RkyMtnWhiteWolf Samba Member
Posted: Sun Jul 24, 2016 11:39 am Post subject: Rear Turn Signals Not Flashing But Fronts Are |
What should I check and where is it? |
jspbtown Samba Member
Posted: Sun Jul 24, 2016 1:05 pm Post subject: Re: Rear Turn Signals Not Flashing But Fronts Are |
Need a LOT more info before someone can help you.
Type of rear lights?
How are they wired?
Type of turn signal switch?
New problem? Old problem? |
Frizbal Samba Member
Posted: Sun Jul 24, 2016 2:00 pm Post subject: Re: Rear Turn Signals Not Flashing But Fronts Are |
Are you sure they aren't blinking, or are they so dim you can't tell a difference? My wiring is the original from 69, so but the time the current the flasher puts out gets to the light, it has already cut it off again for the next blink and therefore BARELY lights up. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jul 24, 2016 3:01 pm Post subject: Re: Rear Turn Signals Not Flashing But Fronts Are |
First check that you have not lost ground to rear lamps....
