21junkstreet Samba Member
Joined: April 28, 2013 Posts: 72 Location: Memphis, TN.
Posted: Mon Jul 25, 2016 9:01 pm Post subject: Electric fuel pump recommendation. |
I have a 66 squareback with a set of 34 Dellorto single barrels . About a thousand miles ago I replaced the pump. It is a Carter universal unit you can get at O'Reillys. I used that one because that was what was already on the car. I remember the PO saying he put a pump on it as well. Tomorrow I am going to clean the screen in the tank. Has anybody had good luck with a particular brand? |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
Posted: Mon Jul 25, 2016 9:42 pm Post subject: Re: Electric fuel pump recommendation. |
21junkstreet wrote: |
I've been running a MrGasket brand pump (#42S) for several years with both Weber 34's and Solex 32's. The pump in my Notch has been in there since 2010 after heat soaking 2 mechanical pumps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Mon Jul 25, 2016 10:28 pm Post subject: Re: Electric fuel pump recommendation. |
Yeah , I've been reading up on FI using megasquirt or whatever using OE components. This car has 59k original miles on it. It's so great to drive. I know it takes away from the originality, but if you could get in it in any weather condition, fire it up, and drive it all afternoon, it would be awesome!. That's the way I'm going to go, but until then I need to mess with these carbs a little longer. I've actually read good things about Dellortos. |
Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
Posted: Tue Jul 26, 2016 6:39 am Post subject: Re: Electric fuel pump recommendation. |
I have also done the MS II installation on my 70 Fastback. I would be happy to answer any questions you might have, I also have a .msq you can use as a starting point. |
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Wed Jul 27, 2016 7:52 pm Post subject: Re: Electric fuel pump recommendation. |
Thanks for the input, guys. The fuel injection reads are informative as they are interesting. But that's for a later date. When I was in high school in the early 90s I worked at an air-cooled shop I remember throwing away boxes and boxes of type 1,2and 3 fuel injection stuff one time when we were cleaning up because " nobody will ever want any of this garbage" . Now I'm looking for it. This weekend I'll put another Carter on it and clean the screen, maybe take the tank out if I have to , to clean it. Thanks again, Patrick. |
