streetbuggy8804 Samba Member
Joined: August 25, 2009 Posts: 652 Location: Placentia,ca
Posted: Mon Jul 25, 2016 6:23 am Post subject: Tunnel bottom removal |
Does anyone happen to have a link to a thread where someone removed the tunnel bottom plate? I am thinking about doing this so that I can route all my lines through there ( efi engine, hydraulic clutch ect). Thanks. _________________ Manxter DS #32
Fabricator wanna-be |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jul 25, 2016 6:46 am Post subject: Re: Tunnel bottom removal |
It is easier to cut a couple of 'doors' (openings) in side of tunnel where 'tubes' are clamped internally to change out existing lines and also to clamp in new lines.... Then just weld up openings when done... Removing and replacing bottom is long arduous job that may not be necessary... Adel clamps on inside wall of tunnel are great and you only need small opening to place and bolt them...
Bottom graphic in link below is active and you can click on portions and it will show detailed picture of different sections...
http://www.vwdcqinc.org.au/vwdcqimages/insideabugimages/insidetunnel.html
The there is the whole magilla...
https://www.google.com/search?q=inside+the+VW+tunn...p;ie=UTF-8
Posted: Mon Jul 25, 2016 7:49 am Post subject: Re: Tunnel bottom removal |
Thanks dale. I don't mind the work and I already have a couple of access panels with gusset plates that I have created. I'm looking for a thread because I know the removal process but would like a reference to someone who has done it. _________________ Manxter DS #32
WHYYYTRYYY Samba Member
Joined: June 30, 2016 Posts: 50 Location: Jackson, NJ
Posted: Mon Jul 25, 2016 3:33 pm Post subject: Re: Tunnel bottom removal |
Hey streetbuggy, any pics of your access panels? I'm about to pull the body off my kit car and replace the front clip of the tunnel. While I'm in there, I am moving the shifter location back, omitting the ebrake handle, and replacing everything inside the tunnel. I was considering easy access panels instead of welding everything back. I was going to frame the hole with light plate steel welded in, then drill and tap some holes for a form fitting cover and gasket. |
Posted: Mon Jul 25, 2016 4:18 pm Post subject: Re: Tunnel bottom removal |
Turnkey Manx sells a nice little guest kit. Mine I created myself because they were not commercially abailable at the time.
This one is the only pic I have. Prior to holes being drilled of course. Nothing crazy. Just simple renforcement
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1104 Location: North East Pennsylvania
Posted: Mon Jul 25, 2016 5:21 pm Post subject: Re: Tunnel bottom removal |
I removed the bottom plate on my 1969 chassis because the person that shortened the chassis cut all the tubes and just left the ends hanging. I spliced all the cut ends and reinforced the clutch tube welds.
There are a lot of welds to drill out.
One thing to be sure of is to support the tunnel well before welding it back together. You don't want to weld it back together twisted.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Posted: Wed Jul 27, 2016 6:23 pm Post subject: Re: Tunnel bottom removal |
This is such an awesome forum. Glad I joined. Saves me so much time hunting around online trying to find specific, detailed pictures of such things. Thanks for the excellent pictures guys. |
SoCal67Volks Samba Member
Joined: April 07, 2008 Posts: 158 Location: San Pedro California
Posted: Wed Jul 27, 2016 8:04 pm Post subject: Re: Tunnel bottom removal |
......and an additonal Thank You!
My original plans for shortening my pan included removing the bottom plate from the tunnel. I wanted to add some reinforcements as well as additional fuel return lines for future fuel injection to the inside of the tunnel.
Thanks for the pics! I'm now going to drop my pan (& bottom tunnel plate) to add the internal gussets and fuel lines I intended to do the first time.
Thanks again (I have some catching up to do!). _________________ 1967 Type 1 Sunroof
Meyers Manx Kickout
Meyers Manx SR2
"Making a car look complicated is easy, making it look simple is hard." John Buttera |
