jason Samba Member
Posted: Tue Jul 26, 2016 4:50 pm Post subject: 86C with 1.3 or 86B with 1.4 |
I'm trying to get about .03 valve clearance running an 86c with 1.4's. I was thinking about changing to 1.3's to see if I can find it. I also have an 86B I can run with the 1.4's. I'm thinking my motor would like the higher duration of the C. It is a 2387, L7's, 10.5 with SS pistons. Anyone running an 86C with 1.3's? I would have to buy the 1.3's to try. My heads were cut a bit too much so trying to find solutions. Deck is .053 so I can't add it there. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Jul 26, 2016 5:36 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
Jason,
Sell the pistons and get wiseco/AA forged ones. You're killing yourself. I just don't understand it. Adjust to 10.5 cr and have over .204ths of valve clearance with 1.5 ratio, +2 adv and .584 lift on an 86c like me. I'm running 11.2 cr. Your chasing and trying to make compromises to make the squishes work. Get it built so you can enjoy it. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4848 Location: sanger ca
Posted: Tue Jul 26, 2016 6:15 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
^^^^^ after having built a ss motor, this is very good advice _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
jason Samba Member
Posted: Tue Jul 26, 2016 10:05 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
Yes, I know, won't do it again. I don't have my car ready for the motor yet so I have a bit more time to figure the motor out. I spent too much time to give up now. We'll see how it runs first. I would be good if the heads weren't cut too much again. It's actually 10.6 now. Realistically I don't think the little bit less lift will be that big of a difference. Would be easier to just mill the dome off if I do flat tops. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Wed Jul 27, 2016 5:46 am Post subject: Re: 86C with 1.3 or 86B with 1.4 |
Is that the specific cam and lobe center recommended for the SS pistons? |
jason Samba Member
Posted: Wed Jul 27, 2016 7:45 am Post subject: Re: 86C with 1.3 or 86B with 1.4 |
John said nothing special. Build it normally and add some more compression. It would be fine if I used smaller valves, cam or less compression. Shoulda woulda coulda |
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Wed Jul 27, 2016 10:44 am Post subject: Re: 86C with 1.3 or 86B with 1.4 |
Sorry for the small hijack, but what makes using these Pistons such a pain in the ass? |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
jason Samba Member
Posted: Wed Jul 27, 2016 1:35 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
Yes, domed piston. 42mm valves or smaller would be good. 44's a tad too big |
67_looker Samba Member
Posted: Wed Jul 27, 2016 1:36 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
mcmscott wrote: |
^^^^^ after having built a ss motor, this is very good advice |
X2
Don’t make compromises with the cam timing and valve lift. You will lose more than you gain with the SS pistons. Run a tight deck between 0.035-0.040 with flat tops. SS pistons is best suited for small cam drivers, with high compression to gain MPG |
maui Samba Member
Posted: Wed Jul 27, 2016 4:27 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
I running 10t1 comp and Fk10 straight up on my 2500cc with 42x37 valves and I get at least 80 thousand piston dome clearance and if jetted right dat ting going be cherry cuz I feel the compression is to low to make a diff for the dome.I tried retard 2 deg and feel the same but idle not working for me so I got it back to normal and work good. |
jason Samba Member
Posted: Sat Jul 30, 2016 6:10 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
I had some time to mess around with it today. I checked the rockers on a different set of heads and they came out to 1.41. They are 1.4's. I thought maybe I should check on the heads that they are going to live on, 1.48. There's my problem. Getting .577 out of it. Gonna mess with the rocker blocks, they need to come down anyway. Hopefully I can find the clearance. I realized they would be different head to head, I just didn't think they'd be that different. |
mark tucker Samba Member
Posted: Sat Jul 30, 2016 8:42 pm Post subject: Re: 86C with 1.3 or 86B with 1.4 |
almost every set of rockers with the pushrod adjuster end Ive had to lower .060" to get the geo right.(cb, bug poop, empi&clones) I have some that need to go even lower a lot lower I think they were made for long valves& diferent stud location.....got 2 sets of them new extreamly nice but almost useless.around 1.6 ratio as they are, they were just plain made rong. I think thats where the needel bearing rockers got such a bad name as that kills needels&other parts as moct people dont have a clue as to properly setup rocker systems/valve train.
have you changed cam degrees to see where it go,s and what it needs?figure how much they need clearancing? addvance a little and get more ex clearance then knotch the intake if needed. there are loytsa ways to skin a cat, some get what you need some get you all scratched, some get you bit and some get you arested. pic your pleasure. |
