LinkeLoutje Samba Member
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Sun Jul 24, 2016 8:30 am Post subject: Re: Electrics 1972 1300 beetle |
I don't know.
But i do know the rear window defrosters almost never work at all anyway. the painted on grids evaporate away and makes trying useless. There are new windows with new grids. In that case It might matter. |
Posted: Sat Aug 06, 2016 1:17 am Post subject: Re: Electrics 1972 1300 beetle |
May I give this a little bump? Still curious what these are! |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sat Aug 06, 2016 4:18 pm Post subject: Re: Electrics 1972 1300 beetle |
First pic the top part is the fresh air fan switch, bottom part is just an aftermarket interior light someone has added.
Part in the second pic is some sort of non original switch, possibly for that extra interior light. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Sat Aug 06, 2016 10:21 pm Post subject: Re: Electrics 1972 1300 beetle |
The mid-70's 1300cc Beetle may have been a non-US model 1200 (just as SB is model 1302/1303). This 1200 wiring diagram may be closer to your actual wiring:
Compare both and use the one that best matches. _________________ AshMan40
Posted: Wed Aug 10, 2016 1:26 pm Post subject: Re: Electrics 1972 1300 beetle |
Thanks. I'm quite sure it has been a European 1300 deluxe from 1972.
That fresh air switch, where is that located on these schemes? (the non USA 1200 scheme is a lot more difficult to read btw...)
The item on the second picture (https://www.thesamba.com/vw/gallery/pix/1534858.jpg) is then the light switch? I've found that switch on another donor beetle as well. Might be quite a coincidence that both beetles have this switch? |
