allmom3p Samba Member
Posted: Sun Jul 24, 2016 8:33 pm Post subject: Help with reading plate |
Can someone help me decipher this plate...I have a cheat sheet but still can't make heads or tails...
Thanks in advance!!!
[/img] |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Sun Jul 24, 2016 8:39 pm Post subject: Re: Help with reading plate |
1965 convertible. Built in August of 1964. So it's one of the first 1965 models produced.
1170 is the gross vehicle weight in kilograms
The two numbers below that are gross weights for the front and rear axle _________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sun Jul 24, 2016 8:51 pm Post subject: Re: Help with reading plate |
Typ 15 -- it's a type 15, which is a convertible Beetle
Fahrgest Nr -- Chassis number or VIN 155 028 ###
The VIN starting with the '65 model year has the third digit denoting the model year, so a VIN starting with 155 would be a 1965, 156 would be a 1966, and so forth. Looking up the VIN on the chart in the technical tab on this site shows that your car is from the very first month of production for '65 models, and was therefor built in August of 1964.
As noted above, 1170 is the maximum gross vehicle weight in kilograms. Also the 480 and 700 would be the maximum front and rear axle weights, respectively, in kilograms. _________________ 1960 Ragtop w/Semaphores "Inga" |
