Howard 111 Samba Member
Posted: Sun Jul 24, 2016 1:43 pm Post subject: WOT and shift point |
Like it says, when you are racing, or just stretching you legs for a few gears, what is your shift redline.
I have a street Ghia with a turbo, and shifting at 6,000 seems to be all this engine wants or needs. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sun Jul 24, 2016 3:27 pm Post subject: Re: WOT and shift point |
Really depends on the engine combo, Howard. I had a 1750 in a car that went with power to 65-6700rpm. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Sun Jul 24, 2016 3:39 pm Post subject: Re: WOT and shift point |
There is no one RPM fits all answer for this question. You have a turbo engine and I have a NA engine. The RPM's are not in the same class. Mine is a 1679 with a 119* webcam and stock heads sporting dual single throat carbs. If I ring it's neck I get 5400rpm. But normally can take it to 5K without much worry. Now I once had it rev above 5800K during a burn out on wet pavement. But the rev limiting rotor protected from any damage. I think I need to learn a little better throttle control during lose of traction events
Enjoy the ride. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Sun Jul 24, 2016 3:55 pm Post subject: Re: WOT and shift point |
a turbo might make it higher or it might make it lower rpm than if it was NA, depends on the sizing of the turbo, charge temp, and manifold dimensions. |
Posted: Sun Jul 24, 2016 5:14 pm Post subject: Re: WOT and shift point |
I think the cam has as much to do with it as anything. But it's really the whole combo. I had a drag Ghia for a while that had a shift point of 8,000. The first few times I heard it twist that high, it gave me the creeps!!!
But it stayed together. I ran 1/8 mile drags, with a best of a 7.57. I never went past 3rd gear before I was in the traps. I never won a penny, got a few trophies, but man was it fun!!!
My butt-dyno tells me my turbo Ghia now, would be a close run, and I couldn't pick a winner. _________________ 1973 Karmann Ghia
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Mon Jul 25, 2016 4:02 am Post subject: Re: WOT and shift point |
Goin from N/a IDA motors to 'Turbo" bug i need to learn all over
"Short ' shifting that is ,my turbo's will rev to the Moon,,,, but??? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
mark tucker Samba Member
Posted: Mon Jul 25, 2016 9:50 am Post subject: Re: WOT and shift point |
when my ears tell me to.....I found some stainless jam nuts for my rockers that added a few more rpm ,Ive not hit the float rpm .since titanium wood be nice for a little more cushion. tit metrick nuts are eazy to find & cheep but...the 5/16 seems to be made with bird teeth. I reckon the usaf dosent use many that size. there are somany factors that can alter the rpm. many people try to make it go too high when the heads, cam,exhaust,intakes, rockers or carbs dont work there . thats when shit happens. dont try to make 200 hp out of a 2332 with 70 hp heads. |
