Marcq Samba Member
Joined: June 15, 2015 Posts: 231 Location: Corona, CA
Posted: Sun Jul 24, 2016 12:58 pm Post subject: Can the steering colum be re-attached without the dash |
Hey guys!! Need to do some major work on my dash, want to take it off completely and be able to drive it for some time. Can the steering column be re-attached without the dash?
Thanks, Marc.. |
Marcq Samba Member
Posted: Sun Jul 24, 2016 1:19 pm Post subject: Re: Can the steerring colum be re-attached without the dash |
Wont have a problem fabricating something, is it related to the column ?
On pictures I see two brackets coming down to the column, wont be enough?
I planing to do a temporary shelf for the instrument cluster that would be attached to those two brackets
Thanks
Marc.. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
?Waldo? Samba Member
Posted: Sun Jul 24, 2016 1:42 pm Post subject: Re: Can the steering colum be re-attached without the dash |
Buy another dashboard. |
Posted: Sun Jul 24, 2016 1:43 pm Post subject: Re: Can the steering colum be re-attached without the dash |
There are 2 brackets behind the dash already that support the column not the dash. |
Marcq Samba Member
Posted: Sun Jul 24, 2016 1:45 pm Post subject: Re: Can the steering colum be re-attached without the dash |
Thanks, that answered some question
But actually I lied I want to remove the thing(dash, heater core) permanently, haven't use the heater since I've owned it, motor needs to be change and I don't want to, and don't need to, I live in Cal and I want to make my van light weight in all aspect of it
Thanks
Marc.. |
Posted: Sun Jul 24, 2016 1:57 pm Post subject: Re: Can the steering colum be re-attached without the dash |
That is a fair bit of hassle for not much weight savings.
If you have your heart set on getting rid of it once you have the dash out, pulling the heater box and putting the dash back it would be easier that trying to figure if you can drive with the dash out. |
Marcq Samba Member
Posted: Sun Jul 24, 2016 2:14 pm Post subject: Re: Can the steering colum be re-attached without the dash |
syncrodoka wrote: |
Saw a picture, I think it was Ben's that had the hole dash out on a dash removing article, it look huge the room saving up front, I find the dash is as is useless beside hiding what's behind
Marc.. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sun Jul 24, 2016 2:35 pm Post subject: Re: Can the steering colum be re-attached without the dash |
I just can't fathom wanting to own/drive a vanagon with the dash permanently removed. It will look like absolute $H!T all the time. Vanagons are appreciating in value. You might consider selling it and buying a POS Dodge Caravan or the like to use as the object of your destruction.
You never need to defog your windshield? |
Marcq Samba Member
Posted: Sun Jul 24, 2016 2:44 pm Post subject: Re: Can the steering colum be re-attached without the dash |
djkeev wrote: |
Brackets are welded to air box/crash beam.....
Dave |
Thanks Dave
Marc.. |
Marcq Samba Member
Posted: Sun Jul 24, 2016 2:47 pm Post subject: Re: Can the steering colum be re-attached without the dash |
Andrew A. Libby wrote: |
Never since I owned it (2 years), I have a ceiling fan behind my head but don't use it for defog
Marc.. |
Posted: Sun Jul 24, 2016 6:18 pm Post subject: Re: Can the steering colum be re-attached without the dash |
djkeev wrote: |
The lower ones are. Look at what the upper column bracket actually bolts to(not the dash)- the 2 black brackets on either side of the master cylinder that attach to the bulkhead. The dash probably provides some side to side rigidity though.
I didn't see the part where you wanted to leave out the dash permanently. That seems like all kinds of fun in the event of a crash. |
Paulbeard Samba Member
Posted: Sun Jul 24, 2016 6:29 pm Post subject: Re: Can the steering colum be re-attached without the dash |
If you had the tools/skills to do it, I could see cutting the dash so you retain the mounting for the column and the vents, but the rest (the top half) could be removed like the instrument cluster. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
WLD*WSTY Samba Member
Joined: November 04, 2009 Posts: 438 Location: Arizona
Posted: Mon Jul 25, 2016 9:02 pm Post subject: Re: Can the steering colum be re-attached without the dash |
Nominated for the Wall of Shame... _________________ '82 SyncroWesty, the first ever conversion.'06 Subaru 2.5L |
Merian Samba Member
Posted: Mon Jul 25, 2016 9:10 pm Post subject: Re: Can the steering colum be re-attached without the dash |
I second _________________ .... |
Marcq Samba Member
Posted: Mon Jul 25, 2016 9:36 pm Post subject: Re: Can the steering colum be re-attached without the dash |
WLD*WSTY wrote: |
Nominated for the Wall of Shame... |
Cool!! At least I will be on some walls
Marc.. |
