 2016 7:18 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Thoughts?
Gordo.
That torsion spring setup is a pretty ingenious and complicated thing. Are you sure that allowing the hinges more movement would not allow some part of the mechanism to come loose?
nothing
Page 84 of 100
