JasonSatterthwaite Samba Member
Posted: Fri Jul 29, 2016 9:44 pm Post subject: Swing arm camber |
Hello
I'm sure this has been asked a thousand times. New VW fiberglass buggy owner. The rear wheels are cambered in at the bottom dramatically. Is this a modification or adjustment?
I'm not the best at mechanics but I cannot see how it can be lowered. Is it longer shocks?
Thank you for any help
Jason |
jsturtlebuggy Samba Member
Posted: Fri Jul 29, 2016 9:49 pm Post subject: Re: Swing arm camber |
Do you have all the weight in the buggy? Including the engine and battery, etc...
Swing axles will straighten out with the engine weight usually.
Do you have pictures of the buggy showing what you are talking about? _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Fri Jul 29, 2016 10:14 pm Post subject: Re: Swing arm camber |
I cant seem to upload a pic with the motor in it now. I have the motor back in now.
With the motor back in it didn't change much even when I jump in the back
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Fri Jul 29, 2016 10:31 pm Post subject: Re: Swing arm camber |
The wheels have to be rolling for the camber to change. The tires won't just slide outwards across the ground if you jump on it, they'll just dig in.
After the engine, battery, back seat, engine cage, etc., are all installed, roll it back and forth a few feet, then you'll know if it will settle down.
You should have just a couple degree positive camber \-o-/ with the car unloaded. If its too much or too little, you need to reindex the torsion bars |
Posted: Sat Jul 30, 2016 12:09 pm Post subject: Re: Swing arm camber |
Thanks so much for the help. Done some more research now and I have a better understanding.
Thanks again
Jason |
