lrcdnc Samba Member
Posted: Tue Jul 26, 2016 3:25 pm Post subject: Low oil pressure |
Well I just rebuilt my engine from a 1600cc to 1700cc, new cam brg, crank brg, lifters, all internals. Also installed a new 28mm oil pump. Also converted it over to an external oil filter. I'm using a K&N HP 2004 filter. Plugged the one side of the oil pump for the external filter. Filled the engine with 10w-30 oil. Before starting the engine I tried bring the oil pressure up. I could only get 20 PSI. Pulled to cover off the pump and removed the gasket. With the gasket I had .006 clearance between the cover and the pump. With the gasket removed I have .002 clearance, but still only 20 PSI. Any Ideas, what am I missing? |
gringoloco2000 Samba Member
Joined: August 15, 2013 Posts: 150 Location: Debary, FL
Posted: Tue Jul 26, 2016 9:08 pm Post subject: Re: Low oil pressure |
How are you priming it? When I prime mine, I don't think I get over 20PSI. I turn it over with the coil disconnected until I get over 10PSI. Have you gotten is started and don't get over 20PSI when you are over 2K RPM? _________________ '68 Rust Bucket |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Jul 26, 2016 10:05 pm Post subject: Re: Low oil pressure |
would first change that oil filter- on starting a new engine they throw gobs of stuff to the oil-
Next would check the oil pressure relief valve n spring- we just had one with the wrong spring- _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
mark tucker Samba Member
Posted: Thu Jul 28, 2016 11:13 am Post subject: Re: Low oil pressure |
always remove sparking bolts when spinning the engine to prime the oil system !!!. did you put the pistons in then the springs?or the springs then the pistons? are all the clearances correct? were they checked? |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Thu Jul 28, 2016 5:03 pm Post subject: Re: Low oil pressure |
You plugged the pump outlet. Did you also plug the matching outlet galley? If the pump housing is undersized it can bleed pressure out that galley.
Usually I can get about 40psi cranking for oil pressure. Yes, I abuse my starter and battery... A recent build I couldn't get the pressure above 20... Hmmm. Fired it up and had about 70 psi at break in RPM. No worries here. |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Thu Jul 28, 2016 5:42 pm Post subject: Re: Low oil pressure |
I do not know if the cranking oil pressure is normal or not, but it's certainly good enough to start the engine. |
Posted: Thu Jul 28, 2016 6:04 pm Post subject: Re: Low oil pressure |
modok wrote: |
I agree. |
lrcdnc Samba Member
Posted: Fri Jul 29, 2016 7:56 am Post subject: Re: Low oil pressure |
williamM wrote: |
Next would check the oil pressure relief valve n spring- we just had one with the wrong spring- |
I've installed a new type pressure relief valve, the type with the grove at the top. But the low pressure was there when I had the old pressure relief in. |
lrcdnc Samba Member
Posted: Fri Jul 29, 2016 8:00 am Post subject: Re: Low oil pressure |
modok wrote: |
I think your right. 20 PSI by just turning over with just the battery isn't bad. It should have better psi running. I'm waiting on my SVDA distributor to crank iit up. Thanks. |
lrcdnc Samba Member
Posted: Fri Aug 05, 2016 9:24 am Post subject: Re: Low oil pressure |
lrcdnc wrote: |
modok wrote: |
Yup started the engine yesterday and had 60+ psi. After 20 min. brake in and up to temp. still had 45+ psi.
Thanks everyone for your comments it helped. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
