static337 Samba Member
Joined: December 04, 2015 Posts: 106 Location: United States
Posted: Sat Jul 23, 2016 5:46 pm Post subject: Need help finding a barrel nut for a 28 pict carb |
Found one. Thanks all for the help.
Danwvw Samba Member
Posted: Sat Jul 23, 2016 6:04 pm Post subject: Re: need help finding a barrel nut for a 28 pict carb |
Thanks the second one I've found similar ones but have been told they don't fit a 28 pict I'll double check with the seller. |
mukluk Samba Member
Posted: Sat Jul 23, 2016 9:13 pm Post subject: Re: need help finding a barrel nut for a 28 pict carb |
Thank you. That's what I need. But not gonna pay 10 dollars shipping on a 4 dollar part. Bummer. |
mukluk Samba Member
Posted: Sat Jul 23, 2016 10:11 pm Post subject: Re: need help finding a barrel nut for a 28 pict carb |
In similar cases where shipping cost exceeded the item cost, I usually end up fleshing out the order some with other bits and bobs that I've had floating about on my "want" list -- there are always small items and projects that could use some attention, or at the very least having a couple OEM spare parts about does come in handy from time to time. _________________ 1960 Ragtop w/Semaphores "Inga" |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sun Jul 24, 2016 3:42 am Post subject: Re: Need help finding a barrel nut for a 28 pict carb |
I'm not sure where you're getting that other barrel clamps won't fit.
The ones on the carbs were the same diameter going back a very long ways. In the late 60s they changed from a flat head screw to an 8mm hex head, but the barrel size was the same.
I'm one of the few people around who actually like the old slotted-style barrel clamp - well I like the original look of it better than the 8mm style. But I've used BOTH styles at various times over the years, on the 28PICT on my 62 bug.
Really, all of these examples interchange!
What won't work are the larger diameter barrel clamps used on the heater box levers up to the early/mid 60s. _________________ Andy T.
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Jul 24, 2016 4:52 am Post subject: Re: need help finding a barrel nut for a 28 pict carb |
static337 wrote: |
Well - if you read it on the internet, it must be true .... I have run into one here and there that is a little too snug but if I didnt have any other options, a piece of sandpaper would solve that.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Jul 24, 2016 5:53 am Post subject: Re: Need help finding a barrel nut for a 28 pict carb |
I'll take a sellers word on it not fitting before wasting the money on one that won't fit. If that's reading it on the Internet then I'm guilty. |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Sun Jul 24, 2016 5:58 am Post subject: Re: Need help finding a barrel nut for a 28 pict carb |
I've got several extras. Happy to send you one. PM me your address. _________________ '65 Sunroof Bug |
glutamodo wrote: |
What won't work are the larger diameter barrel clamps used on the heater box levers up to the early/mid 60s. |
Hmm. I'll keep looking. Seems thato the ones I found have a diameter of 5/16 or 8mm I'm measuring only 6mm of opening on my throttle lever. |
Posted: Sun Jul 24, 2016 5:59 am Post subject: Re: Need help finding a barrel nut for a 28 pict carb |
rcroane wrote: |
I've got several extras. Happy to send you one. PM me your address. |
Awesome. Sending pm now. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Jul 24, 2016 8:13 am Post subject: Re: Need help finding a barrel nut for a 28 pict carb |
Or you can go this route and save 50% on the part and I'm sure he won't charge $10 for shipping.
http://www.thesamba.com/vw/classifieds/detail.php?id=1792579
This was accomplished with a classifieds search using 'barrel".
You might want to buy a small grip of em. When I used to take my car to the local VW repair they routinely "replaced the clamp with the "correct" part" _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Jul 24, 2016 12:07 pm Post subject: Re: Need help finding a barrel nut for a 28 pict carb |
static337 wrote: |
Not sure how you got 6mm there. It is supposed to be 8mm.
