Jmart045 Samba Member
Posted: Fri Jul 29, 2016 7:39 pm Post subject: New to rail buggy and VW engine need help! |
I bought a rail buggy with a 1968 motor. It's smoking so I know it will need rings soon but can't get it to idle. Put new carb and intake on it and new plugs. All from the guys at a VW shop. I'll will have to get the exact carb I bought but I try to adjust idle with screws on carb with no change at all. I have to hold down on throttle just to keep running. Any ideals or help? Thanks! |
Dark Earth Samba Member
Posted: Fri Jul 29, 2016 8:14 pm Post subject: Re: New to rail buggy and VW engine need help! |
Are there any electrical connections on the carburetor that aren't hooked up ? _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
jsturtlebuggy Samba Member
Posted: Fri Jul 29, 2016 9:43 pm Post subject: Re: New to rail buggy and VW engine need help! |
Do you have pictures of your engine setup.
Saying an engine is from 1968 it would be hard to say if it is all stock or someone in the last 48 years has modified it. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Tue Aug 02, 2016 7:27 am Post subject: Re: New to rail buggy and VW engine need help! |
Yes there was I finally found out that the idle aid valve has to be hooked to negative side of coil. What about the electrical pay off the choke? Is idling and running good now. Has anyone every put a 1999 vw bettle motor on a rail buggy? I got one for $100 and suppose to run and drive. |
Posted: Tue Aug 02, 2016 8:18 am Post subject: Re: New to rail buggy and VW engine need help! |
Jmart045 wrote: |
Yes there was I finally found out that the idle aid valve has to be hooked to negative side of coil. What about the electrical pay off the choke? Is idling and running good now. |
The pilot jet cutoff valve needs to be wired to the (+) side of the coil with 12 volts constantly. The choke is your winter starting aid. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Tue Aug 02, 2016 8:27 am Post subject: Re: New to rail buggy and VW engine need help! |
What is that even for? |
Posted: Tue Aug 02, 2016 8:43 am Post subject: Re: New to rail buggy and VW engine need help! |
Jmart045 wrote: |
If you're talking about the idle valve, It's so the car won't "run on" or "diesel" after you turn the key off. The positive side of the coil will give you 12 volts constantly when the ignition switch is turned on. I believe the negative side of the coil will pulse on and off as the points open and close (not what you want).
Just hook it to the (+) side of the coil and you'll be golden. Listen for it to click when you turn the key on and it's working. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Tue Aug 02, 2016 10:08 am Post subject: Re: New to rail buggy and VW engine need help! |
Awesome thanks! Have you or do you know anyone that has put a 1999 vw bettle on a rail buggy? |
dustymojave Samba Member
Posted: Tue Aug 02, 2016 10:30 pm Post subject: Re: New to rail buggy and VW engine need help! |
Crumco Motorsports
Featured in Dune Buggies & Hot VWs.
They've built several others. Some, like Black Beauty above with original VW steel body shells and some with all fiberglass bodies. _________________ Richard
SoCalBajas Member
Posted: Thu Aug 04, 2016 1:39 pm Post subject: Re: New to rail buggy and VW engine need help! |
What I was asking if anyone has taken the powertrain and put it on a rail buggy. That's my plan so far. |
