jl7474 Samba Member
Joined: July 18, 2016 Posts: 4 Location: Henderson, NV
Posted: Tue Jul 26, 2016 8:05 am Post subject: 1776 Carbs |
I just bought a Thing for my wife and it has a 1776 engine. It has a mild cam and big valve heads. It currently has dual Kadron's on it. I don't like the way it accelerates when taking off from a stop light and from what I'm being told that is fairly common for these types of carbs. I am considering switching to dual 40 Webers. Is this a good idea? What are you opinions and also what is the best kit to get?
Here is the ones I am currently looking to buy.
http://www.jbugs.com/product/43-7317.html?Category_Code=1973-vw-thing-performance-carburetors
Thank you for any help! |
jl7474 Samba Member
liken127 Samba Member
Joined: June 27, 2013 Posts: 102 Location: Upland Ca.
Posted: Tue Jul 26, 2016 8:11 pm Post subject: Re: 1776 Carbs |
Just did the 40 Webbers, And they were great out of the box!
they went on a 1914, with a little bigger than stock heads. |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Jul 27, 2016 4:33 am Post subject: Re: 1776 Carbs |
The ICT's would be a step in the wrong direction, as they are 34mm vs the 40mm of the Kads.
Are you sure your Kads are adjusted/synced correctly? Verify your accelerator pump is working correctly, they are often out of adjustment and need to be shimmed. |
74 Thing Samba Member
Posted: Wed Jul 27, 2016 8:39 am Post subject: Re: 1776 Carbs |
If you make the change you want 2 two barrel carbs. You already have 2 single barrel carbs on it now so you want the upgrade. John at Aircooled.net has a program where he will disassemble and clean/set the floats and jet according to your combination and elevation. That may be something you want to look into. |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Wed Jul 27, 2016 6:40 pm Post subject: Re: 1776 Carbs |
I like my K-Dogs. They are reliable. The plenum based design makes them forgiving to meatheads like me...but they dont perform. You can spend a buck or two and send them to the Kady Shack...fix 'em up proper! I need a new motor and am looking at a single carb setup. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
tobiasax Samba Member
Posted: Sun Jul 31, 2016 11:17 pm Post subject: Re: 1776 Carbs |
It sounds like something is wrong with your engine/carbs. Kadrons shouldn't behave that way.
I used dual Kads om my 1776cc w stock 040 heads and Engle W110 cam. It ran great always with good respons. It was strong as hell on low/mid rpm. However, above around 4500 rpm the engine wanted more than the carb could deliver.
I later did switch to dual 40DRLA with 32 mm venturies and did some porting. This really woke the engine up at higher rpm. However I did lose a little low end punch.
Good luck! _________________ __________________________________________ |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Sat Nov 12, 2016 11:49 pm Post subject: Re: 1776 Carbs |
Can a 34 pict 3 feed a 1776?
Sorry, yes, kind of a high jack _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sun Nov 13, 2016 9:24 am Post subject: Re: 1776 Carbs |
jmstu76 wrote: |
Sorry, yes, kind of a high jack |
yes 30,00 miles drive it every day runs great 1776 110 cam bugpack headers 009 dist ( yes a 009 ) stock 34 carb. |
Posted: Mon Nov 14, 2016 5:59 am Post subject: Re: 1776 Carbs |
citroen wrote: |
jmstu76 wrote: |
Last engine I tried to do the 110 34PICT carb combo on idled like dog poop. Did you have to jet it way up to get it to work? |
