NL-Scirocco75 Samba Member
Joined: August 31, 2013 Posts: 9 Location: Maarssen, The Netherlands
Posted: Thu Jul 28, 2016 2:46 pm Post subject: 1964 Split bus Turkis/Blue-White interior factory color? |
I am restoring a June 64 Standard (that was wearing) Turkis/ blue-white.
I can't find in topics and tech info nor on other sides the white color code used for the complete interior (i.e. not the pieces like gear and brake levers that are well described in the color schemes) on floors, dash, air box etc.
Would this be the exterior top color (in this case the blue white) or another white color?
Help/reference info is very much appreciated. |
EmpiGT Samba Member
Posted: Thu Jul 28, 2016 3:04 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
Yes all the interior body metal on the inside of your bus will be the top color,(blue white) except the inside of the doors, they are two tone like the exterior. |
Posted: Thu Jul 28, 2016 3:18 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
EmpiGT wrote: |
Indeed, i've seen the Turkis overspray on the front doors inside.
The item "all the interior body metal on the inside" is not mentioned in all color schemes in the tech area (or e.g. on the WW site, nor could I found it in og workshop manuals from the restoration shop).
It surprises me that using the same white color for the inside seems obvious for you. I must have missed something? |
EmpiGT Samba Member
Posted: Thu Jul 28, 2016 3:30 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
1961 and older it was the bottom exterior body color used on the inside. I'm sure there is a write up somewhere on it. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69801 Location: Phoenix Metro
Posted: Thu Jul 28, 2016 4:54 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
You are right I haven't seen it mentioned anywhere in the Bus literature.
I think of it as being part of the body so it's the same as the exterior paint.
The removable parts are the parts that are a different white color.
Just to confirm things - I have an original paint Turkis/Blue-White '63 and the dash and overhead vent and floors are all Blue-White. _________________ How to Post Photos
esde Samba Member
Joined: October 20, 2007 Posts: 5965 Location: central rust belt
Posted: Thu Jul 28, 2016 5:04 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
EmpiGT wrote: |
I'm working on a 62 that's turkis on the inside, I'm pretty sure it's original paint. Maybe it is a 61 production, or the transition isn't exactly 61? _________________ modok wrote:
Posted: Thu Jul 28, 2016 5:09 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
esde wrote: |
EmpiGT wrote: |
I'm working on a 62 that's turkis on the inside, I'm pretty sure it's original paint. Maybe it is a 61 production, or the transition isn't exactly 61? |
Hmm, not sure when this changed.
The dash is original paint Turkis?
What's the month from the Mcode plate or the VIN #? _________________ How to Post Photos
esde Samba Member
Posted: Thu Jul 28, 2016 5:32 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
EverettB wrote: |
esde wrote: |
EmpiGT wrote: |
What's the month from the Mcode plate or the VIN #? |
It's the only layer of paint inside, and given the history very unlikely it's ever been stripped down before. It was bought disassembled with a lot of strange bits, like a Turkis green steering wheel. I'll be w the bus tomorrow welding in floors, will grab a pic of the m code. It's a 15 window if that matters _________________ modok wrote:
EmpiGT Samba Member
Posted: Thu Jul 28, 2016 5:35 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
I've seen turkis 1961's with turkis dash. does this 62 have the later 62 style dash with the rounded corner speedo pod? |
esde Samba Member
Posted: Thu Jul 28, 2016 9:21 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
I'm not sure on the dash. Here are a few pics I have that show the interior color. Honestly it's a bit more green than turquoise, but it's definitely not been resprayed. The color is places you wouldn't ever get with a respray..
Posted: Fri Jul 29, 2016 3:08 am Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
EverettB wrote: |
Just to confirm things - I have an original paint Turkis/Blue-White '63 and the dash and overhead vent and floors are all Blue-White. |
"I think of it as being part of the body so it's the same as the exterior paint."
Sounds reasonable, really strange that no documentation describes this, considering the nature of our (German) neighbors
I wonder when/how they sprayed the interior during production, would require a lot of taping on each two tone bus to prevent the outer paint to get sprayed over or v.v.
Not easy, but decided to go for full body restauration so the og paint is removed. As I need to decide soon I'll go for blue/white unless more info would pop up.
From the pictures below and previously in day light, I found it hard to say what color it was with 52 yrs history on it.
As to thank you for your input some nice pictures; below the "og white paint" and the "no paint" status after recent high pressure water blasting.
Clara Samba Member
Posted: Fri Jul 29, 2016 6:47 am Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
NL-Scirocco75 wrote: |
EverettB wrote: |
I wonder when/how they sprayed the interior during production, would require a lot of taping on each two tone bus to prevent the outer paint to get sprayed over or v.v. ....
IIRC, for 62& later, the whole exterior and cab was painted the lower color.
Then the upper was painted over the lower below the beltline and in the cab.
Having the colour under the 'white' does give a shading to the 'white'.
Is there a thread on where the body was painted? I wouldn't be surprised.
headlight buckets showing SWR under BG on 63 microbus:
headlight bucket wear showing Titian red under BeigeGrey:
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
esde Samba Member
Posted: Fri Jul 29, 2016 4:23 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
EmpiGT wrote: |
EverettB wrote: |
I just got in from welding new cargo floors into this bus. Even though it's been blasted clean there's still remnants of green in lots of corners. The green steering wheel is something I've never seen before either, I'm waiting for a picture of it to come through.. _________________ modok wrote:
EmpiGT Samba Member
Posted: Fri Jul 29, 2016 6:21 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
That is an odd one. Not even a really early 1962 as in a late 61 production year. Someone must have been hung over from the night before. |
daveintactown Samba Member
Joined: January 28, 2021 Posts: 6 Location: Tacoma, WA, USA
Posted: Mon Sep 13, 2021 5:08 pm Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
I'm trying to determine the proper grab bar vinyl color for my 63 Turkis/como green. Can anyone enlighten me as to whether ivory or silver beige is correct? They are so dingy I can no longer tell.
Thx. |
widehatch Samba Member
Joined: May 27, 2007 Posts: 775 Location: Memphis, TN aka The Armpit of the South
Posted: Fri Sep 17, 2021 6:14 am Post subject: Re: 1964 Split bus Turkis/Blue-White interior factory color? |
esde wrote: |
SD |
i've never seen the rear interior metal of a bus painted the body color behind the headliner _________________ Missouri Micros |
